TPSM82810: PCB layout question
Part Number: TPSM82810
Hi team,
Could you comment whether the extended land pattern and solder paste design of PIN5 is necessary? Thanks!
The PCB layout engineers of my customer have some concern on the clearance between PIN5 & PIN6.
Sam Ting
  • Hi Sam,
    Let me check on the reason for making pin 5's land pad larger.  It will likely be next week before I can give an answer.
    I calculate a pad separation of 250 um between pin 5 and pin 6.  Does this match what you calculate?  How is this an issue?  (I think there is less separation between pins 5 and 12, for example.)
  • Hi Sam,
    I confirmed that you can choose to not extend pin 5's pad so close to pin 6, if you need to.  In most applications, pin 5 is connected to a large copper pour to carry the output current.  So, you will likely have copper there anyways from the Vout plane.
    I am still curious what issue the spacing between pin 5 and 6 caused for you?
  • Hi Chris and Sam,
    Got it. Thanks for the support.
    The PCB layout engineer is concern about whether the distance is too short that increase the risk of shorting.
    However, after evaluating the process ability, we will convince him to built the footprint as TI suggestion.
    Thanks!
    Kilo Wu
