Other Parts Discussed in Thread: TPS23882
I am accessing a TPS2881 driver in I2C configuration B (16 bits-access)
When reading several registers, the contents of the first 4 bytes are OK but the following bytes are read as 0xFF.
Is it possible to read more 4 bytes in a raw like in any I2C device?
Does the issue come from the configuration B?
I have 36 bytes in a raw to access (simply done by the DMA of my microcontroller) and hope I will not have to make 9 read operations!
Is there a trick?
Thank you
