I came across the TDELTAV parameter in the BQ28Z610 gas gauge settings using bqStudio, and I have not been able to find a description for this parameter in the technical reference manual. In the 13.3 Settings section, the IT Gauging Configuration does not contain the TDELTAV parameter as bqStudio indicates. Could someone explain what this parameter is used for?
Thank you for your time.
Blake
