Part Number: BQ34Z100-G1
Hi guys.
I have worked with 2 fuel gauges from TI, but they always have been already calibrated, programmed and so on. I have never gone through manufacturing process my self.
So I am using BQ34Z100-G1, I checked the datasheet and fully did not understand what should I do and in what order, so there are few questions:
When I solder the BMS with bq34z100-g1 to battery for first time and turn it on what steps should I take?
From the manual it seems like this:
1. Install the data memory file with .gg extension.
2. Edit the number of cells parameter
3. Do the calibration from the calibration screen in bqStudio
4. Choose the right chemistry from chemistry screen
Am I right or did I understand this completely wrong?
When should I use the programming screen and golden image screen?
Meanwhile I will continue to search for explanations/manuals for BqStudio.
Karlis Tucs
