After an unsuccessful golden image learning cycle for a project with an bq27542-G1, I am wondering what has to be done to start over, or to use the EVM with a different set of cells.
Previously, I was simply resetting Update Status to 0, followed by a Reset (Command 0x41). Is this sufficient?
From previous experience with other chips, and as mentioned in other posts and pieces of documentation, I understand that there may be several hidden values that may have to be reset. If this is the case, could you please provide an image of the default firmware/configuration?
Thanks in advance,
Jorg
