Other Parts Discussed in Thread: TLC5944,
Hi team,
Can you answer the following customer question please?
Unfortunately, the data sheet of the TLC5940 does not provide very detailed information about the Power-ON behavior. For the TLC5944 I found the following passage in the Grayscale (GS) Shift Register and Data Latch section, which seems to be valid for the TLC5940 as well, since the power-on behavior of both devices is identical.
Could you please confirm that this statement also applies to the TLC5940 in terms of content?
Thank you,
Franz
