Part Number: BQ27421EVM-G1B
Other Parts Discussed in Thread: GPCRB, EV2400, , GPCCHEM
ello,
We are using the BQ27421 Fuel Gauge in our project. We have a problem with StateOfCharge (returns battery percentage). Also, our project contains a GSM module that uses much power consumption (peak current +/- 2A). When we used our device in the normal temperature range (0°C - +25°C) we didn't detect any issues with the fuel gauge.
Issues that were detected:
- If the device is used at low temperature (-15°C - 0°C) we detect a percentage drop from 50% to 0% or from 100% to 70% or from 80% to 50% in the small-time period. Yes, we know about battery voltage swing when we have a high current consumer (GSM module) But why don't the percentage value go back after finishing working with a high current consumer?
Please, check LOGS_1.txt, LOGS_2.txt, LOGS_3.txt, LOGS_4.txt, LOGS_5.txt, and LOGS_6.txt files (see below)
Questions:
1. Why do we have a percentage drop? How to fix it?
2. Why doesn't the percentage return back after moving to the normal voltage value immediately? What are fixing ways?
Settings, that we use for FG:
MIN_TEMPERATURE_THRESHOLD = -50 (it means -5°C); SOC1_SET_THRESHOLD = 10; SOC1_CLEAR_THRESHOLD = 15; SOCF_SET_THRESHOLD = 2; SOCF_CLEAR_THRESHOLD = 5; HIBERNATE_MILLIAMPS = 0; HIBERNATE_MILLIVOLTS = 3000; QMAX_MILLI_A_H = 16'384; CAPACITY_MILLI_A_H = 810; ENERGY = 3078; (ENERGY = 3.8 * CAPACITY_MILLI_A_H) TERMINATE_MILLIVOLTS = 3520; TAPER_RATE = 144; TAPER_VOLTAGE = 4100;
Voltage -> Voltage(): 0x04 and 0x05 Percentage -> StateOfCharge(): 0x1C and 0x1D Temperature -> Temperature(): 0x02 and 0x03 Registers were requested every 5 seconds --GSM module enable and try to cconnect to network ----- FG: Voltage= 3777, Percentage= 7, Temperature= -14.9 FG: Voltage= 3619, Percentage= 7, Temperature= -14.7 FG: Voltage= 3602, Percentage= 7, Temperature= -14.8 FG: Voltage= 3650, Percentage= 7, Temperature= -14.9 FG: Voltage= 3753, Percentage= 7, Temperature= -14.8 FG: Voltage= 3572, Percentage= 7, Temperature= -14.9 FG: Voltage= 3555, Percentage= 7, Temperature= -14.8 FG: Voltage= 3551, Percentage= 7, Temperature= -14.8 FG: Voltage= 3276, Percentage= 7, Temperature= -15.0 FG: Voltage= 3071, Percentage= 0, Temperature= -14.8 FG: Voltage= 3109, Percentage= 0, Temperature= -14.8 FG: Voltage= 3421, Percentage= 0, Temperature= -14.8 FG: Voltage= 3475, Percentage= 0, Temperature= -15.1 FG: Voltage= 3567, Percentage= 0, Temperature= -14.9 FG: Voltage= 3645, Percentage= 0, Temperature= -14.8 FG: Voltage= 3688, Percentage= 0, Temperature= -14.7 FG: Voltage= 3268, Percentage= 0, Temperature= -14.8 FG: Voltage= 3489, Percentage= 0, Temperature= -14.8 FG: Voltage= 3432, Percentage= 0, Temperature= -14.2 FG: Voltage= 3436, Percentage= 0, Temperature= -13.6 FG: Voltage= 3450, Percentage= 0, Temperature= -12.9 FG: Voltage= 3512, Percentage= 0, Temperature= -12.4 FG: Voltage= 3702, Percentage= 0, Temperature= -11.9 FG: Voltage= 3633, Percentage= 0, Temperature= -11.1 FG: Voltage= 3860, Percentage= 0, Temperature= -10.8 FG: Voltage= 3938, Percentage= 0, Temperature= -10.6 FG: Voltage= 3938, Percentage= 0, Temperature= -10.6 FG: Voltage= 3979, Percentage= 0, Temperature= -10.2 FG: Voltage= 3982, Percentage= 0, Temperature= -10.0 FG: Voltage= 3936, Percentage= 0, Temperature= -9.7 FG: Voltage= 3815, Percentage= 0, Temperature= -9.3 FG: Voltage= 3654, Percentage= 0, Temperature= -8.8 FG: Voltage= 3834, Percentage= 0, Temperature= -8.1 FG: Voltage= 3931, Percentage= 0, Temperature= -7.7 FG: Voltage= 3868, Percentage= 0, Temperature= -7.5 ---------- GSM module disable -------------------------- FG: Voltage= 3819, Percentage= 0, Temperature= -7.3 FG: Voltage= 3955, Percentage= 0, Temperature= -7.1 FG: Voltage= 3996, Percentage= 0, Temperature= -6.8 FG: Voltage= 3999, Percentage= 0, Temperature= -6.6 FG: Voltage= 4005, Percentage= 0, Temperature= -6.3 FG: Voltage= 4005, Percentage= 0, Temperature= -6.1 FG: Voltage= 4010, Percentage= 0, Temperature= -5.8 FG: Voltage= 4009, Percentage= 0, Temperature= -5.6 FG: Voltage= 4014, Percentage= 0, Temperature= -5.3 FG: Voltage= 4016, Percentage= 0, Temperature= -5.1 FG: Voltage= 4012, Percentage= 0, Temperature= -4.8 FG: Voltage= 4019, Percentage= 0, Temperature= -4.6 FG: Voltage= 4019, Percentage= 0, Temperature= -4.4 FG: Voltage= 4020, Percentage= 0, Temperature= -4.3 FG: Voltage= 4021, Percentage= 0, Temperature= -3.9 FG: Voltage= 4021, Percentage= 0, Temperature= -3.7 FG: Voltage= 4025, Percentage= 0, Temperature= -3.4 FG: Voltage= 4026, Percentage= 0, Temperature= -3.2 FG: Voltage= 4001, Percentage= 0, Temperature= -2.9 FG: Voltage= 4008, Percentage= 0, Temperature= -2.6 FG: Voltage= 4029, Percentage= 71, Temperature= -2.3 FG: Voltage= 4030, Percentage= 71, Temperature= -2.1 FG: Voltage= 4031, Percentage= 71, Temperature= -1.9 FG: Voltage= 4032, Percentage= 71, Temperature= -1.7 FG: Voltage= 4032, Percentage= 71, Temperature= -1.4 FG: Voltage= 4034, Percentage= 71, Temperature= -1.3
Voltage -> Voltage(): 0x04 and 0x05 Percentage -> StateOfCharge(): 0x1C and 0x1D Temperature -> Temperature(): 0x02 and 0x03 The device worked at low temperature and send data to the server every hour --------------------------------------------------------------- FG: Voltage= 4,12 Percentage= 84 Temperature= -2 FG: Voltage= 4,09 Percentage= 82 Temperature= -2 FG: Voltage= 4,08 Percentage= 80 Temperature= -2 FG: Voltage= 4,08 Percentage= 78 Temperature= -2 FG: Voltage= 4,07 Percentage= 77 Temperature= -2 FG: Voltage= 4,08 Percentage= 75 Temperature= -2 FG: Voltage= 4,07 Percentage= 74 Temperature= 0 FG: Voltage= 4,07 Percentage= 72 Temperature= 0 FG: Voltage= 4,07 Percentage= 71 Temperature= 0 FG: Voltage= 4,06 Percentage= 70 Temperature= 0 FG: Voltage= 4,06 Percentage= 69 Temperature= 2 FG: Voltage= 4,06 Percentage= 68 Temperature= 2 FG: Voltage= 4,05 Percentage= 67 Temperature= 1 FG: Voltage= 4,04 Percentage= 66 Temperature= 0 FG: Voltage= 4,03 Percentage= 65 Temperature= -2 FG: Voltage= 4,03 Percentage= 65 Temperature= -1 FG: Voltage= 4,02 Percentage= 64 Temperature= -1 FG: Voltage= 4,01 Percentage= 61 Temperature= -2 FG: Voltage= 3,99 Percentage= 58 Temperature= -2 FG: Voltage= 3,98 Percentage= 54 Temperature= -2 FG: Voltage= 3,97 Percentage= 50 Temperature= -3 FG: Voltage= 3,96 Percentage= 43 Temperature= -3 FG: Voltage= 3,95 Percentage= 36 Temperature= -4 FG: Voltage= 3,94 Percentage= 31 Temperature= -4 FG: Voltage= 3,93 Percentage= 26 Temperature= -5 FG: Voltage= 3,93 Percentage= 22 Temperature= -6 FG: Voltage= 3,92 Percentage= 19 Temperature= -6 FG: Voltage= 3,91 Percentage= 15 Temperature= -7 FG: Voltage= 3,9 Percentage= 11 Temperature= -7 FG: Voltage= 3,89 Percentage= 8 Temperature= -7 FG: Voltage= 3,88 Percentage= 6 Temperature= -7 FG: Voltage= 3,86 Percentage= 5 Temperature= -7 FG: Voltage= 3,86 Percentage= 3 Temperature= -5 FG: Voltage= 3,86 Percentage= 3 Temperature= -4 FG: Voltage= 3,88 Percentage= 0 Temperature= -2 FG: Voltage= 3,87 Percentage= 0 Temperature= -2 FG: Voltage= 3,87 Percentage= 0 Temperature= -2 FG: Voltage= 3,87 Percentage= 0 Temperature= -2 FG: Voltage= 3,86 Percentage= 0 Temperature= -2 FG: Voltage= 3,85 Percentage= 0 Temperature= -3 FG: Voltage= 3,85 Percentage= 0 Temperature= -4 FG: Voltage= 3,84 Percentage= 0 Temperature= -5 FG: Voltage= 3,83 Percentage= 0 Temperature= -6 FG: Voltage= 3,83 Percentage= 0 Temperature= -6 FG: Voltage= 3,82 Percentage= 0 Temperature= -7 FG: Voltage= 3,82 Percentage= 0 Temperature= -7 FG: Voltage= 3,81 Percentage= 0 Temperature= -7 FG: Voltage= 3,81 Percentage= 0 Temperature= -7 FG: Voltage= 3,81 Percentage= 0 Temperature= -6 FG: Voltage= 3,8 Percentage= 0 Temperature= -7 FG: Voltage= 3,8 Percentage= 0 Temperature= -8 FG: Voltage= 3,79 Percentage= 0 Temperature= -8 FG: Voltage= 3,78 Percentage= 0 Temperature= -9 FG: Voltage= 3,78 Percentage= 0 Temperature= -9 FG: Voltage= 3,78 Percentage= 0 Temperature= -8 FG: Voltage= 3,78 Percentage= 0 Temperature= -8 FG: Voltage= 3,78 Percentage= 0 Temperature= -7 FG: Voltage= 3,78 Percentage= 0 Temperature= -5 FG: Voltage= 3,78 Percentage= 0 Temperature= -4 FG: Voltage= 3,78 Percentage= 0 Temperature= -4 FG: Voltage= 3,78 Percentage= 0 Temperature= -4 FG: Voltage= 3,78 Percentage= 0 Temperature= -5 FG: Voltage= 3,77 Percentage= 0 Temperature= -5 FG: Voltage= 3,76 Percentage= 0 Temperature= -6 FG: Voltage= 3,76 Percentage= 0 Temperature= -7 FG: Voltage= 3,76 Percentage= 0 Temperature= -7 FG: Voltage= 3,75 Percentage= 0 Temperature= -7 FG: Voltage= 3,73 Percentage= 0 Temperature= -8 FG: Voltage= 3,72 Percentage= 0 Temperature= -8 FG: Voltage= 3,73 Percentage= 0 Temperature= -8 FG: Voltage= 3,75 Percentage= 0 Temperature= -8 FG: Voltage= 3,74 Percentage= 0 Temperature= -8 FG: Voltage= 3,74 Percentage= 0 Temperature= -8 FG: Voltage= 3,74 Percentage= 0 Temperature= -8 FG: Voltage= 3,74 Percentage= 0 Temperature= -8 FG: Voltage= 3,74 Percentage= 0 Temperature= -7 FG: Voltage= 3,74 Percentage= 0 Temperature= -7 FG: Voltage= 3,74 Percentage= 0 Temperature= -7 FG: Voltage= 3,73 Percentage= 0 Temperature= -8 FG: Voltage= 3,73 Percentage= 0 Temperature= -8 FG: Voltage= 3,46 Percentage= 0 Temperature= -6 FG: Voltage= 3,73 Percentage= 0 Temperature= -6 FG: Voltage= 3,46 Percentage= 0 Temperature= -6 FG: Voltage= 3,46 Percentage= 0 Temperature= -6
STATUS REGISTER -> CONTROL_STATUS: 0x0000 FLAGS REGISTER -> Flags(): 0x06 and 0x07 Voltage -> Voltage(): 0x04 and 0x05 Percentage -> StateOfCharge(): 0x1C and 0x1D Temperature -> Temperature(): 0x02 and 0x03 Registers were requested every 5 seconds --------------------------------------------------------------- FG: Voltage= 4231, Percentage= 70, Temperature= -0.8 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FLAGS REGISTER = 8 (Bin: High: 00000000 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4231, Percentage= 100, Temperature= -0.5 FLAGS REGISTER = 8 (Bin: High: 00000000 Low: 00001000 ) STATUS REGISTER = 9096 (Bin: High: 00100011 Low: 10001000 ) FG: Voltage= 4231, Percentage= 100, Temperature= -0.5 FLAGS REGISTER = 8 (Bin: High: 00000000 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4220, Percentage= 100, Temperature= -0.5 FLAGS REGISTER = 8 (Bin: High: 00000000 Low: 00001000 ) STATUS REGISTER = 9096 (Bin: High: 00100011 Low: 10001000 ) FG: Voltage= 4228, Percentage= 100, Temperature= -0.5 FLAGS REGISTER = 8 (Bin: High: 00000000 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4231, Percentage= 100, Temperature= -0.5 --- percentage drop detected --- FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9096 (Bin: High: 00100011 Low: 10001000 ) FG: Voltage= 4229, Percentage= 70, Temperature= -0.5 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4231, Percentage= 70, Temperature= -0.6 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9096 (Bin: High: 00100011 Low: 10001000 ) FG: Voltage= 4231, Percentage= 70, Temperature= -0.6 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4223, Percentage= 70, Temperature= -0.6 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9096 (Bin: High: 00100011 Low: 10001000 ) FG: Voltage= 4230, Percentage= 70, Temperature= -0.6 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4228, Percentage= 70, Temperature= -0.6 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9096 (Bin: High: 00100011 Low: 10001000 ) FG: Voltage= 4230, Percentage= 70, Temperature= -0.6 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4230, Percentage= 70, Temperature= -0.6 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9096 (Bin: High: 00100011 Low: 10001000 ) FG: Voltage= 4230, Percentage= 70, Temperature= -0.6 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4228, Percentage= 70, Temperature= -0.7 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9096 (Bin: High: 00100011 Low: 10001000 ) FG: Voltage= 4230, Percentage= 70, Temperature= -0.7 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4230, Percentage= 70, Temperature= -0.7 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9096 (Bin: High: 00100011 Low: 10001000 ) FG: Voltage= 4230, Percentage= 70, Temperature= -0.8 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4230, Percentage= 70, Temperature= -0.8 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9096 (Bin: High: 00100011 Low: 10001000 ) FG: Voltage= 4228, Percentage= 70, Temperature= -0.8 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000 ) STATUS REGISTER = 9112 (Bin: High: 00100011 Low: 10011000 ) FG: Voltage= 4231, Percentage= 70, Temperature= -0.8
STATUS REGISTER -> CONTROL_STATUS: 0x0000 FLAGS REGISTER -> Flags(): 0x06 and 0x07 Voltage -> Voltage(): 0x04 and 0x05 Percentage -> StateOfCharge(): 0x1C and 0x1D Temperature -> Temperature(): 0x02 and 0x03 Registers were requested every 5 seconds --------------------------------------------------------------- FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4081, Percentage= 81, Temperature= 6.4 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4081, Percentage= 81, Temperature= 6.2 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4081, Percentage= 81, Temperature= 5.9 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4082, Percentage= 81, Temperature= 5.7 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4081, Percentage= 81, Temperature= 5.4 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4081, Percentage= 81, Temperature= 5.2 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4081, Percentage= 81, Temperature= 4.9 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4080, Percentage= 81, Temperature= 4.7 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4080, Percentage= 81, Temperature= 4.4 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4080, Percentage= 81, Temperature= 4.2 ------------- small persentage swing detected ------------ FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4078, Percentage= 83, Temperature= 3.9 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4079, Percentage= 83, Temperature= 3.7 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4079, Percentage= 83, Temperature= 3.4 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4078, Percentage= 83, Temperature= 3.2 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4077, Percentage= 83, Temperature= 2.9 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4075, Percentage= 83, Temperature= 2.7 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4076, Percentage= 83, Temperature= 2.5 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4075, Percentage= 83, Temperature= 2.2 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4076, Percentage= 83, Temperature= 2.0 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4075, Percentage= 83, Temperature= 1.8 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4073, Percentage= 83, Temperature= 1.5 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4074, Percentage= 83, Temperature= 1.3 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4074, Percentage= 83, Temperature= 1.0 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4073, Percentage= 83, Temperature= 0.8 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4073, Percentage= 83, Temperature= 0.6 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4072, Percentage= 82, Temperature= 0.3 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4072, Percentage= 82, Temperature= 0.1 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4071, Percentage= 82, Temperature= -0.1 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4069, Percentage= 82, Temperature= -0.3 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4071, Percentage= 82, Temperature= -0.5 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4069, Percentage= 82, Temperature= -0.8 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4070, Percentage= 82, Temperature= -1.0 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4069, Percentage= 82, Temperature= -1.2 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4066, Percentage= 82, Temperature= -1.4 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4067, Percentage= 82, Temperature= -1.6 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4067, Percentage= 82, Temperature= -1.8 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4066, Percentage= 82, Temperature= -2.0 FLAGS REGISTER = 264 (Bin: High: 00000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4066, Percentage= 82, Temperature= -2.2 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3959, Percentage= 82, Temperature= -2.3 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4000, Percentage= 82, Temperature= -2.0 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3910, Percentage= 82, Temperature= -1.7 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3925, Percentage= 82, Temperature= -1.3 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3921, Percentage= 82, Temperature= -1.0 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3996, Percentage= 82, Temperature= -1.0 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3922, Percentage= 82, Temperature= -1.0 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3923, Percentage= 82, Temperature= -0.8 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3865, Percentage= 82, Temperature= -0.7 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3837, Percentage= 82, Temperature= -0.5 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3865, Percentage= 82, Temperature= -0.4 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3815, Percentage= 82, Temperature= -0.3 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3855, Percentage= 82, Temperature= -0.2 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3869, Percentage= 82, Temperature= -0.3 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3812, Percentage= 82, Temperature= -0.3 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3839, Percentage= 82, Temperature= -0.3 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3929, Percentage= 82, Temperature= -0.3 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3832, Percentage= 82, Temperature= -0.4 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3840, Percentage= 82, Temperature= -0.5 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3780, Percentage= 82, Temperature= -0.7 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3838, Percentage= 82, Temperature= -0.7 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3837, Percentage= 81, Temperature= -0.7 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3824, Percentage= 81, Temperature= -0.8 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3816, Percentage= 81, Temperature= -0.8 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3810, Percentage= 81, Temperature= -0.9 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3880, Percentage= 81, Temperature= -1.0 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3966, Percentage= 81, Temperature= -1.4 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4002, Percentage= 81, Temperature= -2.0 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4006, Percentage= 81, Temperature= -2.6 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4006, Percentage= 81, Temperature= -3.2 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4009, Percentage= 81, Temperature= -3.7 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4009, Percentage= 81, Temperature= -4.2 FLAGS REGISTER = 265 (Bin: High: 00000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4001, Percentage= 81, Temperature= -4.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4011, Percentage= 81, Temperature= -4.9 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4010, Percentage= 81, Temperature= -5.3 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4012, Percentage= 81, Temperature= -5.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4012, Percentage= 81, Temperature= -5.9 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 10894 (Bin: High: 00101010 Low: 10001110) FG: Voltage= 4008, Percentage= 81, Temperature= -6.2 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 10894 (Bin: High: 00101010 Low: 10001110) FG: Voltage= 4010, Percentage= 81, Temperature= -6.4 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 10894 (Bin: High: 00101010 Low: 10001110) FG: Voltage= 4011, Percentage= 81, Temperature= -6.7 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 10894 (Bin: High: 00101010 Low: 10001110) FG: Voltage= 4009, Percentage= 81, Temperature= -6.9 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4011, Percentage= 81, Temperature= -7.1 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4009, Percentage= 81, Temperature= -7.3 ------------- Percentage drop detected ------------------ FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4009, Percentage= 72, Temperature= -7.5 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4007, Percentage= 72, Temperature= -7.7 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4007, Percentage= 72, Temperature= -7.9 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4009, Percentage= 72, Temperature= -8.1 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4007, Percentage= 72, Temperature= -8.3 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4004, Percentage= 72, Temperature= -8.5 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4006, Percentage= 72, Temperature= -8.6 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4002, Percentage= 72, Temperature= -8.8 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4004, Percentage= 72, Temperature= -9.0 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4004, Percentage= 72, Temperature= -9.1 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4002, Percentage= 72, Temperature= -9.3 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4003, Percentage= 72, Temperature= -9.5 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4001, Percentage= 72, Temperature= -9.6 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3996, Percentage= 72, Temperature= -9.8 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 4000, Percentage= 72, Temperature= -9.9 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3998, Percentage= 72, Temperature= -10.0 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3993, Percentage= 72, Temperature= -10.2 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3995, Percentage= 72, Temperature= -10.4 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3995, Percentage= 72, Temperature= -10.5 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3993, Percentage= 72, Temperature= -10.6 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3994, Percentage= 71, Temperature= -10.8 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3991, Percentage= 71, Temperature= -10.9 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3992, Percentage= 71, Temperature= -11.0 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3989, Percentage= 71, Temperature= -11.2 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3986, Percentage= 71, Temperature= -11.3 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3986, Percentage= 71, Temperature= -11.5 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3984, Percentage= 71, Temperature= -11.6 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3981, Percentage= 71, Temperature= -11.7 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3969, Percentage= 71, Temperature= -11.8 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3980, Percentage= 71, Temperature= -11.9 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3977, Percentage= 71, Temperature= -12.1 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3978, Percentage= 71, Temperature= -12.2 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3976, Percentage= 71, Temperature= -12.3 FLAGS REGISTER = 16648 (Bin: High: 01000001 Low: 00001000) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3975, Percentage= 71, Temperature= -12.5 -------------- Percentage drop detected ------------------ FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3718, Percentage= 58, Temperature= -12.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3745, Percentage= 58, Temperature= -12.0 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3657, Percentage= 58, Temperature= -11.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3599, Percentage= 58, Temperature= -11.1 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3645, Percentage= 58, Temperature= -10.8 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3664, Percentage= 58, Temperature= -10.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3641, Percentage= 58, Temperature= -10.3 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3620, Percentage= 58, Temperature= -10.1 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3538, Percentage= 58, Temperature= -9.9 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3600, Percentage= 57, Temperature= -9.7 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3594, Percentage= 57, Temperature= -9.7 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3591, Percentage= 57, Temperature= -9.7 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3591, Percentage= 57, Temperature= -9.7 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3501, Percentage= 57, Temperature= -9.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3577, Percentage= 57, Temperature= -9.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3562, Percentage= 57, Temperature= -9.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3569, Percentage= 57, Temperature= -9.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3565, Percentage= 57, Temperature= -9.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3556, Percentage= 57, Temperature= -9.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3546, Percentage= 57, Temperature= -9.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3543, Percentage= 57, Temperature= -9.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3540, Percentage= 57, Temperature= -9.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3544, Percentage= 57, Temperature= -9.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3608, Percentage= 57, Temperature= -9.7 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3544, Percentage= 57, Temperature= -9.8 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3551, Percentage= 57, Temperature= -9.8 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3538, Percentage= 57, Temperature= -9.8 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3523, Percentage= 56, Temperature= -9.8 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3513, Percentage= 56, Temperature= -9.8 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3519, Percentage= 56, Temperature= -9.8 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3524, Percentage= 56, Temperature= -10.0 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3501, Percentage= 56, Temperature= -10.0 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3501, Percentage= 56, Temperature= -10.0 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3383, Percentage= 55, Temperature= -10.0 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3490, Percentage= 55, Temperature= -9.9 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3495, Percentage= 55, Temperature= -9.9 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3492, Percentage= 55, Temperature= -9.9 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3581, Percentage= 55, Temperature= -10.2 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3485, Percentage= 55, Temperature= -10.3 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3487, Percentage= 55, Temperature= -10.3 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3483, Percentage= 55, Temperature= -10.3 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3474, Percentage= 54, Temperature= -10.3 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3599, Percentage= 54, Temperature= -10.3 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3471, Percentage= 54, Temperature= -10.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3471, Percentage= 54, Temperature= -10.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3456, Percentage= 53, Temperature= -10.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3509, Percentage= 53, Temperature= -10.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3454, Percentage= 53, Temperature= -10.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3453, Percentage= 53, Temperature= -10.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3441, Percentage= 53, Temperature= -10.5 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3447, Percentage= 52, Temperature= -10.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3444, Percentage= 52, Temperature= -10.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3441, Percentage= 52, Temperature= -10.6 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3481, Percentage= 52, Temperature= -10.7 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3432, Percentage= 52, Temperature= -10.7 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3436, Percentage= 52, Temperature= -10.7 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3434, Percentage= 51, Temperature= -10.7 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3518, Percentage= 51, Temperature= -10.8 FLAGS REGISTER = 16649 (Bin: High: 01000001 Low: 00001001) STATUS REGISTER = 8846 (Bin: High: 00100010 Low: 10001110) FG: Voltage= 3430, Percentage= 51, Temperature= -10.9
STATUS REGISTER -> CONTROL_STATUS: 0x0000 FLAGS REGISTER -> Flags(): 0x06 and 0x07 VOLTAGE -> Voltage(): 0x04 and 0x05 PERCENTAGE -> StateOfCharge(): 0x1C and 0x1D TEMPERATURE -> Temperature(): 0x02 and 0x03 R_CAPACITY_U -> RemainingCapacityUnfiltered(): 0x28 and 0x29 R_CAPACITY_F -> RemainingCapacityFiltered(): 0x2A and 0x2B R_CAPACITY -> RemainingCapacity(): 0x0C and 0x0D HEALTH_STATE -> StateOfHealth(): 0x20 and 0x21 PERCENTAGE_U -> StateOfChargeUnfiltered(): 0x30 and 0x31 FC_CAPACITY_U -> FullChargeCapacityUnfiltered(): 0x2C and 0x2D FC_CAPACITY_F -> FullChargeCapacityFiltered(): 0x2E and 0x2F FC_CAPACITY -> FullChargeCapacity(): 0x0E and 0x0F FA_CAPACITY -> FullAvailableCapacity(): 0x0A and 0x0B NA_CAPACITY -> NominalAvailableCapacity(): 0x08 and 0x09 Registers were requested every 15 seconds --------------------------------------------------------------- FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3841, PERCENTAGE= 47, TEMPERATURE= -8.9 R_CAPACITY_U= 290, R_CAPACITY_F= 335, R_CAPACITY= 335, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 294 FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3850, PERCENTAGE= 47, TEMPERATURE= -9.1 R_CAPACITY_U= 289, R_CAPACITY_F= 335, R_CAPACITY= 335, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3848, PERCENTAGE= 47, TEMPERATURE= -9.2 R_CAPACITY_U= 289, R_CAPACITY_F= 335, R_CAPACITY= 335, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3850, PERCENTAGE= 47, TEMPERATURE= -9.3 R_CAPACITY_U= 289, R_CAPACITY_F= 335, R_CAPACITY= 335, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3851, PERCENTAGE= 47, TEMPERATURE= -9.3 R_CAPACITY_U= 289, R_CAPACITY_F= 335, R_CAPACITY= 335, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 BATTERY_INFO SOURCE FUEL: V= 3852, Percentage= 47, SampleCount= 1 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3852, PERCENTAGE= 47, TEMPERATURE= -9.3 R_CAPACITY_U= 289, R_CAPACITY_F= 335, R_CAPACITY= 335, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3852, PERCENTAGE= 47, TEMPERATURE= -9.4 R_CAPACITY_U= 289, R_CAPACITY_F= 335, R_CAPACITY= 335, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3852, PERCENTAGE= 47, TEMPERATURE= -9.4 R_CAPACITY_U= 289, R_CAPACITY_F= 335, R_CAPACITY= 335, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3847, PERCENTAGE= 47, TEMPERATURE= -9.4 R_CAPACITY_U= 289, R_CAPACITY_F= 335, R_CAPACITY= 335, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3852, PERCENTAGE= 47, TEMPERATURE= -9.4 R_CAPACITY_U= 289, R_CAPACITY_F= 334, R_CAPACITY= 334, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3850, PERCENTAGE= 47, TEMPERATURE= -9.5 R_CAPACITY_U= 289, R_CAPACITY_F= 334, R_CAPACITY= 334, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3849, PERCENTAGE= 47, TEMPERATURE= -9.5 R_CAPACITY_U= 289, R_CAPACITY_F= 334, R_CAPACITY= 334, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3848, PERCENTAGE= 47, TEMPERATURE= -9.5 R_CAPACITY_U= 289, R_CAPACITY_F= 334, R_CAPACITY= 334, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3853, PERCENTAGE= 47, TEMPERATURE= -9.5 R_CAPACITY_U= 289, R_CAPACITY_F= 334, R_CAPACITY= 334, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3852, PERCENTAGE= 47, TEMPERATURE= -9.6 R_CAPACITY_U= 289, R_CAPACITY_F= 334, R_CAPACITY= 334, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 293 BATTERY_INFO SOURCE FUEL: V= 3852, Percentage= 47, SampleCount= 1 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3843, PERCENTAGE= 47, TEMPERATURE= -9.6 R_CAPACITY_U= 288, R_CAPACITY_F= 334, R_CAPACITY= 334, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 292 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3846, PERCENTAGE= 47, TEMPERATURE= -9.6 R_CAPACITY_U= 288, R_CAPACITY_F= 334, R_CAPACITY= 334, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 292 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3851, PERCENTAGE= 47, TEMPERATURE= -9.6 R_CAPACITY_U= 288, R_CAPACITY_F= 334, R_CAPACITY= 334, HEALTH_STATE= 550, PERCENTAGE_U= 52 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 566, NA_CAPACITY= 292 --------------------------- Transefer enable using GSM module -------------------------- FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3489, PERCENTAGE= 0, TEMPERATURE= -5.9 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3486, PERCENTAGE= 0, TEMPERATURE= -4.8 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 --------------------------- Transefer disble -------------------------- FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3736, PERCENTAGE= 0, TEMPERATURE= -5.0 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3829, PERCENTAGE= 0, TEMPERATURE= -6.3 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3825, PERCENTAGE= 0, TEMPERATURE= -7.2 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 BATTERY_INFO SOURCE FUEL: V= 3835, Percentage= 0, SampleCount= 1 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3836, PERCENTAGE= 0, TEMPERATURE= -7.7 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3813, PERCENTAGE= 0, TEMPERATURE= -8.1 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3839, PERCENTAGE= 0, TEMPERATURE= -8.3 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3801, PERCENTAGE= 0, TEMPERATURE= -8.5 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3841, PERCENTAGE= 0, TEMPERATURE= -8.6 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3841, PERCENTAGE= 0, TEMPERATURE= -8.7 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3843, PERCENTAGE= 0, TEMPERATURE= -8.9 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3832, PERCENTAGE= 0, TEMPERATURE= -8.9 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3844, PERCENTAGE= 0, TEMPERATURE= -9.0 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3842, PERCENTAGE= 0, TEMPERATURE= -9.1 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 BATTERY_INFO SOURCE FUEL: V= 3843, Percentage= 0, SampleCount= 1 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3844, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3841, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3843, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3844, PERCENTAGE= 0, TEMPERATURE= -9.3 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3846, PERCENTAGE= 0, TEMPERATURE= -9.3 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3845, PERCENTAGE= 0, TEMPERATURE= -9.3 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3842, PERCENTAGE= 0, TEMPERATURE= -9.3 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 0 FC_CAPACITY_U= 562, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 567, NA_CAPACITY= 5 --------------------------- Transefer enable using GSM module -------------------------- FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3663, PERCENTAGE= 0, TEMPERATURE= -9.3 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 12 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 36 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3822, PERCENTAGE= 0, TEMPERATURE= -8.5 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 12 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 36 --------------------------- Transefer disble -------------------------- FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3838, PERCENTAGE= 0, TEMPERATURE= -8.7 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 12 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 36 BATTERY_INFO SOURCE FUEL: V= 3842, Percentage= 0, SampleCount= 1 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3842, PERCENTAGE= 0, TEMPERATURE= -8.8 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 12 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 36 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3844, PERCENTAGE= 0, TEMPERATURE= -9.0 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 12 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 36 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3844, PERCENTAGE= 0, TEMPERATURE= -9.1 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 12 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 36 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3844, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 12 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 36 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3838, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 12 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 36 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3845, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 12 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 36 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3829, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 12 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 36 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3845, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 29, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 11 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 35 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3844, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 29, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 11 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 35 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3846, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 29, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 11 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 35 BATTERY_INFO SOURCE FUEL: V= 3843, Percentage= 0, SampleCount= 1 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3843, PERCENTAGE= 0, TEMPERATURE= -9.2 R_CAPACITY_U= 29, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 11 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 35 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3843, PERCENTAGE= 0, TEMPERATURE= -9.3 R_CAPACITY_U= 29, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 11 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 35 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3846, PERCENTAGE= 0, TEMPERATURE= -9.3 R_CAPACITY_U= 29, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 11 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 35 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8328 (Bin: High: 00100000, Low: 10001000) VOLTAGE= 3847, PERCENTAGE= 0, TEMPERATURE= -9.3 R_CAPACITY_U= 29, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 550, PERCENTAGE_U= 11 FC_CAPACITY_U= 270, FC_CAPACITY_F= 724, FC_CAPACITY= 724, FA_CAPACITY= 276, NA_CAPACITY= 35
STATUS REGISTER -> CONTROL_STATUS: 0x0000 FLAGS REGISTER -> Flags(): 0x06 and 0x07 VOLTAGE -> Voltage(): 0x04 and 0x05 PERCENTAGE -> StateOfCharge(): 0x1C and 0x1D TEMPERATURE -> Temperature(): 0x02 and 0x03 R_CAPACITY_U -> RemainingCapacityUnfiltered(): 0x28 and 0x29 R_CAPACITY_F -> RemainingCapacityFiltered(): 0x2A and 0x2B R_CAPACITY -> RemainingCapacity(): 0x0C and 0x0D HEALTH_STATE -> StateOfHealth(): 0x20 and 0x21 PERCENTAGE_U -> StateOfChargeUnfiltered(): 0x30 and 0x31 FC_CAPACITY_U -> FullChargeCapacityUnfiltered(): 0x2C and 0x2D FC_CAPACITY_F -> FullChargeCapacityFiltered(): 0x2E and 0x2F FC_CAPACITY -> FullChargeCapacity(): 0x0E and 0x0F FA_CAPACITY -> FullAvailableCapacity(): 0x0A and 0x0B NA_CAPACITY -> NominalAvailableCapacity(): 0x08 and 0x09 Registers were requested every 15 seconds --------------------------------------------------------------- FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3860, PERCENTAGE= 61, TEMPERATURE= -8.8 R_CAPACITY_U= 318, R_CAPACITY_F= 355, R_CAPACITY= 355, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 577 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3857, PERCENTAGE= 61, TEMPERATURE= -8.9 R_CAPACITY_U= 318, R_CAPACITY_F= 355, R_CAPACITY= 355, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 577 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3858, PERCENTAGE= 61, TEMPERATURE= -8.9 R_CAPACITY_U= 318, R_CAPACITY_F= 355, R_CAPACITY= 355, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 577 FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3736, PERCENTAGE= 61, TEMPERATURE= -8.9 R_CAPACITY_U= 318, R_CAPACITY_F= 355, R_CAPACITY= 355, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 577 FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3701, PERCENTAGE= 61, TEMPERATURE= -8.8 R_CAPACITY_U= 318, R_CAPACITY_F= 355, R_CAPACITY= 355, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 577 FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3698, PERCENTAGE= 61, TEMPERATURE= -8.7 R_CAPACITY_U= 318, R_CAPACITY_F= 355, R_CAPACITY= 355, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 577 (String) --------------------------- Transefer enable using GSM module -------------------------- FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3601, PERCENTAGE= 61, TEMPERATURE= -8.1 R_CAPACITY_U= 318, R_CAPACITY_F= 355, R_CAPACITY= 355, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 577 (String) FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3797, PERCENTAGE= 61, TEMPERATURE= -7.5 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 (String) --------------------------- Transefer disble -------------------------- FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3820, PERCENTAGE= 61, TEMPERATURE= -7.5 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3841, PERCENTAGE= 61, TEMPERATURE= -7.7 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3846, PERCENTAGE= 61, TEMPERATURE= -8.0 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3848, PERCENTAGE= 61, TEMPERATURE= -8.2 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3850, PERCENTAGE= 61, TEMPERATURE= -8.3 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16649 (Bin: High: 01000001, Low: 00001001) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3849, PERCENTAGE= 61, TEMPERATURE= -8.4 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3848, PERCENTAGE= 61, TEMPERATURE= -8.4 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3852, PERCENTAGE= 61, TEMPERATURE= -8.5 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3850, PERCENTAGE= 61, TEMPERATURE= -8.6 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3853, PERCENTAGE= 61, TEMPERATURE= -8.6 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3854, PERCENTAGE= 61, TEMPERATURE= -8.6 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3852, PERCENTAGE= 61, TEMPERATURE= -8.7 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 (String) FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3854, PERCENTAGE= 61, TEMPERATURE= -8.7 R_CAPACITY_U= 317, R_CAPACITY_F= 354, R_CAPACITY= 354, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 (String) FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3849, PERCENTAGE= 61, TEMPERATURE= -8.7 R_CAPACITY_U= 317, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 (String) FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3854, PERCENTAGE= 61, TEMPERATURE= -8.7 R_CAPACITY_U= 317, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3854, PERCENTAGE= 61, TEMPERATURE= -8.8 R_CAPACITY_U= 317, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3855, PERCENTAGE= 61, TEMPERATURE= -8.8 R_CAPACITY_U= 317, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 576 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3855, PERCENTAGE= 61, TEMPERATURE= -8.8 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3855, PERCENTAGE= 61, TEMPERATURE= -8.8 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3852, PERCENTAGE= 61, TEMPERATURE= -8.8 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3854, PERCENTAGE= 61, TEMPERATURE= -8.8 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3855, PERCENTAGE= 61, TEMPERATURE= -8.9 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3851, PERCENTAGE= 61, TEMPERATURE= -8.8 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3855, PERCENTAGE= 61, TEMPERATURE= -8.9 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3856, PERCENTAGE= 61, TEMPERATURE= -8.9 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3854, PERCENTAGE= 61, TEMPERATURE= -8.9 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3853, PERCENTAGE= 61, TEMPERATURE= -8.9 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3855, PERCENTAGE= 61, TEMPERATURE= -9.0 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 (String) --------------------------- Transefer enable using GSM module -------------------------- FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3854, PERCENTAGE= 61, TEMPERATURE= -9.0 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 BATTERY_INFO SOURCE FUEL: V= 3855, Percentage= 61, SampleCount= 20 FLAGS REGISTER= 16648 (Bin: High: 01000001, Low: 00001000) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3855, PERCENTAGE= 61, TEMPERATURE= -9.0 R_CAPACITY_U= 316, R_CAPACITY_F= 353, R_CAPACITY= 353, HEALTH_STATE= 340, PERCENTAGE_U= 62 FC_CAPACITY_U= 516, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 775, NA_CAPACITY= 575 DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3317, PERCENTAGE= 0, TEMPERATURE= -2.9 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3297, PERCENTAGE= 0, TEMPERATURE= -1.7 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 (String) FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3333, PERCENTAGE= 0, TEMPERATURE= -0.9 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 --------------------------- Transefer disble -------------------------- FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3699, PERCENTAGE= 0, TEMPERATURE= -2.1 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3806, PERCENTAGE= 0, TEMPERATURE= -3.6 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3823, PERCENTAGE= 0, TEMPERATURE= -4.6 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3825, PERCENTAGE= 0, TEMPERATURE= -5.4 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3835, PERCENTAGE= 0, TEMPERATURE= -6.0 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3838, PERCENTAGE= 0, TEMPERATURE= -6.3 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 (String) FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3841, PERCENTAGE= 0, TEMPERATURE= -6.6 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 (String) FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3844, PERCENTAGE= 0, TEMPERATURE= -7.0 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 (String) FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3846, PERCENTAGE= 0, TEMPERATURE= -7.1 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3845, PERCENTAGE= 0, TEMPERATURE= -7.3 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3850, PERCENTAGE= 0, TEMPERATURE= -7.4 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3851, PERCENTAGE= 0, TEMPERATURE= -7.5 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3853, PERCENTAGE= 0, TEMPERATURE= -7.6 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3854, PERCENTAGE= 0, TEMPERATURE= -7.7 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3855, PERCENTAGE= 0, TEMPERATURE= -7.7 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3854, PERCENTAGE= 0, TEMPERATURE= -7.8 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3855, PERCENTAGE= 0, TEMPERATURE= -7.8 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3853, PERCENTAGE= 0, TEMPERATURE= -7.8 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3858, PERCENTAGE= 0, TEMPERATURE= -7.9 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3858, PERCENTAGE= 0, TEMPERATURE= -7.9 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 (String) FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3831, PERCENTAGE= 0, TEMPERATURE= -7.9 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3852, PERCENTAGE= 0, TEMPERATURE= -7.9 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 (String) FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3859, PERCENTAGE= 0, TEMPERATURE= -7.9 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 BATTERY_INFO SOURCE FUEL: V= 3859, Percentage= 0, SampleCount= 20 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3859, PERCENTAGE= 0, TEMPERATURE= -8.0 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3858, PERCENTAGE= 0, TEMPERATURE= -8.0 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3858, PERCENTAGE= 0, TEMPERATURE= -8.1 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3860, PERCENTAGE= 0, TEMPERATURE= -8.1 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3861, PERCENTAGE= 0, TEMPERATURE= -8.1 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3862, PERCENTAGE= 0, TEMPERATURE= -8.2 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 --------------------------- Transefer enable using GSM module -------------------------- FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3861, PERCENTAGE= 0, TEMPERATURE= -8.2 R_CAPACITY_U= 0, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 0 FC_CAPACITY_U= 202, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 770, NA_CAPACITY= 568 (String) FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3749, PERCENTAGE= 0, TEMPERATURE= -7.4 R_CAPACITY_U= 31, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 14 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 562 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3775, PERCENTAGE= 0, TEMPERATURE= -7.2 R_CAPACITY_U= 31, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 14 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 562 --------------------------- Transefer disble -------------------------- FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3847, PERCENTAGE= 0, TEMPERATURE= -7.4 R_CAPACITY_U= 31, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 14 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 562 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3853, PERCENTAGE= 0, TEMPERATURE= -7.6 R_CAPACITY_U= 31, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 14 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 562 FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3850, PERCENTAGE= 0, TEMPERATURE= -7.7 R_CAPACITY_U= 31, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 14 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 562 (String) FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3856, PERCENTAGE= 0, TEMPERATURE= -7.8 R_CAPACITY_U= 31, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 14 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 562 (String) FLAGS REGISTER= 16655 (Bin: High: 01000001, Low: 00001111) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3854, PERCENTAGE= 0, TEMPERATURE= -7.9 R_CAPACITY_U= 31, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 14 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 562 (String) FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3855, PERCENTAGE= 0, TEMPERATURE= -8.0 R_CAPACITY_U= 31, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 14 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 562 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3858, PERCENTAGE= 0, TEMPERATURE= -8.0 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 13 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 561 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3859, PERCENTAGE= 0, TEMPERATURE= -8.0 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 13 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 561 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3858, PERCENTAGE= 0, TEMPERATURE= -8.1 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 13 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 561 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3860, PERCENTAGE= 0, TEMPERATURE= -8.1 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 13 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 561 FLAGS REGISTER= 16654 (Bin: High: 01000001, Low: 00001110) STATUS REGISTER= 8334 (Bin: High: 00100000, Low: 10001110) DESIGN_CAPACITY= 810, DESIGN_ENERGY= 3078, TERMINATE_VOLTAGE= 3520, HIBERNATE_I= 0, HIBERNATE_V= 3000 VOLTAGE= 3860, PERCENTAGE= 0, TEMPERATURE= -8.2 R_CAPACITY_U= 30, R_CAPACITY_F= 0, R_CAPACITY= 0, HEALTH_STATE= 340, PERCENTAGE_U= 13 FC_CAPACITY_U= 237, FC_CAPACITY_F= 587, FC_CAPACITY= 587, FA_CAPACITY= 768, NA_CAPACITY= 561
What other main config value should we use? Give a recommendation for us.
Michael
