Hi Team,
Our customer is looking for a synchronous rectifier control chip. According to the customer,
The synchronous rectifier control sits on the secondary and I need one which work with a full bridge topology but does not require a signal from the primary side.
Also need to work if the output is 3.2v or lower. Generally this mean the chip's power supply Vdd, needs to work at 3.2v are less.
FYI we can use a chip with one or two output meaning it can be the half wave type or the center taped type. quote both if possible.
Hope to hear from you soon. Our project has been dead for over a month because none of the chips we try work. They all seem to be for the flyback topology which we don't have.
Can you please suggest a device that fits the customer's requirements.
Thank you for your support!
Danilo
