I plan to use the TPS65910 for AM335x.
The TPS65910 will supply power the AM335x and LTE modules.
There is an important point when turning off the power in my application.
If a power switch is pressed, the LTE module is turned off first and then all power is turned off.
But I think the LTE module can be turned off first.
After the switch is pressed, Can the AM335x turn off the LTE module first and then make all powers off?
When the switch is pressed, does all the power immediately turn off?
Best regards
