Other Parts Discussed in Thread: BQ28Z610
I am trying to configure the BQ28Z610 through I2C using an external MCU.
I used this example to write a code that writes in the flash memory at the address 0x469B to write the value 0x10 (such that the BQ will be configured for 1 cell): https://e2e.ti.com/support/power-management/f/196/t/632332?BQ28Z610-I-can-t-write-Data-Flash but there is no change in the configuration. Also I saw in the technical guide that MACData(), MACDataChecksum() and 0x61 MACDataLength() are read only, so how can I write in those registers?
Can someone help me with an example specific to this configuration change, it would help a lot.
Thank you!
