I am not able to generate Golden Image files due to the error "java.lang.ArrayIndexOutOfBoundsException: 5".
Please see attached photo and advise:
I'm getting the same error when trying to generate the golden image files.
I've described it here:
I uploaded the requested files.
Unfortunately the problem is still not solved.
Hi Sebastian,
Let's try to work it out together. I was able to generate the files yesterday after many trials with UNSEAL FULL ACCESS command sent first. It is not consistent for me for some reason, maybe due to I2C related problems but let's see if issuing UNSEAL_FULL_ACCESS perior to golden image generation works for you consistently. If so, then I will know I have some comm. issues on my side.
