I am currently using a TL431 with around 30V in this schematic:
I want to use TL431 for voltage over 36V. Is there a use case for this? Will the circuit with two TL431 work? (something like this):
Andrii.
Andrii.
Stacking will allow getting past the absolute max voltage rating but if you can specify the intended use we could check if the setup will achieve the objectives. Can you please share more details?
