Hello Team,
Can you check whether the schematic connections are correct in the attached screenshot.
Thanks & Regards,
Siburaj D.S.
Hello Team,
Thanks & Regards,
Siburaj D.S.
Hi Ricardo,
Can you help me to solve below queries.
1. When testing in one of the boards in default mode (without microcontroller) STAT output is continuously low, without connecting battery.
Thanks & Regards,
Siburaj D.S.
Siburaj,
I would expect to see STAT blink and the BAT capacitors are charged and discharged. It may be possible D27 is conducting. What is the voltage on the BAT pin? What happens if you remove D27?
Ricardo
