Part Number: BQ40Z50
Other Parts Discussed in Thread: GPCCHEM, GPCCEDV, BQSTUDIO
I never used a BMS before, but I have a pcb with a BMS (BQ40z50) and a charger (LT1510-5CGN) .
This was designed by someone else, I only know that I am supposed to load a .srec file and charge/ discharge the batteries.
I have done this, and it seems to be working, but after ± 3 weeks not using the device, the batteries were empty.
The batteries were fully charched when the device was swiched off, (mechanical switch so no leakage current there) but after ±3 weeks the batteries were empty.
How can this be happening,
Second problem is that the battery status is not remembered correctly.
When charging, the battery status seems ok, but when everithing is switched off, the next day the battery status is indicating a empty battery, but when messering the actual voltage the battery is still 95% full.
How can i solve these problems?
