Other Parts Discussed in Thread: BQ79616
Hi Team,
Can you please advise with following request:
1- An IC that can be added back to back when Bq79616 is used in series; We want to increase the battery capacity by parallelizing. We will use the bq79616 COML communication link for the procedure. Does the IC have any limitations for parallel communication when more than one IC (ranging from 10-30) is connected via a parallel COML link?
2- When we want to reach high voltages with serial connection, we want to use ring topology to make the communication more robust. This topology still uses the "bq79600- communication extender" IC of TI. Is there a more cost-effective solution that we can use with ring topology?
Thanks in advance
Best Regards
Furkan Sefiloglu
