The PS pin is floating forced CCM mode. The fsw should be 1.1Mhz but I measured 600khz only.
Please check attached schematic, thanks.
Can you resend the schematic, it did not get sent with your message.
Davor
From the schematic I see that PS is connected via 240kOhm to GND and it is not floating.
Can you make sure that this resistor is infact assembled on your board?
Davor
Hi Jim,
Due to holiday time, we will need a bit more time to investigate the attached schematics and feedback to you.
Please allow us to come back to you by beginning of next week.
Thanks!
Yann
Hello Jim,
What is the typical load you are using ?
Could you send us a waveform of the SW pin as well as the PS waveform on the same scope shot ?
Is the PS voltage greater than 2.2V ?
Let us know.
Thanks a lot!
Dorian
Hello Jim,
As we are continuing via emails. I am closing this thread.
If you want to open it again, please reply below.
Thanks a lot!
Dorian
