Other Parts Discussed in Thread: BQ27426, BQSTUDIO, BQ27220, BQ27546-G1
I would like to use the bq27426 for a 10000 mAh 3.7V battery.
In the datasheet the max battery capacity of the bq27426 is 14000mAh (www.ti.com/.../BQ27426) but in the document SLUUBB0 p. 49 ( http://www.ti.com/lit/ug/sluubb0/sluubb0.pdf ) the max value of design capacity is 8000mAh. Where is the error ?
Thank you.
