HI Ti
The learning was completed using BQ28Z610-R1, and PACK assembly is scheduled to proceed.
I would like to inquire a few before that.
1. Can I change items such as Termination Voltage and Taper Current after completing the learning?
2. In general, do you proceed with PACK assembly and input golden image? Or do you enter in PCM state?
3. Do I need to perform calibration for each pack?
+ Can I proceed to Cal only the current and PACK Voltage after assembling the pack?
4. I would like to manage the serial number separately and enter it in the Fuel Gauge. Which field should I enter?
-I2C Configuration-Serial? or System Data-Manufacture Info
5. How can I check if Golden Image is correct?
Jeong
