Hi Expert,
I want to double confirm PWRON pin setting.
I want to power on my device when PWRHOLD pin pull high without press power button .
BOOT1 = VRTC (High, or 1)
BOOT0 = GND (Low, or 0)
Could I set PWRON pin floating?
Daniel
Hi Expert,
Daniel
Hi, Daniel,
PWRON pin has a pull-up control bit PWRONP which is PUADEN_REG bit4; it's 1 by default which means "Pull-up is enabled". if you don't change it to 0, the PWRON pin can be floating. If you want to have a stronger pull-up, you can still use an external resistor to pull it up.
