Looking at datasheet's on bq24450 there is mention on it charging at around 15 Amps. as i am prototyping at the moment i am needing this info quite urgently.
power supply is at 38volts DC 40amps (battery or multiple batteries at 12v Lead Acid Type from 80amp to > 200amps)..
Q ext is multiple Mosfet-P in parallel ..
So please let me know external resistor settings and any help on R isnsm & isnsp also D Schottky as high current is being used..
circuit is similar to attached
