I installed bqStudio on an XP laptop without a problem but when I try to run it I get the error log below. We are more a Linux shop and don't have much XP expertise. I would appreciate if you can have any pointers.
Sinan Akman
java.lang.UnsatisfiedLinkError: C:\ti\BatteryManagementStudio\sdkjniadapter.dll:
This application has failed to start because the application configuration is i
ncorrect. Reinstalling the application may fix this problem
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at toolsSDK.JNIWrappers.SDKLib.<clinit>(Unknown Source)
at com.ti.evswsdk.communication.connection.CMConnection.<init>(Unknown S
ource)
at com.ti.evswsdk.communication.connection.CMConnection.getInstance(Unkn
own Source)
at com.ti.evswsdk.ApplicationWorkbenchWindowAdvisor.preWindowOpen(Unknow
n Source)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpening(WorkbenchWi
ndow.java:1654)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:65
4)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequest
or.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(Injecto
rImpl.java:898)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java
:121)
:86)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextIn
jectionFactory.java:73)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.jav
a:1526)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.
java:1500)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActive
Shell(WorkbenchSourceProvider.java:944)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentSt
ate(WorkbenchSourceProvider.java:138)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEven
t(WorkbenchSourceProvider.java:704)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1266)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1112)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1137)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1122)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1673
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2193)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4673)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:339)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1633)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2117)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5050)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:230)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1244)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBW
Renderer.java:694)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCrea
teGui(PartRenderingEngine.java:658)
teGui(PartRenderingEngine.java:746)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0
(PartRenderingEngine.java:717)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(Pa
rtRenderingEngine.java:711)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGu
i(PartRenderingEngine.java:695)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(Pa
rtRenderingEngine.java:1057)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.ja
va:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(Part
RenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Wor
kbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
va:337)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.jav
a:606)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at com.ti.evswsdk.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandl
e.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli
cation(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec
lipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja
va:380)
va:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
!ENTRY org.eclipse.osgi 4 0 2016-05-04 13:06:56.613
!MESSAGE Application error
!STACK 1
ource)
own Source)
n Source)
ndow.java:1654)
4)
or.java:56)
rImpl.java:898)
:121)
:86)
a:1526)
java:1500)
Renderer.java:694)
va:337)
kbench.java:156)
va:337)
a:606)
e.java:196)
va:380)
va:235)
!ENTRY com.ti.evswsdk 4 0 2016-05-04 13:06:56.707
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in com.ti.evswsdk.Activator.stop()
of bundle com.ti.evswsdk.
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleCont
extImpl.java:847)
at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(Equinox
Bundle.java:955)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopW
orker(EquinoxBundle.java:323)
at org.eclipse.osgi.container.Module.doStop(Module.java:626)
at org.eclipse.osgi.container.Module.stop(Module.java:488)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decSta
rtLevel(ModuleContainer.java:1623)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doCont
ainerStartLevel(ModuleContainer.java:1542)
at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:
248)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$Equino
xSystemModule.stopWorker(EquinoxBundle.java:144)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:186)
xSystemModule$1.run(EquinoxBundle.java:159)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class toolsSDK.J
NIWrappers.SDKLib
at com.ti.evswsdk.Activator.stop(Unknown Source)
at org.eclipse.osgi.internal.framework.BundleContextImpl$4.run(BundleCon
textImpl.java:827)
textImpl.java:1)
at java.security.AccessController.doPrivileged(Native Method)
extImpl.java:820)
... 13 more
Root exception:
java.lang.NoClassDefFoundError: Could not initialize class toolsSDK.JNIWrappers.
SDKLib
textImpl.java:827)
textImpl.java:1)
extImpl.java:820)
Bundle.java:955)
248)
!SESSION 2016-05-04 13:07:51.738 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_74
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2016-05-04 13:07:54.863
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.w
orkbench.swt".
!STACK 0
ource)
own Source)
n Source)
ndow.java:1654)
4)
or.java:56)
rImpl.java:898)
:121)
:86)
a:1526)
java:1500)
Renderer.java:694)
va:337)
kbench.java:156)
va:337)
a:606)
e.java:196)
va:380)
va:235)
!ENTRY org.eclipse.osgi 4 0 2016-05-04 13:07:54.910
!STACK 1
ource)
own Source)
n Source)
ndow.java:1654)
4)
or.java:56)
rImpl.java:898)
:121)
:86)
a:1526)
java:1500)
Renderer.java:694)
va:337)
kbench.java:156)
va:337)
a:606)
e.java:196)
va:380)
va:235)
!ENTRY com.ti.evswsdk 4 0 2016-05-04 13:07:54.941
!STACK 0
extImpl.java:847)
Bundle.java:955)
248)
NIWrappers.SDKLib
textImpl.java:827)
textImpl.java:1)
extImpl.java:820)
... 13 more
Root exception:
SDKLib
textImpl.java:827)
textImpl.java:1)
extImpl.java:820)
Bundle.java:955)
248)
at java.lang.Thread.run(Unknown Source) -------------------------------------------------------------------------------------------------------------------------------------------
