Hello, I want to design a solar/usb powered battery charger for a pack of 4 NiMh AA batteries in series.
I've read from various posts that the inconsistent current from solar panels will make end of charge detection difficult, so i was thinking of a design where the solar can be used to trickle charge the batteries (meaning the peak current of the solar cell will be withing a safe trickle charge current of the battery) and a usb to fast charge the batteries.
My questions are:
1. What is the best solution for this application?
2. If i'm using the bq2000 series chips to charge the 4 batteries in series what minimum voltage across the batteries will i need to ensure proper charging? I'm not too clear about this part from the datasheets.
