hi,my TPS65640 power ic Positive voltage and negative voltage are not synchronized,I want to output the same voltage value,eg:AVDD output +6.0V at the same time VGL is -6.0V
Hello Xiao,
Negative charge pimp is only enabled and starts ramping up after AVDD has reached its programmed voltage value. So AVDD will always come up first and than negative charge pump VGL. They can not come up at the same time.
Kind Regards,
Liaqat
What voltage values are you currently getting for AVDD and VGL rails?
Can you please attach schematics of your design? Also, please let me know the values that registers 0x01 and 0x06 are programmed to.
Kind Regards,
Liaqat
