Other Parts Discussed in Thread: TINA-TI
Hello expert,
I have question for TPS2553's current limit behavior.
My understanding for this device's reaction for over current event is output should be turned off at first after then output side start to supply regulated output when device is enabled and be suppled voltage from input side.
Also, Vout supply regulated voltage at first if OC is happened when TPS2553 is starting up or enabling.
However, TINA-TI simulation result showed this device supplied regulated power to load side at first and FET haven't turned of as follows.
Then would you tell me actual condition of when internal path FET is turned off?
Kazuki Kuramochi
