Hi all,
Regarding BQ34z100-G1, i've recently evaluate it on the EVM using Bqstudio.
I also done calibrating my set of custom batteries (not found in Batt chem) and created the golden image file (.srec, .df and .bq) using bqstudio software.
I have read the slua665 regading bq34z100 going into production, i believe it is different for bq34z100-g1 as the golden file format is different from what i have created.
May i know whether is there a proper procedure on how to program the IC with the golden file i created and seal it?
Is Bq mtester , HPA169/495 necessary?
In Bqstudio software, there is a "Programming" tab right beside the "Golden image" tab, is that function use to flash in golden file image at production?
thanks.
Kah Wei
