TPS63900: Can this device be connected in parallel?
Part Number: TPS63900
I would like to ask you about the TPS63900 device.
Is it possible to use this device to connect outputs in parallel?
The idea is to connect multiple devices in parallel and handle large currents.
In this device, the output voltage is set inside the device, so I would like to hear from you if parallel connection is possible.
