Hi there, I am using the BQ40Z60 integrated in a board based off the EVM schematic.
In trying to identify the correct chem ID, I am carrying out a charge-relax-discharge-relax cycle.
I have configured the chip to use 4 cells as I am using a 4 cell LiPo. A 19V V_AC supply is used.
When enabling the FETs and charge, the battery begins to charge at the prescribed 1000 mA current, but as it approaches max voltage of 4.2V per cell, there is no tapering of the charge current and it ends up exceeding the max voltage before I manually disable the charge.
I note that charge voltage says 16400mV in the register, but the actually voltage ramps up past 16.8V as the battery is charged fully
Is there an obvious misconfiguration here?
Thu Apr 15 16:53:24 NZST 2021 Device Version Info = 4600_0_15 BQZ Device Name = bq40z60 BQZ Firmware Version = V0_15_BLD21 Design Capacity = 4000 Design Voltage = 14400 Specification Info = 0x0031 Manufacturer Date = 1980-1-1 Serial Number = 0x0001 Manufacturer Name = Texas Instruments Device Name = bq40z60 Device Chemistry = LION Sample,DateTime,ElapsedTime,ManufAccess,RemCapAlarm,RemTimeAlarm,BattMode,@Rate(@),@TimeFull,@TimeEmpty,@RateOK,Temperature,Voltage,Current,AvgCurr,MaxErr,RSOC,ASOC,RemCap,FullChgCap,RunTimeEmty,RunTimeEmty,AvgTimeFull,ChgCurr,ChgVolt,BattStat,CycleCnt,TurboPwr,TurboCurr,SoH,OpStatA,OpStatB,TempRange,ChgStat,ChgrStat,GaugeStat,ITStat,MfgStat,SafetyAlertAB,SafetyStatAB,SafetyAlertCD,SafetyStatCD,PFAlertAB,PFStatAB,PFAlertCD,PFStatCD,CellVolt1,CellVolt2,CellVolt3,CellVolt4,vBAT,Vacp,CellCurr1,CellCurr2,CellCurr3,CellCurr4,CellPower1,CellPower2,CellPower3,CellPower4,Power,AvgPow,IntTemp,TS1Temp,TS2Temp,TS3Temp,TS4Temp,CellTemp,FETTemp,FltRemQ,FltRemE,FltFullChgQ,FltFullChgE,TrueRemQ,TrueRemE,InitialQ,InitialE,TrueFullChgQ,TrueFullChgE,T_sim,T_ambient,RaScale1,RaScale2,RaScale3,RaScale4,CompRes1,CompRes2,CompRes3,CompRes4,PackGrid,LStatus,CellGrid1,CellGrid2,CellGrid3,CellGrid4,StateTime,DOD0_1,DOD0_2,DOD0_3,DOD0_4,DOD0 Passed Q,DOD0 Passed E,DOD0 Time,DODEOC_1,DODEOC_2,DODEOC_3,DODEOC_4,QMax1,QMax2,QMax3,QMax4,QMaxDOD0_1,QMaxDOD0_2,QMaxDOD0_3,QMaxDOD0_4,QMaxPassedQ,QMaxTime,Tk,Ta,RawDOD_1,RawDOD_2,RawDOD_3,RawDOD_4,CBTime1,CBTime2,CBTime3,CBTime4,CBDOD_1,CBDOD_2,CBDOD_3,CBDOD_4,CBTotalDODChg,SOH_FC_Q,SOH_FC_E,ChgVoltReg,ChgCurrReg,LogRowTime(ms),LogStatus 1,2021-04-15 16:53:28,4.000,0x01C7,300,10,0x0081,0,65535,65535,1,20.7,16311,172,172,100,100,81,3240,3240,9720,657,65535,800,16400,0x40C0,0,-19582,-14789,83,0x0197,0x0000,0x08,0x0008,0x0001,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4089,4077,4078,4088,16357,17816,818,824,824,820,334,336,336,335,981,281,24.8,20.9,20.4,20.7,20.7,20.7,24.6,3258,4737,3240,4708,3258,4737,-66,-107,3240,4708,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,0,2768,2624,2608,2736,48,78,0,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,48,0,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1005,SUCCESS 2,2021-04-15 16:53:32,8.001,0x0197,300,10,0x0081,0,65535,65535,1,20.8,16336,835,330,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19606,-14787,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4091,4078,4079,4089,16365,17810,836,836,834,832,342,341,340,340,1364,540,27.9,20.9,20.5,20.7,20.7,20.7,27.9,3258,4740,3239,4709,3258,4740,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,5,2768,2624,2608,2736,47,76,0,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,47,0,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1116,SUCCESS 3,2021-04-15 16:53:36,12.001,0x0197,300,10,0x0081,0,65535,65535,1,20.8,16341,834,452,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19612,-14787,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4092,4079,4080,4090,16367,17810,835,836,833,833,342,341,340,341,1363,738,28.5,20.9,20.5,20.8,20.7,20.8,28.5,3259,4741,3239,4709,3259,4741,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,9,2768,2624,2608,2736,46,75,0,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,46,0,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1059,SUCCESS 4,2021-04-15 16:53:40,16.002,0x0197,300,10,0x0081,0,65535,65535,1,20.9,16345,834,544,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19612,-14787,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4093,4080,4081,4091,16371,17808,835,834,834,833,342,340,340,341,1363,888,28.9,20.9,20.4,20.8,20.7,20.8,28.9,3260,4743,3239,4709,3260,4743,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,13,2768,2624,2608,2736,45,73,0,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,45,0,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1066,SUCCESS 5,2021-04-15 16:53:44,20.002,0x0197,300,10,0x0081,0,65535,65535,1,20.8,16349,833,613,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19612,-14787,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4094,4081,4082,4092,16374,17810,836,833,833,830,342,340,340,340,1364,1002,29.3,20.9,20.4,20.8,20.7,20.8,29.3,3261,4744,3239,4709,3261,4744,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,17,2768,2624,2608,2736,44,72,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,44,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1134,SUCCESS 6,2021-04-15 16:53:48,24.003,0x0197,300,10,0x0081,0,65535,65535,1,20.8,16352,834,666,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19618,-14787,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4082,4083,4093,16377,17809,834,835,834,831,342,341,341,340,1364,1089,29.5,20.9,20.5,20.8,20.7,20.8,29.5,3262,4746,3239,4709,3262,4746,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,21,2768,2624,2608,2736,43,70,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,43,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1099,SUCCESS 7,2021-04-15 16:53:52,28.003,0x0197,300,10,0x0081,0,65535,65535,1,20.8,16355,834,707,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19621,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4083,4083,4093,16382,17808,834,833,835,830,342,340,341,340,1362,1155,29.7,20.9,20.5,20.7,20.7,20.7,29.7,3262,4746,3239,4709,3262,4746,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,24,2768,2624,2608,2736,43,70,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,42,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1082,SUCCESS 8,2021-04-15 16:53:56,32.004,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16358,834,737,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19609,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4096,4083,4084,4094,16383,17810,834,836,834,830,342,341,341,340,1364,1205,29.9,20.9,20.4,20.6,20.7,20.7,29.9,3263,4747,3239,4709,3263,4747,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,29,2768,2624,2608,2736,42,69,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,42,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1081,SUCCESS 9,2021-04-15 16:54:00,36.004,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16360,834,761,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19609,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4096,4084,4085,4095,16383,17810,834,832,833,831,342,340,340,340,1364,1244,30.0,20.9,20.4,20.5,20.7,20.7,30.0,3264,4749,3239,4709,3264,4749,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,33,2768,2624,2608,2736,41,67,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,41,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1147,SUCCESS 10,2021-04-15 16:54:04,40.005,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16363,834,778,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19615,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4097,4084,4085,4095,16386,17810,833,835,833,830,341,341,340,340,1365,1273,30.1,20.9,20.4,20.6,20.7,20.7,30.1,3265,4750,3239,4709,3265,4750,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,36,2768,2624,2608,2736,40,66,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,40,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1070,SUCCESS 11,2021-04-15 16:54:08,44.005,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16364,834,792,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19615,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4085,4086,4096,16389,17811,834,834,833,830,342,341,340,340,1365,1295,30.2,20.9,20.4,20.6,20.7,20.7,30.2,3266,4752,3239,4709,3266,4752,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,41,2768,2624,2608,2736,39,64,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,39,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1063,SUCCESS 12,2021-04-15 16:54:12,48.006,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16367,835,802,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19615,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4085,4086,4096,16389,17812,834,834,833,831,342,341,340,340,1365,1312,30.3,20.9,20.5,20.7,20.7,20.7,30.3,3267,4754,3239,4709,3267,4754,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,45,2768,2624,2608,2736,38,62,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,38,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1080,SUCCESS 13,2021-04-15 16:54:16,52.006,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16369,834,810,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19615,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4086,4087,4097,16393,17812,835,834,834,832,342,341,341,341,1367,1325,30.4,20.9,20.3,20.4,20.7,20.7,30.4,3268,4755,3239,4709,3268,4755,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,49,2768,2624,2608,2736,37,61,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,37,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1125,SUCCESS 14,2021-04-15 16:54:20,56.007,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16371,835,816,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19620,-14792,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4099,4087,4087,4097,16394,17811,835,834,834,832,342,341,341,341,1367,1335,30.5,20.9,20.3,20.6,20.7,20.7,30.5,3269,4757,3239,4709,3269,4757,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,52,2768,2624,2608,2736,36,59,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,36,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1096,SUCCESS 15,2021-04-15 16:54:24,60.007,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16372,835,820,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19621,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4087,4088,4098,16396,17810,835,834,834,832,342,341,341,341,1367,1342,30.5,20.9,20.3,20.6,20.7,20.7,30.5,3270,4758,3239,4709,3270,4758,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,56,2768,2624,2608,2736,35,58,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,35,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1129,SUCCESS 16,2021-04-15 16:54:28,64.008,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16373,835,824,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19621,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4087,4088,4098,16399,17811,834,833,835,830,342,340,341,340,1367,1348,30.5,20.9,20.4,20.7,20.7,20.7,30.5,3271,4760,3239,4709,3271,4760,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,61,2768,2624,2608,2736,34,56,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,34,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1161,SUCCESS 17,2021-04-15 16:54:32,68.008,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16375,835,826,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19621,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4088,4089,4099,16401,17810,835,834,835,832,342,341,341,341,1367,1353,30.6,20.9,20.4,20.7,20.7,20.7,30.6,3272,4761,3239,4709,3272,4761,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,64,2768,2624,2608,2736,33,55,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,33,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1097,SUCCESS 18,2021-04-15 16:54:36,72.008,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16377,835,828,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19624,-14787,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4088,4089,4099,16402,17810,836,834,837,834,343,341,342,342,1368,1356,30.6,20.9,20.4,20.6,20.7,20.7,30.6,3273,4763,3239,4709,3273,4763,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,68,2768,2624,2608,2736,32,53,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,32,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1124,SUCCESS 19,2021-04-15 16:54:40,76.009,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16379,835,830,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19624,-14787,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4089,4090,4100,16403,17813,834,834,835,833,342,341,342,342,1368,1359,30.7,20.9,20.3,20.6,20.7,20.7,30.7,3274,4764,3239,4709,3274,4764,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,72,2768,2624,2608,2736,31,52,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,31,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1141,SUCCESS 20,2021-04-15 16:54:44,80.009,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16381,835,831,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19627,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4102,4089,4090,4100,16405,17813,834,835,836,831,342,341,342,341,1368,1361,30.8,20.9,20.3,20.6,20.7,20.7,30.8,3275,4766,3239,4709,3275,4766,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,76,2768,2624,2608,2736,30,50,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,30,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1127,SUCCESS 21,2021-04-15 16:54:48,84.010,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16382,836,832,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19627,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4102,4090,4090,4100,16406,17814,836,836,834,831,343,342,341,342,1368,1363,30.7,20.9,20.2,20.5,20.7,20.7,30.7,3275,4766,3239,4709,3275,4766,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,80,2768,2624,2608,2736,30,50,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,29,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1110,SUCCESS 22,2021-04-15 16:54:52,88.010,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16384,836,833,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19627,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4090,4091,4101,16408,17813,837,836,836,833,343,342,342,342,1370,1364,30.8,20.9,20.2,20.6,20.7,20.7,30.8,3276,4768,3239,4709,3276,4768,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,84,2768,2624,2608,2736,29,48,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,29,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1051,SUCCESS 23,2021-04-15 16:54:56,92.011,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16386,835,833,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19633,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4091,4091,4101,16410,17816,836,836,836,833,343,342,342,342,1368,1365,30.8,20.9,20.3,20.7,20.7,20.7,30.8,3277,4769,3239,4709,3277,4769,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,88,2768,2624,2608,2736,28,47,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,28,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1029,SUCCESS 24,2021-04-15 16:55:00,96.011,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16387,836,834,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19633,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4091,4092,4102,16413,17815,836,836,835,833,343,342,342,342,1370,1366,30.9,20.9,20.3,20.6,20.7,20.7,30.9,3278,4771,3239,4709,3278,4771,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,92,2768,2624,2608,2736,27,45,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,27,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1012,SUCCESS 25,2021-04-15 16:55:04,100.012,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16389,836,834,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19633,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4104,4092,4092,4102,16413,17816,838,836,836,834,344,342,342,342,1370,1367,30.9,20.9,20.3,20.6,20.7,20.7,30.9,3279,4772,3239,4709,3279,4772,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,96,2768,2624,2608,2736,26,44,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,26,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1030,SUCCESS 26,2021-04-15 16:55:08,104.012,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16390,836,835,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19633,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4104,4092,4093,4102,16416,17816,837,835,836,833,344,342,342,342,1370,1368,30.9,20.9,20.2,20.6,20.7,20.7,30.9,3280,4774,3239,4709,3280,4774,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,100,2768,2624,2608,2736,25,42,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,25,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1011,SUCCESS 27,2021-04-15 16:55:12,108.013,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16392,836,835,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19639,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4104,4092,4093,4103,16417,17818,837,836,836,832,344,342,342,341,1370,1368,31.0,20.9,20.2,20.6,20.7,20.7,31.0,3281,4775,3239,4709,3281,4775,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,104,2768,2624,2608,2736,24,41,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,24,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1104,SUCCESS 28,2021-04-15 16:55:16,112.013,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16393,836,835,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19639,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4105,4093,4094,4103,16419,17818,836,837,837,833,343,343,343,342,1371,1369,31.0,20.9,20.3,20.6,20.7,20.7,31.0,3282,4777,3239,4709,3282,4777,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,108,2768,2624,2608,2736,23,39,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,23,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1107,SUCCESS 29,2021-04-15 16:55:20,116.014,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16395,836,835,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19639,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4105,4093,4094,4103,16420,17817,837,835,836,833,344,342,342,342,1371,1369,31.0,20.9,20.3,20.6,20.7,20.7,31.0,3283,4778,3239,4709,3283,4778,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,112,2768,2624,2608,2736,22,38,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,22,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1106,SUCCESS 30,2021-04-15 16:55:24,120.014,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16396,836,836,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19639,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4106,4093,4094,4104,16422,17816,837,836,837,833,344,342,343,342,1371,1370,31.1,20.9,20.3,20.6,20.7,20.7,31.1,3284,4780,3239,4709,3284,4780,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,116,2768,2624,2608,2736,21,36,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,21,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1137,SUCCESS 31,2021-04-15 16:55:28,124.015,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16398,836,836,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19645,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4106,4094,4095,4104,16422,17816,836,836,836,833,343,342,342,342,1371,1370,31.0,20.9,20.3,20.7,20.7,20.7,31.0,3285,4782,3239,4709,3285,4782,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,120,2768,2624,2608,2736,20,34,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,20,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1072,SUCCESS 32,2021-04-15 16:55:32,128.015,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16400,836,836,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19645,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4106,4094,4095,4105,16424,17818,836,836,836,833,343,342,342,342,1371,1370,31.1,20.9,20.3,20.5,20.7,20.7,31.1,3286,4783,3239,4709,3286,4783,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,124,2768,2624,2608,2736,19,33,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,19,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1074,SUCCESS 33,2021-04-15 16:55:36,132.016,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16401,836,836,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19645,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4107,4095,4095,4105,16424,17816,836,837,838,832,343,343,343,342,1371,1370,31.1,20.9,20.2,20.5,20.7,20.7,31.1,3287,4785,3239,4709,3287,4785,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,128,2768,2624,2608,2736,18,31,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,18,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1084,SUCCESS 34,2021-04-15 16:55:40,136.016,0x0197,300,10,0x0081,0,65535,65535,1,20.8,16403,836,836,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19657,-14789,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4107,4095,4096,4105,16427,17814,836,836,836,833,343,342,342,342,1371,1371,31.1,20.9,20.0,20.4,20.7,20.7,31.1,3287,4785,3239,4709,3288,4786,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,132,2768,2624,2608,2736,17,30,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,17,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1041,SUCCESS 35,2021-04-15 16:55:44,140.017,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16404,836,836,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19648,-14787,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4107,4095,4096,4106,16429,17815,836,837,836,835,343,343,342,343,1371,1371,31.2,20.9,20.1,20.5,20.7,20.7,31.1,3288,4786,3239,4709,3288,4786,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,136,2768,2624,2608,2736,17,30,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,17,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1103,SUCCESS 36,2021-04-15 16:55:48,144.017,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16405,837,836,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19654,-14787,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4108,4096,4097,4106,16429,17816,837,837,838,835,344,343,343,343,1373,1371,31.1,20.9,20.2,20.6,20.7,20.7,31.1,3289,4788,3239,4709,3289,4788,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,140,2768,2624,2608,2736,16,28,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,16,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1038,SUCCESS 37,2021-04-15 16:55:52,148.018,0x0197,300,10,0x0081,0,65535,65535,1,20.7,16407,837,836,100,100,81,3239,3239,65535,65535,0,800,16400,0x4080,0,-19654,-14787,83,0x0197,0x0000,0x08,0x0008,0x0003,0x90,0x0014,0x0418,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4108,4096,4097,4107,16432,17816,836,837,837,836,343,343,343,343,1373,1371,31.2,20.9,20.2,20.6,20.7,20.7,31.2,3290,4789,3239,4709,3290,4789,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,144,2768,2624,2608,2736,15,27,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,15,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,243,20,1117,SUCCESS 38,2021-04-15 16:55:56,152.018,0x0197,300,10,0x0081,0,65535,65535,1,20.8,16355,-20,767,100,100,81,3239,3239,9717,65535,0,800,16400,0x4080,0,-19666,-14792,83,0x01C7,0x0000,0x08,0x0008,0x0002,0x90,0x0014,0x0018,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4083,4093,4093,4086,16371,18430,-20,-19,-20,-22,-8,-8,-8,-9,-33,1258,26.2,21.0,20.3,20.6,20.8,20.8,26.3,3291,4791,3239,4709,3291,4791,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,148,2768,2624,2608,2736,14,25,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,14,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,0,0,1019,SUCCESS 39,2021-04-15 16:56:00,156.019,0x01C7,300,10,0x0081,0,65535,65535,1,20.8,16352,-19,578,100,100,81,3239,3239,10228,65535,0,800,16400,0x4080,0,-19666,-14792,83,0x01C7,0x0000,0x08,0x0008,0x0002,0x90,0x0014,0x0018,0x0000,0x0000,0x0040,0x0000,0x0000,0x0000,0x0000,0x0000,4082,4092,4093,4085,16369,18430,-20,-19,-20,-22,-8,-8,-8,-9,-33,948,24.8,21.0,20.4,20.7,20.8,20.8,24.8,3291,4791,3239,4709,3291,4791,-66,-107,3239,4709,20.7,20.6,1000,1000,1000,1000,0,0,0,0,2,4,2,2,2,2,152,2768,2624,2608,2736,14,25,1,2880,2880,2880,2880,4000,4000,4000,4000,0,0,0,0,14,1,1.0,1000,2768,2624,2608,2736,0,0,0,0,0,0,0,0,0,3309,4935,0,0,1051,SUCCESS
Fri Apr 02 11:37:46 NZDT 2021 Device Version Info = 4600_0_15 BQZ Device Name = bq40z60 BQZ Firmware Version = V0_15_BLD21 Design Capacity = 4000 Design Voltage = 12000 Specification Info = 0x0031 Manufacturer Date = 1980-1-1 Serial Number = 0x0001 Manufacturer Name = Texas Instruments Device Name = bq40z60 Device Chemistry = LION Sample,DateTime,ElapsedTime,ManufAccess,RemCapAlarm,RemTimeAlarm,BattMode,@Rate(@),@TimeFull,@TimeEmpty,@RateOK,Temperature,Voltage,Current,AvgCurr,MaxErr,RSOC,ASOC,RemCap,FullChgCap,RunTimeEmty,RunTimeEmty,AvgTimeFull,ChgCurr,ChgVolt,BattStat,CycleCnt,TurboPwr,TurboCurr,SoH,OpStatA,OpStatB,TempRange,ChgStat,ChgrStat,GaugeStat,ITStat,MfgStat,SafetyAlertAB,SafetyStatAB,SafetyAlertCD,SafetyStatCD,PFAlertAB,PFStatAB,PFAlertCD,PFStatCD,CellVolt1,CellVolt2,CellVolt3,CellVolt4,vBAT,Vacp,CellCurr1,CellCurr2,CellCurr3,CellCurr4,CellPower1,CellPower2,CellPower3,CellPower4,Power,AvgPow,IntTemp,TS1Temp,TS2Temp,TS3Temp,TS4Temp,CellTemp,FETTemp,FltRemQ,FltRemE,FltFullChgQ,FltFullChgE,TrueRemQ,TrueRemE,InitialQ,InitialE,TrueFullChgQ,TrueFullChgE,T_sim,T_ambient,RaScale1,RaScale2,RaScale3,RaScale4,CompRes1,CompRes2,CompRes3,CompRes4,PackGrid,LStatus,CellGrid1,CellGrid2,CellGrid3,CellGrid4,StateTime,DOD0_1,DOD0_2,DOD0_3,DOD0_4,DOD0 Passed Q,DOD0 Passed E,DOD0 Time,DODEOC_1,DODEOC_2,DODEOC_3,DODEOC_4,QMax1,QMax2,QMax3,QMax4,QMaxDOD0_1,QMaxDOD0_2,QMaxDOD0_3,QMaxDOD0_4,QMaxPassedQ,QMaxTime,Tk,Ta,RawDOD_1,RawDOD_2,RawDOD_3,RawDOD_4,CBTime1,CBTime2,CBTime3,CBTime4,CBDOD_1,CBDOD_2,CBDOD_3,CBDOD_4,CBTotalDODChg,SOH_FC_Q,SOH_FC_E,ChgVoltReg,ChgCurrReg,LogRowTime(ms),LogStatus 1,2021-04-02 11:37:50,4.002,0x02C7,300,10,0x6081,0,65535,65535,0,19.0,16335,136,136,100,0,0,0,3551,0,0,65535,1000,16400,0x0BD0,0,-2674,-8827,91,0x0297,0x0000,0x04,0x0008,0x0001,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4087,4083,4084,4101,16246,19435,990,998,997,997,405,407,407,409,1066,222,25.1,19.0,-53.2,-53.3,-53.3,19.0,23.4,-346,-415,3552,5236,-346,-415,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,1,16384,16384,16384,16384,210,252,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,210,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1070,SUCCESS 2,2021-04-02 11:37:54,8.002,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16361,1008,340,100,0,0,0,3552,65535,65535,668,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4088,4084,4085,4103,16253,19425,1009,1010,1010,1008,412,412,413,414,1649,557,27.7,18.9,-53.3,-53.2,-53.3,18.9,27.6,-345,-413,3552,5236,-345,-413,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,5,16384,16384,16384,16384,209,250,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,209,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1040,SUCCESS 3,2021-04-02 11:37:58,12.002,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16366,1005,500,100,0,0,0,3552,65535,65535,466,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4090,4085,4086,4105,16258,19422,1009,1010,1008,1008,413,413,412,414,1646,818,28.4,18.9,-53.3,-53.3,-53.3,18.9,28.4,-344,-412,3552,5236,-344,-412,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,9,16384,16384,16384,16384,208,249,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,208,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1133,SUCCESS 4,2021-04-02 11:38:02,16.003,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16370,1004,622,100,0,0,0,3552,65535,65535,381,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4091,4087,4088,4105,16261,19422,1007,1008,1008,1006,412,412,412,413,1645,1017,29.0,18.9,-53.3,-53.3,-53.3,18.9,29.0,-343,-411,3552,5236,-342,-410,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,13,16384,16384,16384,16384,206,247,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,206,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1085,SUCCESS 5,2021-04-02 11:38:06,20.004,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16374,1004,714,100,0,0,0,3552,65535,65535,335,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4092,4087,4088,4106,16263,19424,1007,1007,1008,1007,412,412,412,413,1644,1168,29.3,18.9,-53.3,-53.3,-53.3,18.9,29.3,-341,-409,3552,5236,-341,-409,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,17,16384,16384,16384,16384,205,246,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,205,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1101,SUCCESS 6,2021-04-02 11:38:10,24.005,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16377,1004,783,100,0,0,0,3552,65535,65535,313,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4093,4088,4089,4107,16268,19421,1006,1006,1008,1005,412,411,412,413,1644,1282,29.7,18.9,-53.3,-53.3,-53.3,18.9,29.7,-340,-407,3552,5236,-340,-407,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,20,16384,16384,16384,16384,204,244,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,204,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1081,SUCCESS 7,2021-04-02 11:38:14,28.005,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16379,1004,836,100,0,0,0,3552,65535,65535,296,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4093,4089,4090,4108,16271,19424,1008,1007,1007,1005,413,412,412,413,1645,1369,29.9,18.9,-53.3,-53.3,-53.3,18.9,29.9,-339,-406,3552,5236,-339,-406,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,25,16384,16384,16384,16384,203,243,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,203,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1114,SUCCESS 8,2021-04-02 11:38:18,32.006,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16381,1004,877,100,0,0,0,3552,65535,65535,284,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4094,4090,4091,4109,16275,19421,1007,1005,1006,1005,412,411,412,413,1645,1436,30.2,18.9,-53.3,-53.3,-53.3,18.9,30.2,-338,-405,3552,5236,-338,-405,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,28,16384,16384,16384,16384,202,242,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,202,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1114,SUCCESS 9,2021-04-02 11:38:22,36.007,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16384,1004,907,100,0,0,0,3552,65535,65535,275,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4090,4091,4109,16277,19424,1007,1008,1006,1006,412,412,412,413,1645,1486,30.3,18.9,-53.3,-53.3,-53.3,18.9,30.3,-337,-404,3552,5236,-337,-404,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,32,16384,16384,16384,16384,201,241,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,201,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1099,SUCCESS 10,2021-04-02 11:38:26,40.008,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16387,1004,931,100,0,0,0,3552,65535,65535,269,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4091,4092,4109,16277,19419,1005,1006,1006,1004,412,412,412,413,1645,1524,30.5,18.9,-53.3,-53.3,-53.3,18.9,30.5,-336,-403,3552,5236,-336,-403,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,36,16384,16384,16384,16384,200,240,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,200,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1095,SUCCESS 11,2021-04-02 11:38:30,44.008,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16389,1004,948,100,0,0,0,3552,65535,65535,265,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4091,4093,4110,16280,19420,1005,1005,1005,1005,412,411,411,413,1646,1553,30.6,18.9,-53.3,-53.3,-53.3,18.9,30.6,-335,-401,3552,5236,-335,-401,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,40,16384,16384,16384,16384,199,238,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,199,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1040,SUCCESS 12,2021-04-02 11:38:34,48.009,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16391,1004,962,100,0,0,0,3552,65535,65535,262,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4096,4092,4093,4111,16282,19417,1005,1005,1007,1005,412,411,412,413,1646,1575,30.8,18.9,-53.3,-53.3,-53.3,18.9,30.8,-334,-400,3552,5236,-334,-400,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,44,16384,16384,16384,16384,198,237,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,198,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1079,SUCCESS 13,2021-04-02 11:38:38,52.010,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16393,1004,972,100,0,0,0,3552,65535,65535,259,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4097,4093,4094,4111,16283,19420,1007,1006,1006,1004,413,412,412,413,1646,1592,30.8,18.9,-53.3,-53.3,-53.3,18.9,30.8,-332,-398,3552,5236,-332,-398,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,48,16384,16384,16384,16384,196,235,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,196,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1110,SUCCESS 14,2021-04-02 11:38:42,56.010,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16396,1004,980,100,0,0,0,3552,65535,65535,257,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4097,4093,4094,4112,16286,19420,1006,1006,1007,1006,412,412,412,414,1646,1605,30.9,18.9,-53.3,-53.3,-53.3,18.9,30.9,-331,-397,3552,5236,-331,-397,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,52,16384,16384,16384,16384,195,234,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,195,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1114,SUCCESS 15,2021-04-02 11:38:46,60.011,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16398,1004,985,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4093,4095,4112,16289,19419,1008,1006,1006,1006,413,412,412,414,1646,1615,31.1,18.9,-53.3,-53.3,-53.3,19.0,31.0,-330,-395,3552,5236,-330,-395,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,56,16384,16384,16384,16384,194,232,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,194,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1063,SUCCESS 16,2021-04-02 11:38:50,64.012,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16400,1004,990,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4094,4095,4113,16289,19416,1007,1005,1006,1005,413,411,412,413,1647,1623,31.1,18.9,-53.3,-53.3,-53.3,18.9,31.1,-329,-394,3552,5236,-329,-394,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,60,16384,16384,16384,16384,193,231,2,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,193,2,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1124,SUCCESS 17,2021-04-02 11:38:54,68.013,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16402,1004,993,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4099,4095,4096,4113,16292,19416,1008,1006,1007,1007,413,412,412,414,1647,1628,31.2,18.9,-53.3,-53.3,-53.3,18.9,31.2,-328,-393,3552,5236,-328,-393,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,64,16384,16384,16384,16384,192,230,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,192,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1097,SUCCESS 18,2021-04-02 11:38:58,72.013,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16404,1004,996,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4095,4096,4114,16295,19416,1008,1007,1006,1006,413,412,412,414,1647,1633,31.3,19.0,-53.3,-53.3,-53.3,18.9,31.3,-327,-392,3552,5236,-327,-392,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,68,16384,16384,16384,16384,191,229,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,191,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1076,SUCCESS 19,2021-04-02 11:39:02,76.014,0x0297,300,10,0x6081,0,65535,65535,1,18.9,16407,1005,998,100,0,0,0,3552,65535,65535,253,1000,16400,0x0090,0,-2400,-5580,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4096,4097,4114,16297,19419,1007,1007,1008,1006,413,412,413,414,1647,1637,31.4,19.0,-53.3,-53.3,-53.3,19.0,31.4,-326,-391,3552,5236,-326,-391,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,72,16384,16384,16384,16384,190,228,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,190,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1091,SUCCESS 20,2021-04-02 11:39:06,80.015,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16409,1005,1000,100,0,0,0,3552,65535,65535,258,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4096,4097,4115,16300,19419,1007,1007,1007,1006,413,412,413,414,1649,1639,31.4,19.0,-53.3,-53.3,-53.3,19.0,31.4,-325,-389,3552,5236,-325,-389,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,76,16384,16384,16384,16384,189,226,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,189,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1106,SUCCESS 21,2021-04-02 11:39:10,84.015,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16410,1005,1001,100,0,0,0,3552,65535,65535,258,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4097,4098,4116,16301,19419,1006,1007,1006,1007,413,413,412,414,1649,1641,31.5,19.0,-53.3,-53.3,-53.3,19.0,31.5,-324,-388,3552,5236,-324,-388,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,80,16384,16384,16384,16384,188,225,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,188,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1057,SUCCESS 22,2021-04-02 11:39:14,88.016,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16413,1004,1002,100,0,0,0,3552,65535,65535,258,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4097,4098,4116,16303,19415,1006,1006,1008,1006,413,412,413,414,1648,1643,31.5,19.0,-53.3,-53.3,-53.3,19.0,31.5,-322,-386,3552,5236,-322,-386,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,84,16384,16384,16384,16384,186,223,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,186,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1135,SUCCESS 23,2021-04-02 11:39:18,92.017,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16415,1004,1002,100,0,0,0,3552,65535,65535,258,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4102,4098,4099,4117,16304,19418,1006,1007,1007,1007,413,413,413,415,1648,1644,31.5,19.0,-53.3,-53.3,-53.2,19.0,31.5,-321,-385,3552,5236,-321,-385,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,88,16384,16384,16384,16384,185,222,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,185,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1118,SUCCESS 24,2021-04-02 11:39:22,96.018,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16416,1005,1003,100,0,0,0,3552,65535,65535,257,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4102,4098,4099,4117,16308,19418,1006,1006,1008,1006,413,412,413,414,1650,1646,31.6,19.0,-53.3,-53.3,-53.3,19.0,31.6,-320,-383,3552,5236,-320,-383,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,92,16384,16384,16384,16384,184,220,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,184,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1070,SUCCESS 25,2021-04-02 11:39:26,100.018,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16419,1004,1003,100,0,0,0,3552,65535,65535,257,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4099,4100,4118,16311,19421,1006,1006,1008,1006,413,412,413,414,1650,1646,31.6,19.0,-53.2,-53.3,-53.3,19.0,31.6,-319,-382,3552,5236,-319,-382,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,96,16384,16384,16384,16384,183,219,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,183,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1165,SUCCESS 26,2021-04-02 11:39:30,104.019,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16421,1004,1003,100,0,0,0,3552,65535,65535,257,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4099,4100,4118,16312,19418,1007,1007,1008,1006,413,413,413,414,1649,1647,31.7,19.0,-53.3,-53.3,-53.3,19.0,31.7,-318,-381,3552,5236,-318,-381,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,100,16384,16384,16384,16384,182,218,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,182,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1086,SUCCESS 27,2021-04-02 11:39:34,108.020,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16423,1004,1004,100,0,0,0,3552,65535,65535,257,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4104,4100,4101,4119,16313,19420,1008,1006,1006,1008,414,412,413,415,1649,1647,31.7,19.0,-53.3,-53.3,-53.3,19.0,31.7,-317,-380,3552,5236,-317,-380,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,104,16384,16384,16384,16384,181,217,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,181,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1084,SUCCESS 28,2021-04-02 11:39:38,112.020,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16425,1005,1004,100,0,0,0,3552,65535,65535,257,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4105,4100,4102,4119,16315,19416,1007,1007,1007,1005,413,413,413,414,1651,1648,31.8,19.0,-53.3,-53.3,-53.3,19.0,31.8,-316,-379,3552,5236,-316,-379,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,108,16384,16384,16384,16384,180,216,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,180,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1052,SUCCESS 29,2021-04-02 11:39:42,116.021,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16426,1004,1004,100,0,0,0,3552,65535,65535,257,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4105,4101,4102,4119,16318,19418,1007,1006,1005,1005,413,413,412,414,1649,1648,31.8,19.0,-53.3,-53.3,-53.3,19.0,31.8,-315,-377,3552,5236,-315,-377,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,112,16384,16384,16384,16384,179,214,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,179,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1067,SUCCESS 30,2021-04-02 11:39:46,120.022,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16428,1004,1004,100,0,0,0,3552,65535,65535,257,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4106,4102,4102,4120,16319,19416,1007,1008,1006,1003,413,413,413,413,1650,1649,31.8,19.0,-53.3,-53.3,-53.3,19.0,31.8,-314,-376,3552,5236,-314,-376,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,116,16384,16384,16384,16384,178,213,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,178,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1067,SUCCESS 31,2021-04-02 11:39:50,124.023,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16430,1004,1004,100,0,0,0,3552,65535,65535,257,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4106,4102,4103,4120,16321,19416,1007,1008,1007,1003,413,413,413,413,1651,1649,31.8,19.0,-53.2,-53.3,-53.3,19.0,31.8,-312,-374,3552,5236,-312,-374,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,120,16384,16384,16384,16384,176,211,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,176,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1049,SUCCESS 32,2021-04-02 11:39:54,128.023,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16432,1005,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4107,4102,4103,4121,16323,19417,1007,1008,1007,1003,414,413,413,413,1650,1650,31.9,19.0,-53.3,-53.2,-53.3,19.0,31.9,-311,-373,3552,5236,-311,-373,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,124,16384,16384,16384,16384,175,210,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,175,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1033,SUCCESS 33,2021-04-02 11:39:58,132.024,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16434,1005,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4107,4103,4104,4121,16324,19418,1008,1007,1007,1003,414,413,413,413,1652,1650,31.9,19.0,-53.3,-53.3,-53.3,19.0,31.8,-310,-371,3552,5236,-310,-371,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,128,16384,16384,16384,16384,174,208,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,174,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,986,SUCCESS 34,2021-04-02 11:40:02,136.025,0x0297,300,10,0x6081,0,65535,65535,1,19.0,16435,1005,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5510,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4108,4103,4104,4122,16328,19416,1007,1006,1006,1003,414,413,413,413,1652,1650,31.9,19.0,-53.3,-53.3,-53.3,19.0,31.9,-309,-370,3552,5236,-309,-370,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,132,16384,16384,16384,16384,173,207,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,173,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1033,SUCCESS 35,2021-04-02 11:40:06,140.025,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16438,1005,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4108,4104,4105,4122,16329,19418,1007,1005,1006,1003,414,412,413,413,1650,1650,32.0,19.1,-53.3,-53.3,-53.3,19.1,32.0,-308,-369,3552,5236,-308,-369,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,136,16384,16384,16384,16384,172,206,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,172,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1017,SUCCESS 36,2021-04-02 11:40:10,144.026,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16439,1005,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4108,4104,4105,4123,16328,19414,1008,1005,1006,1004,414,412,413,414,1651,1651,32.0,19.1,-53.3,-53.3,-53.3,19.1,31.9,-307,-368,3552,5236,-307,-368,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,140,16384,16384,16384,16384,171,205,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,171,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1125,SUCCESS 37,2021-04-02 11:40:14,148.027,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16441,1005,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4109,4105,4106,4123,16331,19416,1008,1006,1006,1003,414,413,413,414,1651,1651,31.9,19.1,-53.3,-53.3,-53.3,19.1,31.9,-306,-367,3552,5236,-306,-367,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,144,16384,16384,16384,16384,170,204,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,170,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1075,SUCCESS 38,2021-04-02 11:40:18,152.028,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16442,1004,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4109,4105,4106,4123,16333,19413,1007,1006,1006,1004,414,413,413,414,1651,1651,32.0,19.1,-53.2,-53.3,-53.3,19.1,32.0,-305,-365,3552,5236,-305,-365,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,148,16384,16384,16384,16384,169,202,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,169,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1044,SUCCESS 39,2021-04-02 11:40:22,156.028,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16444,1005,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4110,4105,4107,4124,16335,19415,1008,1006,1008,1003,414,413,414,414,1653,1651,32.0,19.1,-53.3,-53.3,-53.3,19.1,32.0,-304,-364,3552,5236,-304,-364,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,152,16384,16384,16384,16384,168,201,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,168,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1090,SUCCESS 40,2021-04-02 11:40:26,160.029,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16446,1005,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4110,4106,4107,4124,16337,19414,1007,1007,1007,1003,414,413,414,414,1653,1652,32.0,19.1,-53.3,-53.3,-53.3,19.1,32.0,-302,-362,3552,5236,-302,-362,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,156,16384,16384,16384,16384,166,199,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,166,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1059,SUCCESS 41,2021-04-02 11:40:30,164.030,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16448,1005,1005,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4110,4106,4107,4124,16338,19415,1006,1006,1007,1004,413,413,414,414,1653,1652,32.0,19.1,-53.3,-53.3,-53.3,19.1,32.0,-301,-361,3552,5236,-301,-361,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,160,16384,16384,16384,16384,165,198,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,165,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1104,SUCCESS 42,2021-04-02 11:40:34,168.030,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16449,1005,1005,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4111,4107,4108,4125,16340,19413,1007,1007,1007,1003,414,414,414,414,1653,1652,32.1,19.1,-53.3,-53.3,-53.3,19.1,32.1,-300,-359,3552,5236,-300,-359,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,164,16384,16384,16384,16384,164,196,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,164,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1103,SUCCESS 43,2021-04-02 11:40:38,172.031,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16451,1004,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4112,4107,4109,4125,16341,19413,1007,1007,1007,1004,414,414,414,414,1652,1652,32.1,19.1,-53.3,-53.3,-53.3,19.1,32.1,-299,-358,3552,5236,-299,-358,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,168,16384,16384,16384,16384,163,195,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,163,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1026,SUCCESS 44,2021-04-02 11:40:42,176.032,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16453,1004,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4112,4108,4109,4126,16345,19414,1006,1007,1008,1004,414,414,414,414,1652,1652,32.1,19.1,-53.3,-53.3,-53.3,19.1,32.1,-298,-357,3552,5236,-298,-357,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,172,16384,16384,16384,16384,162,194,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,162,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1025,SUCCESS 45,2021-04-02 11:40:46,180.033,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16455,1004,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4112,4108,4109,4126,16345,19413,1006,1005,1008,1005,414,413,414,415,1652,1652,32.1,19.1,-53.3,-53.3,-53.3,19.1,32.1,-297,-356,3552,5236,-297,-356,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,176,16384,16384,16384,16384,161,193,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,161,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1040,SUCCESS 46,2021-04-02 11:40:50,184.033,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16457,1005,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4113,4109,4110,4126,16348,19414,1006,1005,1007,1004,414,413,414,414,1652,1652,32.2,19.1,-53.2,-53.3,-53.3,19.1,32.2,-296,-355,3552,5236,-296,-355,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,180,16384,16384,16384,16384,160,192,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,160,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1010,SUCCESS 47,2021-04-02 11:40:54,188.034,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16458,1004,1004,100,0,0,0,3552,65535,65535,256,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4112,4109,4110,4127,16349,19412,1007,1008,1006,1007,414,414,413,416,1652,1652,32.2,19.1,-53.3,-53.3,-53.3,19.1,32.2,-295,-353,3552,5236,-295,-353,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,184,16384,16384,16384,16384,159,190,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,159,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1072,SUCCESS 48,2021-04-02 11:40:58,192.035,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16460,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4113,4109,4110,4127,16350,19414,1007,1007,1007,1006,414,414,414,415,1653,1652,32.1,19.1,-53.3,-53.3,-53.3,19.1,32.1,-294,-352,3552,5236,-294,-352,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,188,16384,16384,16384,16384,158,189,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,158,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1069,SUCCESS 49,2021-04-02 11:41:02,196.035,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16462,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4113,4110,4111,4128,16351,19416,1007,1007,1007,1007,414,414,414,416,1653,1652,32.3,19.1,-53.2,-53.3,-53.3,19.1,32.3,-292,-350,3552,5236,-292,-350,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,192,16384,16384,16384,16384,156,187,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,156,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1057,SUCCESS 50,2021-04-02 11:41:06,200.036,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16463,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4114,4110,4111,4128,16353,19416,1007,1006,1006,1007,414,413,414,416,1653,1653,32.2,19.1,-53.3,-53.3,-53.3,19.1,32.2,-291,-349,3552,5236,-291,-349,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,196,16384,16384,16384,16384,155,186,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,155,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1053,SUCCESS 51,2021-04-02 11:41:10,204.037,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16465,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4114,4111,4112,4129,16354,19413,1007,1006,1007,1005,414,414,414,415,1653,1653,32.3,19.1,-53.2,-53.3,-53.3,19.1,32.3,-290,-347,3552,5236,-290,-347,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,200,16384,16384,16384,16384,154,184,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,154,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1050,SUCCESS 52,2021-04-02 11:41:14,208.038,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16466,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4114,4111,4112,4129,16355,19415,1007,1006,1008,1006,414,414,414,415,1653,1653,32.2,19.1,-53.3,-53.3,-53.3,19.1,32.2,-289,-346,3552,5236,-289,-346,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,204,16384,16384,16384,16384,153,183,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,153,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1080,SUCCESS 53,2021-04-02 11:41:18,212.038,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16468,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4115,4112,4113,4129,16357,19412,1007,1006,1007,1005,414,414,414,415,1653,1653,32.3,19.1,-53.3,-53.3,-53.3,19.1,32.3,-288,-345,3552,5236,-288,-345,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,208,16384,16384,16384,16384,152,182,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,152,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1064,SUCCESS 54,2021-04-02 11:41:22,216.039,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16470,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4115,4112,4113,4130,16357,19413,1007,1006,1007,1005,414,414,414,415,1654,1653,32.3,19.1,-53.3,-53.3,-53.3,19.1,32.3,-287,-344,3552,5236,-287,-344,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,212,16384,16384,16384,16384,151,181,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,151,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1065,SUCCESS 55,2021-04-02 11:41:26,220.040,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16471,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4116,4112,4114,4130,16360,19416,1006,1005,1006,1006,414,413,414,415,1654,1653,32.3,19.1,-53.3,-53.2,-53.3,19.1,32.3,-286,-343,3552,5236,-286,-343,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,216,16384,16384,16384,16384,150,180,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,150,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1064,SUCCESS 56,2021-04-02 11:41:30,224.040,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16473,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4116,4113,4114,4131,16363,19417,1006,1006,1007,1006,414,414,414,416,1654,1653,32.3,19.1,-53.3,-53.3,-53.3,19.1,32.3,-285,-341,3552,5236,-285,-341,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,220,16384,16384,16384,16384,149,178,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,149,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1078,SUCCESS 57,2021-04-02 11:41:34,228.041,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16475,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4117,4113,4115,4131,16365,19416,1007,1006,1007,1005,415,414,414,415,1654,1654,32.3,19.2,-53.3,-53.3,-53.3,19.2,32.3,-284,-340,3552,5236,-284,-340,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,224,16384,16384,16384,16384,147,176,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,147,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1046,SUCCESS 58,2021-04-02 11:41:38,232.042,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16477,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4117,4114,4115,4131,16366,19416,1008,1005,1007,1005,415,413,414,415,1654,1654,32.3,19.1,-53.2,-53.2,-53.3,19.1,32.3,-282,-338,3552,5236,-282,-338,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,228,16384,16384,16384,16384,146,175,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,146,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1062,SUCCESS 59,2021-04-02 11:41:42,236.043,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16478,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4117,4114,4115,4132,16367,19414,1005,1006,1007,1004,414,414,414,415,1654,1654,32.4,19.2,-53.3,-53.3,-53.3,19.2,32.4,-281,-337,3552,5236,-281,-337,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,232,16384,16384,16384,16384,145,174,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,145,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1091,SUCCESS 60,2021-04-02 11:41:46,240.043,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16480,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4118,4115,4116,4132,16369,19413,1006,1006,1008,1005,414,414,415,415,1653,1654,32.4,19.1,-53.3,-53.3,-53.3,19.1,32.4,-280,-335,3552,5236,-280,-335,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,236,16384,16384,16384,16384,144,172,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,144,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1048,SUCCESS 61,2021-04-02 11:41:50,244.044,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16481,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4118,4115,4116,4133,16369,19416,1005,1005,1005,1005,414,414,414,415,1655,1654,32.4,19.1,-53.2,-53.3,-53.3,19.1,32.4,-279,-334,3552,5236,-279,-334,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,240,16384,16384,16384,16384,143,171,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,143,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1061,SUCCESS 62,2021-04-02 11:41:54,248.045,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16483,1004,1004,100,0,0,0,3552,65535,65535,255,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4118,4115,4117,4133,16372,19413,1005,1007,1006,1005,414,414,414,415,1655,1654,32.4,19.2,-53.3,-53.3,-53.3,19.2,32.4,-278,-333,3552,5236,-278,-333,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,244,16384,16384,16384,16384,142,170,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,142,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1107,SUCCESS 63,2021-04-02 11:41:58,252.045,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16485,1004,1004,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4119,4116,4117,4133,16373,19413,1006,1007,1005,1006,414,414,414,416,1653,1654,32.4,19.1,-53.3,-53.3,-53.3,19.1,32.4,-277,-332,3552,5236,-277,-332,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,248,16384,16384,16384,16384,141,169,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,141,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1088,SUCCESS 64,2021-04-02 11:42:02,256.046,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16487,1004,1004,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4119,4117,4117,4134,16374,19413,1006,1007,1005,1006,414,415,414,416,1655,1654,32.5,19.2,-53.3,-53.3,-53.3,19.2,32.5,-276,-331,3552,5236,-276,-331,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,252,16384,16384,16384,16384,140,168,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,140,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1043,SUCCESS 65,2021-04-02 11:42:06,260.047,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16488,1003,1004,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4119,4117,4118,4134,16377,19416,1004,1006,1005,1005,414,414,414,415,1654,1654,32.5,19.1,-53.3,-53.2,-53.3,19.1,32.5,-275,-329,3552,5236,-275,-329,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,256,16384,16384,16384,16384,139,166,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,139,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1087,SUCCESS 66,2021-04-02 11:42:10,264.048,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16490,1003,1004,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4120,4117,4118,4134,16378,19411,1007,1005,1005,1005,415,414,414,415,1654,1654,32.5,19.2,-53.3,-53.2,-53.3,19.2,32.5,-274,-328,3552,5236,-274,-328,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,260,16384,16384,16384,16384,138,165,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,137,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1085,SUCCESS 67,2021-04-02 11:42:14,268.048,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16492,1003,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4120,4117,4119,4135,16380,19413,1006,1005,1006,1004,414,414,414,415,1654,1654,32.5,19.2,-53.2,-53.3,-53.3,19.2,32.5,-272,-326,3552,5236,-272,-326,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,264,16384,16384,16384,16384,136,163,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,136,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1087,SUCCESS 68,2021-04-02 11:42:18,272.049,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16494,1003,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4121,4118,4119,4135,16383,19413,1005,1006,1006,1005,414,414,414,416,1654,1654,32.5,19.2,-53.3,-53.3,-53.3,19.2,32.5,-271,-325,3552,5236,-271,-325,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,268,16384,16384,16384,16384,135,162,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,135,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1086,SUCCESS 69,2021-04-02 11:42:22,276.050,0x0297,300,10,0x6081,0,65535,65535,1,19.1,16495,1004,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5460,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4121,4118,4119,4136,16385,19415,1005,1006,1005,1005,414,414,414,416,1654,1654,32.5,19.1,-53.2,-53.3,-53.3,19.1,32.5,-270,-323,3552,5236,-270,-323,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,272,16384,16384,16384,16384,134,160,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,134,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1037,SUCCESS 70,2021-04-02 11:42:26,280.050,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16496,1003,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4121,4119,4120,4136,16385,19415,1005,1005,1004,1005,414,414,414,416,1655,1655,32.5,19.2,-53.3,-53.3,-53.3,19.2,32.5,-269,-322,3552,5236,-269,-322,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,276,16384,16384,16384,16384,133,159,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,133,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1084,SUCCESS 71,2021-04-02 11:42:30,284.051,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16499,1003,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4122,4119,4120,4136,16386,19414,1005,1006,1004,1005,414,414,414,416,1655,1655,32.5,19.2,-53.3,-53.3,-53.3,19.2,32.5,-268,-321,3552,5236,-268,-321,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,280,16384,16384,16384,16384,132,158,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,132,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1115,SUCCESS 72,2021-04-02 11:42:34,288.052,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16500,1004,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4122,4120,4121,4137,16387,19415,1005,1006,1005,1005,414,414,414,416,1655,1655,32.5,19.2,-53.3,-53.3,-53.3,19.2,32.5,-267,-320,3552,5236,-267,-320,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,284,16384,16384,16384,16384,131,157,3,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,131,3,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1065,SUCCESS 73,2021-04-02 11:42:38,292.053,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16501,1003,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4123,4120,4121,4137,16390,19418,1004,1005,1005,1004,414,414,414,415,1655,1655,32.5,19.2,-53.3,-53.3,-53.3,19.2,32.5,-266,-319,3552,5236,-266,-319,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,288,16384,16384,16384,16384,130,156,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,130,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1097,SUCCESS 74,2021-04-02 11:42:42,296.053,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16503,1003,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4123,4121,4121,4138,16392,19416,1004,1005,1005,1005,414,414,414,416,1655,1655,32.5,19.2,-53.2,-53.3,-53.3,19.2,32.5,-265,-317,3552,5236,-265,-317,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,292,16384,16384,16384,16384,129,154,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,129,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1082,SUCCESS 75,2021-04-02 11:42:46,300.054,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16505,1002,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4123,4121,4122,4138,16396,19413,1004,1005,1005,1002,414,414,414,415,1654,1655,32.5,19.2,-53.3,-53.3,-53.3,19.2,32.5,-264,-316,3552,5236,-263,-315,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,296,16384,16384,16384,16384,127,152,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,127,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1097,SUCCESS 76,2021-04-02 11:42:50,304.055,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16506,1003,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4124,4121,4122,4138,16395,19416,1006,1004,1005,1004,415,414,414,415,1654,1655,32.6,19.2,-53.3,-53.3,-53.2,19.2,32.6,-262,-314,3552,5236,-262,-314,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,300,16384,16384,16384,16384,126,151,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,126,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1064,SUCCESS 77,2021-04-02 11:42:54,308.055,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16508,1003,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4124,4122,4123,4139,16398,19415,1007,1005,1006,1004,415,414,415,416,1656,1655,32.6,19.2,-53.3,-53.3,-53.3,19.2,32.6,-261,-313,3552,5236,-261,-313,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,304,16384,16384,16384,16384,125,150,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,125,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1080,SUCCESS 78,2021-04-02 11:42:58,312.056,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16509,1002,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4125,4122,4124,4139,16398,19415,1005,1005,1005,1005,415,414,414,416,1654,1655,32.6,19.2,-53.3,-53.3,-53.3,19.2,32.6,-260,-311,3552,5236,-260,-311,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,308,16384,16384,16384,16384,124,148,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,124,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1080,SUCCESS 79,2021-04-02 11:43:02,316.057,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16511,1003,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4125,4123,4124,4140,16400,19418,1006,1004,1005,1004,415,414,414,416,1656,1655,32.6,19.2,-53.3,-53.3,-53.3,19.2,32.6,-259,-310,3552,5236,-259,-310,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,312,16384,16384,16384,16384,123,147,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,123,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1094,SUCCESS 80,2021-04-02 11:43:06,320.058,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16513,1003,1003,100,0,0,0,3552,65535,65535,254,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4125,4123,4124,4140,16404,19417,1004,1005,1004,1004,414,414,414,416,1656,1655,32.6,19.2,-53.3,-53.3,-53.3,19.2,32.6,-258,-309,3552,5236,-258,-309,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,315,16384,16384,16384,16384,122,146,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,122,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1061,SUCCESS 81,2021-04-02 11:43:10,324.058,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16515,1002,1003,100,0,0,0,3552,65535,65535,253,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4126,4124,4125,4141,16404,19412,1005,1005,1005,1004,415,414,415,416,1656,1655,32.6,19.2,-53.3,-53.3,-53.3,19.2,32.6,-257,-308,3552,5236,-257,-308,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,320,16384,16384,16384,16384,121,145,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,121,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1109,SUCCESS 82,2021-04-02 11:43:14,328.059,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16516,1002,1003,100,0,0,0,3552,65535,65535,253,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4126,4124,4125,4141,16406,19414,1006,1005,1005,1004,415,414,415,416,1655,1655,32.6,19.2,-53.2,-53.3,-53.3,19.2,32.6,-256,-307,3552,5236,-256,-307,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,323,16384,16384,16384,16384,120,144,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,120,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1075,SUCCESS 83,2021-04-02 11:43:18,332.060,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16516,1003,1003,100,0,0,0,3552,65535,65535,253,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4126,4124,4126,4141,16407,19416,1005,1005,1005,1003,415,414,415,415,1657,1655,32.6,19.2,-53.3,-53.3,-53.3,19.2,32.6,-255,-305,3552,5236,-255,-305,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,327,16384,16384,16384,16384,119,142,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,119,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1058,SUCCESS 84,2021-04-02 11:43:22,336.060,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16518,1002,1003,100,0,0,0,3552,65535,65535,253,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,0x95,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4127,4125,4126,4142,16410,19416,1005,1005,1005,1004,415,415,415,416,1657,1656,32.6,19.2,-53.2,-53.3,-53.2,19.2,32.6,-254,-304,3552,5236,-254,-304,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,331,16384,16384,16384,16384,118,141,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,117,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1075,SUCCESS 85,2021-04-02 11:43:26,340.061,0x0297,300,10,0x6081,0,65535,65535,1,19.2,16520,1002,1002,100,0,0,0,3552,65535,65535,253,1000,16400,0x0090,0,-2400,-5422,91,0x0297,0x0000,0x04,0x0008,0x0003,,,,,,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4127,4126,4126,4142,16410,19414,1005,1001,1000,1000,415,413,413,414,1655,1656,32.6,19.2,-53.3,-53.3,-53.3,19.2,32.6,-252,-302,3552,5236,-252,-302,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,335,16384,16384,16384,16384,116,139,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,116,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1134,ERROR : Please check C:\Users\James\Desktop\debug.log.err 86,2021-04-02 11:43:30,344.062,0x02C7,300,10,0x6081,0,65535,65535,0,19.3,16458,-20,799,100,0,0,0,3552,0,65535,301,1000,16400,0x0090,0,-2400,-5375,91,0x02C7,0x0000,0x04,0x0008,0x0002,0x95,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4107,4120,4121,4110,16338,19977,-18,-19,-18,-20,-7,-8,-7,-8,-31,1320,25.2,19.3,-53.3,-53.2,-53.2,19.3,25.3,-252,-302,3552,5236,-252,-302,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,339,16384,16384,16384,16384,116,139,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,116,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1057,SUCCESS 87,2021-04-02 11:43:34,348.063,0x02C7,300,10,0x6081,0,65535,65535,0,19.3,16455,-19,603,100,0,0,0,3552,0,65535,382,1000,16400,0x0090,0,-2400,-5375,91,0x02C7,0x0000,0x04,0x0008,0x0002,0x95,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4106,4119,4120,4109,16335,19978,-18,-19,-19,-20,-7,-8,-8,-8,-31,995,24.3,19.3,-53.3,-53.3,-53.3,19.3,24.3,-252,-302,3552,5236,-252,-302,3552,5236,3552,5236,19.0,18.5,1000,1000,1000,1000,0,0,0,0,15,0,15,15,15,15,343,16384,16384,16384,16384,116,139,4,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,116,4,1.0,1000,16384,16384,16384,16384,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1102,SUCCESS
Sat Apr 03 09:27:55 NZDT 2021 Device Version Info = 4600_0_15 BQZ Device Name = bq40z60 BQZ Firmware Version = V0_15_BLD21 Design Capacity = 4000 Design Voltage = 12000 Specification Info = 0x0031 Manufacturer Date = 1980-1-1 Serial Number = 0x0001 Manufacturer Name = Texas Instruments Device Name = bq40z60 Device Chemistry = LION Sample,DateTime,ElapsedTime,ManufAccess,RemCapAlarm,RemTimeAlarm,BattMode,@Rate(@),@TimeFull,@TimeEmpty,@RateOK,Temperature,Voltage,Current,AvgCurr,MaxErr,RSOC,ASOC,RemCap,FullChgCap,RunTimeEmty,RunTimeEmty,AvgTimeFull,ChgCurr,ChgVolt,BattStat,CycleCnt,TurboPwr,TurboCurr,SoH,OpStatA,OpStatB,TempRange,ChgStat,ChgrStat,GaugeStat,ITStat,MfgStat,SafetyAlertAB,SafetyStatAB,SafetyAlertCD,SafetyStatCD,PFAlertAB,PFStatAB,PFAlertCD,PFStatCD,CellVolt1,CellVolt2,CellVolt3,CellVolt4,vBAT,Vacp,CellCurr1,CellCurr2,CellCurr3,CellCurr4,CellPower1,CellPower2,CellPower3,CellPower4,Power,AvgPow,IntTemp,TS1Temp,TS2Temp,TS3Temp,TS4Temp,CellTemp,FETTemp,FltRemQ,FltRemE,FltFullChgQ,FltFullChgE,TrueRemQ,TrueRemE,InitialQ,InitialE,TrueFullChgQ,TrueFullChgE,T_sim,T_ambient,RaScale1,RaScale2,RaScale3,RaScale4,CompRes1,CompRes2,CompRes3,CompRes4,PackGrid,LStatus,CellGrid1,CellGrid2,CellGrid3,CellGrid4,StateTime,DOD0_1,DOD0_2,DOD0_3,DOD0_4,DOD0 Passed Q,DOD0 Passed E,DOD0 Time,DODEOC_1,DODEOC_2,DODEOC_3,DODEOC_4,QMax1,QMax2,QMax3,QMax4,QMaxDOD0_1,QMaxDOD0_2,QMaxDOD0_3,QMaxDOD0_4,QMaxPassedQ,QMaxTime,Tk,Ta,RawDOD_1,RawDOD_2,RawDOD_3,RawDOD_4,CBTime1,CBTime2,CBTime3,CBTime4,CBDOD_1,CBDOD_2,CBDOD_3,CBDOD_4,CBTotalDODChg,SOH_FC_Q,SOH_FC_E,ChgVoltReg,ChgCurrReg,LogRowTime(ms),LogStatus 1,2021-04-03 09:27:59,4.001,0x0347,300,10,0x0081,0,65535,65535,1,19.2,16262,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0347,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4062,4068,4069,4064,16147,19980,0,0,0,0,0,0,0,0,0,0,20.7,19.2,-53.2,-53.2,-53.2,19.2,20.7,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,43,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1067,SUCCESS 2,2021-04-03 09:28:03,8.001,0x0347,300,10,0x0081,0,65535,65535,1,19.2,16261,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0347,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4062,4068,4069,4064,16146,19978,0,0,0,0,0,0,0,0,0,0,20.6,19.1,-53.3,-53.2,-53.2,19.1,20.6,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,47,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1039,SUCCESS 3,2021-04-03 09:28:07,12.002,0x0347,300,10,0x0081,0,65535,65535,1,19.2,16261,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0347,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4068,4069,4064,16145,19980,0,0,0,0,0,0,0,0,0,0,20.5,19.2,-53.3,-53.3,-53.2,19.2,20.5,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,51,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1068,SUCCESS 4,2021-04-03 09:28:11,16.002,0x0347,300,10,0x0081,0,65535,65535,1,19.2,16261,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19272,-14770,91,0x0347,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4068,4069,4063,16144,19979,0,0,0,0,0,0,0,0,0,0,20.4,19.2,-53.2,-53.2,-53.2,19.2,20.4,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,55,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1066,SUCCESS 5,2021-04-03 09:28:15,20.003,0x0347,300,10,0x0081,0,65535,65535,1,19.1,16261,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0347,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4068,4068,4063,16144,19978,0,0,0,0,0,0,0,0,0,0,20.4,19.1,-53.3,-53.3,-53.2,19.1,20.4,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,59,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1003,SUCCESS 6,2021-04-03 09:28:19,24.003,0x0347,300,10,0x0081,0,65535,65535,1,19.2,16261,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0347,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4068,4068,4064,16144,19979,0,0,0,0,0,0,0,0,0,0,20.3,19.1,-53.2,-53.2,-53.3,19.1,20.3,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,63,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1050,SUCCESS 7,2021-04-03 09:28:23,28.004,0x0347,300,10,0x0081,0,65535,65535,1,19.1,16261,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19272,-14770,91,0x0347,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4068,4068,4063,16144,19979,0,0,0,0,0,0,0,0,0,0,20.2,19.2,-53.3,-53.3,-53.2,19.2,20.2,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,67,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1096,SUCCESS 8,2021-04-03 09:28:27,32.153,0x0347,300,10,0x0081,0,65535,65535,1,19.2,16260,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19272,-14770,91,0x0347,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4068,4068,4063,16144,19979,0,0,0,0,0,0,0,0,0,0,20.2,19.2,-53.3,-53.2,-53.3,19.2,20.2,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,71,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1033,SUCCESS 9,2021-04-03 09:28:31,36.315,0x0247,300,10,0x0081,0,65535,65535,1,19.2,16260,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0247,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4062,4068,4068,4063,16144,19979,0,0,0,0,0,0,0,0,0,0,20.1,19.2,-53.3,-53.3,-53.3,19.2,20.1,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,75,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1019,SUCCESS 10,2021-04-03 09:28:35,40.005,0x0247,300,10,0x0081,0,65535,65535,1,19.2,16261,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0247,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4067,4068,4063,16142,19981,0,0,0,0,0,0,0,0,0,0,20.1,19.2,-53.3,-53.3,-53.2,19.2,20.1,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,79,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1020,SUCCESS 11,2021-04-03 09:28:39,44.454,0x0247,300,10,0x0081,0,65535,65535,1,19.1,16259,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0247,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4067,4068,4063,16145,19979,0,0,0,0,0,0,0,0,0,0,20.0,19.2,-53.3,-53.3,-53.3,19.2,20.1,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,83,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1084,SUCCESS 12,2021-04-03 09:28:43,48.006,0x0247,300,10,0x0081,0,65535,65535,1,19.2,16260,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0247,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4067,4068,4063,16144,19981,0,0,0,0,0,0,0,0,0,0,20.0,19.2,-53.3,-53.2,-53.2,19.2,20.0,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,87,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1033,SUCCESS 13,2021-04-03 09:28:47,52.007,0x0247,300,10,0x0081,0,65535,65535,1,19.2,16260,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0247,0x0000,0x04,0x0008,0x0000,0xD0,0x0004,0x0010,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4067,4068,4063,16143,19979,0,0,0,0,0,0,0,0,0,0,19.9,19.1,-53.3,-53.3,-53.3,19.2,19.9,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,91,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,0,0,1045,SUCCESS 14,2021-04-03 09:28:51,56.007,0x0247,300,10,0x0081,0,65535,65535,1,19.2,16259,0,0,100,89,79,3152,3566,65535,65535,65535,1000,16400,0x00C0,0,-19281,-14767,91,0x0247,0x0000,0x04,0x0008,0x0000,,,,,,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4067,4068,4063,16144,19980,0,0,0,0,0,0,0,0,0,0,19.9,19.2,-53.3,-53.3,-53.3,19.2,19.9,3152,4583,3566,5251,3152,4583,414,668,3566,5251,19.1,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,95,3104,2992,2976,3072,0,0,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,0,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1048,ERROR : Please check C:\Users\James\Desktop\debug3.log.err 15,2021-04-03 09:28:55,60.008,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16325,1028,371,100,89,79,3153,3566,65535,65535,72,1000,16400,0x0080,0,-19272,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4083,4073,4073,4095,16215,19444,1030,1032,1031,1030,421,420,420,422,1678,606,27.4,19.1,-53.3,-53.3,-53.3,19.1,27.2,3153,4584,3566,5251,3153,4601,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,4,3104,2992,2976,3072,-1,-1,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-1,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1110,SUCCESS 16,2021-04-03 09:28:59,64.008,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16329,1025,529,100,89,79,3154,3566,65535,65535,62,1000,16400,0x0080,0,-19275,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4084,4074,4075,4096,16221,19440,1028,1028,1028,1027,420,419,419,421,1674,863,28.3,19.1,-53.3,-53.3,-53.3,19.1,28.3,3154,4586,3566,5251,3154,4603,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,8,3104,2992,2976,3072,-2,-3,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-2,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1108,SUCCESS 17,2021-04-03 09:29:03,68.009,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16333,1025,648,100,89,79,3155,3566,65535,65535,56,1000,16400,0x0080,0,-19276,-14764,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4085,4075,4076,4097,16224,19439,1027,1027,1028,1026,420,419,419,420,1672,1058,28.8,19.1,-53.3,-53.3,-53.3,19.1,28.8,3155,4587,3566,5250,3155,4604,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,12,3104,2992,2976,3072,-3,-4,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-3,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1124,SUCCESS 18,2021-04-03 09:29:07,72.009,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16336,1024,738,100,89,79,3156,3566,65535,65535,50,1000,16400,0x0080,0,-19278,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4086,4076,4076,4098,16228,19439,1026,1028,1027,1026,419,419,419,420,1673,1206,29.3,19.1,-53.3,-53.3,-53.3,19.1,29.2,3156,4589,3566,5250,3157,4607,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,16,3104,2992,2976,3072,-5,-7,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-5,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1122,SUCCESS 19,2021-04-03 09:29:11,76.010,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16338,1024,807,100,89,79,3157,3566,65535,65535,49,1000,16400,0x0080,0,-19281,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4086,4076,4077,4098,16229,19441,1025,1027,1028,1025,419,419,419,420,1673,1318,29.6,19.1,-53.3,-53.3,-53.3,19.1,29.6,3158,4592,3567,5252,3158,4609,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,20,3104,2992,2976,3072,-6,-9,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-6,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1127,SUCCESS 20,2021-04-03 09:29:15,80.010,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16340,1024,859,100,89,79,3159,3567,65535,65535,46,1000,16400,0x0080,0,-19285,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4087,4077,4077,4099,16233,19438,1027,1026,1028,1025,420,418,419,420,1673,1403,29.8,19.1,-53.3,-53.3,-53.3,19.1,29.8,3159,4593,3566,5251,3159,4610,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,24,3104,2992,2976,3072,-7,-10,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-7,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1091,SUCCESS 21,2021-04-03 09:29:19,84.011,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16343,1024,899,100,89,79,3160,3567,65535,65535,44,1000,16400,0x0080,0,-19287,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4087,4077,4078,4100,16233,19438,1027,1026,1027,1025,420,418,419,420,1675,1468,30.0,19.1,-53.3,-53.3,-53.3,19.1,30.0,3160,4595,3566,5251,3160,4612,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,28,3104,2992,2976,3072,-8,-12,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-8,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1107,SUCCESS 22,2021-04-03 09:29:23,88.011,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16344,1024,929,100,89,80,3161,3566,65535,65535,42,1000,16400,0x0080,0,-19290,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4088,4078,4078,4100,16236,19437,1027,1027,1027,1024,420,419,419,420,1674,1517,30.2,19.1,-53.3,-53.3,-53.3,19.1,30.2,3161,4596,3566,5250,3161,4613,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,31,3104,2992,2976,3072,-9,-13,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-9,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1074,SUCCESS 23,2021-04-03 09:29:27,92.012,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16345,1024,952,100,89,80,3162,3566,65535,65535,41,1000,16400,0x0080,0,-19290,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4088,4078,4079,4101,16237,19441,1028,1026,1027,1025,420,418,419,420,1674,1555,30.4,19.1,-53.3,-53.3,-53.3,19.1,30.4,3162,4598,3566,5251,3162,4615,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,36,3104,2992,2976,3072,-10,-15,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-10,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1089,SUCCESS 24,2021-04-03 09:29:31,96.012,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16347,1024,969,100,89,80,3163,3566,65535,65535,40,1000,16400,0x0080,0,-19294,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4089,4079,4079,4101,16240,19436,1029,1026,1027,1024,421,419,419,420,1674,1584,30.5,19.1,-53.3,-53.3,-53.3,19.1,30.5,3163,4599,3566,5250,3163,4616,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,39,3104,2992,2976,3072,-11,-16,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-11,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1072,SUCCESS 25,2021-04-03 09:29:35,100.013,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16348,1024,982,100,89,80,3164,3566,65535,65535,40,1000,16400,0x0080,0,-19294,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4089,4079,4080,4101,16239,19439,1027,1026,1027,1026,420,419,419,421,1674,1605,30.6,19.1,-53.3,-53.3,-53.3,19.1,30.6,3164,4601,3566,5250,3164,4618,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,43,3104,2992,2976,3072,-12,-18,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-12,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1073,SUCCESS 26,2021-04-03 09:29:39,104.013,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16350,1024,992,100,89,80,3165,3566,65535,65535,39,1000,16400,0x0080,0,-19296,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4090,4080,4080,4102,16244,19438,1027,1025,1025,1025,420,418,418,420,1674,1622,30.7,19.1,-53.3,-53.3,-53.3,19.1,30.7,3166,4604,3567,5251,3166,4621,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,47,3104,2992,2976,3072,-14,-21,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-14,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1103,SUCCESS 27,2021-04-03 09:29:43,108.014,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16352,1025,1000,100,89,80,3166,3566,65535,65535,42,1000,16400,0x0080,0,-19296,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4090,4080,4081,4102,16242,19434,1026,1026,1027,1024,420,419,419,420,1676,1634,30.8,19.1,-53.3,-53.3,-53.3,19.1,30.8,3167,4606,3566,5252,3167,4623,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,51,3104,2992,2976,3072,-15,-23,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-15,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1104,SUCCESS 28,2021-04-03 09:29:47,112.014,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16353,1024,1006,100,89,80,3168,3567,65535,65535,42,1000,16400,0x0080,0,-19300,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4090,4080,4081,4102,16244,19434,1026,1026,1027,1026,420,419,419,421,1675,1644,30.9,19.1,-53.3,-53.3,-53.3,19.1,30.9,3168,4607,3566,5251,3168,4624,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,55,3104,2992,2976,3072,-16,-24,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-16,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1043,SUCCESS 29,2021-04-03 09:29:51,116.015,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16354,1024,1010,100,89,80,3169,3566,65535,65535,41,1000,16400,0x0080,0,-19302,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4090,4080,4081,4102,16245,19432,1027,1026,1027,1026,420,419,419,421,1676,1652,31.0,19.1,-53.3,-53.3,-53.3,19.1,31.0,3169,4609,3566,5251,3169,4626,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,59,3104,2992,2976,3072,-17,-26,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-17,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1086,SUCCESS 30,2021-04-03 09:29:55,120.015,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16355,1024,1014,100,89,80,3170,3566,65535,65535,41,1000,16400,0x0080,0,-19302,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4091,4081,4081,4103,16246,19434,1026,1026,1026,1026,420,419,419,421,1675,1657,31.1,19.1,-53.3,-53.3,-53.3,19.1,31.1,3170,4610,3566,5250,3170,4627,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,63,3104,2992,2976,3072,-18,-27,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-18,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1008,SUCCESS 31,2021-04-03 09:29:59,124.016,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16357,1024,1016,100,89,80,3171,3566,65535,65535,41,1000,16400,0x0080,0,-19305,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4091,4081,4082,4103,16249,19435,1028,1027,1027,1025,421,419,419,421,1675,1662,31.2,19.1,-53.3,-53.3,-53.3,19.1,31.2,3171,4612,3566,5251,3171,4629,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,67,3104,2992,2976,3072,-19,-29,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-19,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1057,SUCCESS 32,2021-04-03 09:30:03,128.016,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16358,1024,1018,100,89,80,3172,3566,65535,65535,41,1000,16400,0x0080,0,-19305,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4092,4081,4082,4103,16250,19438,1027,1027,1026,1025,420,419,419,421,1675,1665,31.2,19.1,-53.3,-53.3,-53.3,19.1,31.2,3172,4613,3566,5250,3172,4630,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,71,3104,2992,2976,3072,-20,-30,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-20,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1117,SUCCESS 33,2021-04-03 09:30:07,132.017,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16360,1024,1020,100,89,80,3173,3566,65535,65535,40,1000,16400,0x0080,0,-19308,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4092,4082,4083,4104,16250,19436,1027,1026,1026,1027,420,419,419,421,1677,1668,31.2,19.1,-53.3,-53.3,-53.3,19.1,31.2,3174,4616,3567,5251,3174,4633,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,75,3104,2992,2976,3072,-22,-33,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-22,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1101,SUCCESS 34,2021-04-03 09:30:11,136.017,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16361,1025,1021,100,90,80,3174,3566,65535,65535,40,1000,16400,0x0080,0,-19308,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4092,4082,4083,4104,16251,19438,1027,1027,1027,1025,420,419,419,421,1677,1670,31.4,19.1,-53.3,-53.3,-53.3,19.1,31.3,3175,4618,3567,5251,3175,4635,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,79,3104,2992,2976,3072,-23,-35,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-23,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1084,SUCCESS 35,2021-04-03 09:30:15,140.018,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16362,1025,1022,100,90,80,3176,3567,65535,65535,40,1000,16400,0x0080,0,-19311,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4093,4083,4083,4104,16254,19435,1027,1027,1027,1025,420,419,419,421,1677,1672,31.3,19.1,-53.3,-53.3,-53.3,19.1,31.3,3176,4619,3566,5251,3176,4636,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,83,3104,2992,2976,3072,-24,-36,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-24,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1130,SUCCESS 36,2021-04-03 09:30:19,144.018,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16363,1025,1023,100,90,80,3177,3566,65535,65535,40,1000,16400,0x0080,0,-19312,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4093,4083,4084,4105,16255,19435,1027,1027,1027,1027,420,419,419,422,1677,1673,31.4,19.1,-53.3,-53.3,-53.3,19.1,31.4,3177,4621,3566,5251,3177,4638,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,87,3104,2992,2976,3072,-25,-38,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-25,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1067,SUCCESS 37,2021-04-03 09:30:23,148.019,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16365,1025,1023,100,90,80,3178,3566,65535,65535,40,1000,16400,0x0080,0,-19314,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4093,4083,4084,4105,16256,19437,1027,1028,1027,1025,420,420,419,421,1677,1674,31.5,19.1,-53.3,-53.3,-53.3,19.1,31.5,3178,4623,3566,5251,3178,4640,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,91,3104,2992,2976,3072,-26,-40,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-26,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1129,SUCCESS 38,2021-04-03 09:30:27,152.019,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16366,1024,1023,100,90,80,3179,3566,65535,65535,40,1000,16400,0x0080,0,-19317,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4093,4083,4084,4106,16259,19435,1025,1026,1026,1027,420,419,419,422,1678,1674,31.5,19.1,-53.3,-53.3,-53.3,19.1,31.5,3179,4624,3566,5250,3179,4641,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,95,3104,2992,2976,3072,-27,-41,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-27,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1081,SUCCESS 39,2021-04-03 09:30:31,156.020,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16367,1024,1024,100,90,80,3180,3566,65535,65535,40,1000,16400,0x0080,0,-19320,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4094,4084,4085,4106,16258,19433,1026,1026,1027,1025,420,419,420,421,1676,1675,31.6,19.1,-53.3,-53.3,-53.3,19.1,31.6,3180,4626,3566,5251,3180,4643,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,99,3104,2992,2976,3072,-28,-43,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-28,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1121,SUCCESS 40,2021-04-03 09:30:35,160.020,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16369,1025,1024,100,90,80,3181,3566,65535,65535,39,1000,16400,0x0080,0,-19321,-14764,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4094,4084,4085,4106,16259,19434,1026,1026,1027,1026,420,419,420,421,1678,1676,31.7,19.1,-53.3,-53.3,-53.3,19.1,31.7,3181,4627,3566,5250,3181,4644,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,103,3104,2992,2976,3072,-30,-46,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-30,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1129,SUCCESS 41,2021-04-03 09:30:39,164.021,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16370,1025,1024,100,90,80,3182,3566,65535,65535,39,1000,16400,0x0080,0,-19321,-14764,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4094,4085,4085,4106,16262,19433,1027,1027,1027,1027,420,420,420,422,1678,1676,31.7,19.1,-53.3,-53.3,-53.3,19.1,31.7,3183,4630,3567,5251,3183,4647,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,107,3104,2992,2976,3072,-31,-47,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-31,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1097,SUCCESS 42,2021-04-03 09:30:43,168.021,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16371,1025,1024,100,90,80,3184,3567,65535,65535,39,1000,16400,0x0080,0,-19326,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4085,4085,4107,16263,19436,1028,1027,1025,1025,421,420,419,421,1676,1676,31.7,19.1,-53.3,-53.3,-53.3,19.1,31.7,3184,4632,3566,5251,3184,4649,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,111,3104,2992,2976,3072,-32,-49,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-32,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1065,SUCCESS 43,2021-04-03 09:30:47,172.022,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16372,1025,1024,100,90,80,3185,3566,65535,65535,39,1000,16400,0x0080,0,-19326,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4085,4086,4107,16264,19435,1028,1027,1028,1027,421,420,420,422,1678,1677,31.8,19.1,-53.3,-53.3,-53.3,19.1,31.8,3185,4633,3566,5251,3185,4650,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,115,3104,2992,2976,3072,-33,-50,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-33,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1117,SUCCESS 44,2021-04-03 09:30:51,176.022,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16374,1025,1024,100,90,80,3186,3566,65535,65535,39,1000,16400,0x0080,0,-19327,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4085,4086,4107,16264,19431,1026,1026,1028,1026,420,419,420,421,1678,1677,31.7,19.1,-53.3,-53.3,-53.3,19.1,31.7,3186,4635,3566,5251,3186,4652,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,119,3104,2992,2976,3072,-34,-52,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-34,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1158,SUCCESS 45,2021-04-03 09:30:55,180.023,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16375,1025,1024,100,90,80,3187,3566,65535,65535,39,1000,16400,0x0080,0,-19332,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4096,4086,4086,4107,16266,19433,1028,1027,1026,1025,421,420,419,421,1679,1677,31.8,19.1,-53.3,-53.3,-53.3,19.1,31.8,3187,4636,3566,5250,3187,4653,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,123,3104,2992,2976,3072,-35,-53,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-35,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1038,SUCCESS 46,2021-04-03 09:30:59,184.024,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16376,1024,1024,100,90,80,3188,3566,65535,65535,39,1000,16400,0x0080,0,-19335,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4097,4086,4087,4108,16267,19432,1028,1028,1026,1024,421,420,419,421,1679,1677,31.9,19.1,-53.3,-53.3,-53.3,19.1,31.9,3188,4638,3566,5250,3188,4655,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,127,3104,2992,2976,3072,-36,-55,0,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-36,0,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1077,SUCCESS 47,2021-04-03 09:31:03,188.024,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16377,1024,1025,100,90,80,3189,3566,65535,65535,39,1000,16400,0x0080,0,-19347,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4097,4086,4087,4108,16268,19435,1028,1027,1028,1022,421,420,420,420,1679,1678,31.9,19.2,-53.3,-53.3,-53.3,19.2,31.9,3189,4640,3566,5251,3189,4657,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,131,3104,2992,2976,3072,-37,-57,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-37,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1109,SUCCESS 48,2021-04-03 09:31:07,192.025,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16379,1025,1025,100,90,80,3190,3566,65535,65535,39,1000,16400,0x0080,0,-19336,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4097,4087,4087,4108,16271,19433,1027,1028,1028,1024,421,420,420,421,1679,1678,31.9,19.2,-53.3,-53.3,-53.3,19.1,31.9,3191,4643,3567,5252,3191,4660,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,135,3104,2992,2976,3072,-39,-60,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-39,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1060,SUCCESS 49,2021-04-03 09:31:11,196.026,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16379,1025,1025,100,90,80,3191,3566,65535,65535,38,1000,16400,0x0080,0,-19353,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4097,4087,4088,4109,16271,19432,1028,1026,1027,1023,421,419,420,420,1679,1678,32.0,19.2,-53.3,-53.3,-53.3,19.2,32.0,3192,4644,3566,5251,3192,4661,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,139,3104,2992,2976,3072,-40,-61,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-40,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1092,SUCCESS 50,2021-04-03 09:31:15,200.027,0x0297,300,10,0x0081,0,65535,65535,1,19.1,16381,1024,1025,100,90,80,3192,3566,65535,65535,38,1000,16400,0x0080,0,-19353,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4087,4088,4109,16272,19433,1028,1026,1028,1023,421,419,420,420,1678,1678,31.9,19.2,-53.3,-53.3,-53.3,19.2,31.9,3193,4646,3566,5251,3193,4663,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,143,3104,2992,2976,3072,-41,-63,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-41,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1073,SUCCESS 51,2021-04-03 09:31:19,204.027,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16382,1025,1025,100,90,80,3194,3567,65535,65535,38,1000,16400,0x0080,0,-19359,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4088,4088,4109,16274,19431,1028,1026,1026,1023,421,419,419,420,1679,1678,32.0,19.2,-53.3,-53.3,-53.3,19.2,32.0,3194,4647,3566,5251,3194,4664,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,147,3104,2992,2976,3072,-42,-64,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-42,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1058,SUCCESS 52,2021-04-03 09:31:23,208.028,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16383,1025,1025,100,90,80,3195,3567,65535,65535,38,1000,16400,0x0080,0,-19353,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4088,4088,4109,16274,19429,1027,1026,1026,1023,421,419,419,420,1679,1678,32.0,19.1,-53.3,-53.3,-53.3,19.1,32.0,3195,4649,3566,5251,3195,4666,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,151,3104,2992,2976,3072,-43,-66,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-43,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1088,SUCCESS 53,2021-04-03 09:31:27,212.028,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16384,1025,1025,100,90,80,3196,3566,65535,65535,38,1000,16400,0x0080,0,-19362,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4088,4089,4110,16275,19430,1027,1026,1027,1024,421,419,420,421,1679,1679,32.1,19.2,-53.3,-53.3,-53.3,19.2,32.1,3196,4650,3566,5250,3196,4667,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,155,3104,2992,2976,3072,-44,-67,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-44,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1103,SUCCESS 54,2021-04-03 09:31:31,216.029,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16385,1025,1025,100,90,80,3197,3566,65535,65535,38,1000,16400,0x0080,0,-19362,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4099,4088,4089,4110,16276,19432,1028,1026,1026,1024,421,419,420,421,1678,1679,32.1,19.2,-53.3,-53.3,-53.3,19.2,32.1,3197,4652,3566,5250,3197,4669,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,159,3104,2992,2976,3072,-45,-69,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-45,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1010,SUCCESS 55,2021-04-03 09:31:35,220.029,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16386,1024,1025,100,90,80,3198,3566,65535,65535,38,1000,16400,0x0080,0,-19368,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4099,4089,4089,4110,16277,19432,1028,1026,1028,1024,421,420,420,421,1680,1679,32.1,19.2,-53.3,-53.3,-53.3,19.2,32.1,3198,4653,3566,5250,3199,4672,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,163,3104,2992,2976,3072,-47,-72,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-47,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1088,SUCCESS 56,2021-04-03 09:31:39,224.030,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16387,1024,1025,100,90,80,3199,3566,65535,65535,38,1000,16400,0x0080,0,-19371,-14773,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4099,4089,4090,4110,16279,19430,1028,1027,1028,1023,421,420,420,420,1678,1679,32.2,19.2,-53.3,-53.3,-53.3,19.2,32.2,3200,4657,3567,5252,3200,4674,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,167,3104,2992,2976,3072,-48,-74,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-48,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1117,SUCCESS 57,2021-04-03 09:31:43,228.030,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16388,1025,1025,100,90,80,3200,3566,65535,65535,37,1000,16400,0x0080,0,-19371,-14773,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4089,4090,4111,16279,19434,1026,1028,1029,1024,421,420,421,421,1680,1679,32.1,19.2,-53.3,-53.3,-53.3,19.2,32.1,3201,4658,3566,5251,3201,4675,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,171,3104,2992,2976,3072,-49,-75,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-49,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1072,SUCCESS 58,2021-04-03 09:31:47,232.031,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16390,1025,1025,100,90,81,3202,3567,65535,65535,37,1000,16400,0x0080,0,-19374,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4090,4090,4111,16280,19432,1028,1027,1030,1024,421,420,421,421,1680,1679,32.2,19.2,-53.3,-53.3,-53.3,19.2,32.2,3202,4660,3566,5251,3202,4677,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,175,3104,2992,2976,3072,-50,-77,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-50,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1118,SUCCESS 59,2021-04-03 09:31:51,236.031,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16391,1025,1025,100,90,81,3203,3567,65535,65535,37,1000,16400,0x0080,0,-19377,-14773,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4090,4091,4111,16283,19432,1027,1027,1028,1024,421,420,421,421,1680,1679,32.1,19.2,-53.3,-53.3,-53.3,19.2,32.1,3203,4661,3566,5251,3203,4678,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,179,3104,2992,2976,3072,-51,-78,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-51,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1118,SUCCESS 60,2021-04-03 09:31:55,240.031,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16392,1025,1025,100,90,81,3204,3566,65535,65535,37,1000,16400,0x0080,0,-19377,-14773,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4090,4091,4111,16283,19432,1026,1027,1028,1025,421,420,421,421,1680,1679,32.2,19.2,-53.3,-53.3,-53.3,19.2,32.2,3204,4663,3566,5251,3204,4680,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,183,3104,2992,2976,3072,-52,-80,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-52,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1085,SUCCESS 61,2021-04-03 09:31:59,244.032,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16393,1025,1025,100,90,81,3205,3566,65535,65535,37,1000,16400,0x0080,0,-19377,-14773,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4091,4091,4112,16285,19431,1026,1027,1028,1024,421,420,421,421,1679,1679,32.3,19.2,-53.3,-53.3,-53.3,19.2,32.3,3205,4664,3566,5250,3205,4681,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,187,3104,2992,2976,3072,-53,-81,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-53,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1100,SUCCESS 62,2021-04-03 09:32:03,248.033,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16394,1025,1025,100,90,81,3206,3566,65535,65535,37,1000,16400,0x0080,0,-19381,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4091,4091,4112,16286,19431,1028,1027,1027,1027,421,420,420,422,1680,1680,32.2,19.2,-53.2,-53.3,-53.3,19.2,32.2,3206,4666,3566,5250,3206,4683,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,191,3104,2992,2976,3072,-54,-83,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-54,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1054,SUCCESS 63,2021-04-03 09:32:07,252.033,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16396,1025,1025,100,90,81,3207,3566,65535,65535,37,1000,16400,0x0080,0,-19383,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4091,4092,4112,16287,19432,1027,1028,1028,1028,421,421,421,423,1681,1680,32.3,19.2,-53.3,-53.3,-53.3,19.2,32.3,3208,4669,3567,5252,3208,4686,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,195,3104,2992,2976,3072,-56,-86,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-56,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1098,SUCCESS 64,2021-04-03 09:32:11,256.033,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16397,1025,1025,100,90,81,3208,3566,65535,65535,37,1000,16400,0x0080,0,-19383,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4092,4092,4113,16287,19433,1028,1028,1026,1027,422,421,420,422,1681,1680,32.3,19.2,-53.3,-53.3,-53.3,19.2,32.3,3209,4670,3566,5251,3209,4687,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,199,3104,2992,2976,3072,-57,-87,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-57,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1053,SUCCESS 65,2021-04-03 09:32:15,260.034,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16398,1025,1025,100,90,81,3209,3566,65535,65535,37,1000,16400,0x0080,0,-19383,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4092,4092,4113,16288,19435,1027,1028,1027,1025,421,421,420,422,1681,1680,32.3,19.2,-53.3,-53.3,-53.3,19.2,32.3,3210,4672,3566,5251,3210,4689,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,203,3104,2992,2976,3072,-58,-89,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-58,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1097,SUCCESS 66,2021-04-03 09:32:19,264.034,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16399,1024,1025,100,91,81,3211,3567,65535,65535,36,1000,16400,0x0080,0,-19389,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4092,4093,4113,16289,19432,1027,1028,1028,1027,421,421,421,422,1679,1680,32.3,19.2,-53.3,-53.3,-53.3,19.2,32.3,3211,4674,3566,5251,3211,4691,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,207,3104,2992,2976,3072,-59,-91,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-59,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1084,SUCCESS 67,2021-04-03 09:32:23,268.035,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16400,1025,1025,100,91,81,3212,3566,65535,65535,36,1000,16400,0x0080,0,-19389,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4102,4092,4093,4113,16289,19430,1027,1026,1028,1025,421,420,421,422,1681,1680,32.3,19.2,-53.3,-53.3,-53.3,19.2,32.3,3212,4675,3566,5251,3212,4692,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,211,3104,2992,2976,3072,-60,-92,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-60,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1111,SUCCESS 68,2021-04-03 09:32:27,272.035,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16401,1025,1025,100,91,81,3213,3566,65535,65535,36,1000,16400,0x0080,0,-19389,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4102,4092,4093,4114,16290,19432,1027,1026,1026,1025,421,420,420,422,1681,1680,32.4,19.2,-53.3,-53.3,-53.3,19.2,32.3,3213,4677,3566,5251,3213,4694,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,215,3104,2992,2976,3072,-61,-94,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-61,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1116,SUCCESS 69,2021-04-03 09:32:31,276.036,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16402,1025,1025,100,91,81,3214,3566,65535,65535,36,1000,16400,0x0080,0,-19392,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4102,4093,4093,4114,16292,19432,1027,1027,1027,1025,421,420,420,422,1681,1680,32.3,19.2,-53.3,-53.3,-53.3,19.2,32.3,3214,4678,3566,5250,3214,4695,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,219,3104,2992,2976,3072,-62,-95,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-62,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1065,SUCCESS 70,2021-04-03 09:32:35,280.036,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16403,1024,1025,100,91,81,3215,3566,65535,65535,36,1000,16400,0x0080,0,-19395,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4102,4093,4094,4114,16293,19431,1028,1026,1028,1026,422,420,421,422,1680,1680,32.4,19.2,-53.3,-53.3,-53.3,19.2,32.4,3215,4680,3566,5250,3216,4698,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,223,3104,2992,2976,3072,-64,-98,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-64,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1081,SUCCESS 71,2021-04-03 09:32:39,284.037,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16405,1025,1025,100,91,81,3216,3566,65535,65535,36,1000,16400,0x0080,0,-19395,-14770,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4093,4094,4115,16296,19433,1027,1027,1028,1026,421,420,421,422,1680,1680,32.4,19.2,-53.3,-53.3,-53.3,19.2,32.3,3217,4683,3567,5251,3217,4700,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,227,3104,2992,2976,3072,-65,-100,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-65,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1124,SUCCESS 72,2021-04-03 09:32:43,288.037,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16405,1024,1025,100,91,81,3217,3566,65535,65535,36,1000,16400,0x0080,0,-19398,-14767,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4094,4094,4115,16296,19434,1028,1027,1028,1026,422,420,421,422,1680,1680,32.4,19.2,-53.3,-53.3,-53.3,19.2,32.4,3218,4684,3566,5251,3218,4701,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,231,3104,2992,2976,3072,-66,-101,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-66,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1063,SUCCESS 73,2021-04-03 09:32:47,292.038,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16406,1024,1025,100,91,81,3219,3567,65535,65535,36,1000,16400,0x0080,0,-19404,-14773,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4094,4095,4115,16297,19431,1028,1025,1028,1025,422,420,421,422,1680,1681,32.4,19.2,-53.3,-53.3,-53.3,19.2,32.4,3219,4686,3566,5251,3219,4703,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,235,3104,2992,2976,3072,-67,-103,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-67,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1110,SUCCESS 74,2021-04-03 09:32:51,296.038,0x0297,300,10,0x0081,0,65535,65535,1,19.2,16408,1025,1025,100,91,81,3220,3566,65535,65535,35,1000,16400,0x0080,0,-19404,-14773,91,0x0297,0x0000,0x04,0x0008,0x0003,0x90,0x0004,0x0410,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4094,4095,4115,16298,19430,1028,1027,1027,1027,422,420,421,423,1682,1681,32.4,19.2,-53.3,-53.3,-53.3,19.2,32.4,3220,4687,3566,5250,3220,4704,414,668,3566,5268,19.2,19.1,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,239,3104,2992,2976,3072,-68,-104,1,1280,1280,1280,1280,4000,4000,4000,4000,0,0,0,0,-68,1,1.0,1000,3104,2992,2976,3072,0,0,0,0,0,0,0,0,0,3638,5508,255,25,1125,SUCCESS
Cheers
