Other Parts Discussed in Thread: BQ24780
Hi Guys
Regarding the BQ24780 learning mode problem, the battery LEARN Cycle of the chip learns the battery level through full discharge. Under what conditions does the learning mode use? I read the data sheet if the voltage reaches Battery Depletion Threshold when it discharges in learning mode, it will automatically change to charge by the adapter. If I want to know if the battery is over-discharged, it must be in learning mode?
