Hi team,
My customer is considering to use the TPS54202.
According to the block diagram in the d/s, the EN-pin is connected to a current source. What voltage is the current source connected internally?
Yamaguchi
Hi team,
Yamaguchi
Hi Young-san,
Thank you for your support.
The customer is thinking to control the EN-pin directly by controller IC like MCU. The controller IC I/O is 3.3V, and abs max of the I/O-pin is 4.6V. Therefore, customer is concerned about the voltage from EN-pin being applied to the I/O-pin and exceed the 4.6V. Therefore, customer would like to know what voltage is the current source connected internally.
Yamaguchi
and Hi ,
EN pin is a input pin for this device with large internal resistance.
It is no problem for EN pin connected with external voltage controller , and suggest to put a resister in series .
BRs,
Young
Hi Young-san,
Thank you for the answer.
Could you tell me why does it require a resistor in series? Also, could you tell me the recommended resistance?
Yamaguchi
Hi Yamaguchi,
A resistor in series is for current limiting , and one 10K ohm is recommended .
BRs,
Young
