I want to know the principle of the below modes of current sharing operation.
1. PWM bus current sharing;
2. Master/slave current sharing.
3. How to acheive cold redundancy by using UCD3138
Please look at the following document:
And let me know if you have any questions.
I am not sure what exactly you mean by cold redundancy. Are you referring to a different compensation for colder temperature, when the cramic output caps loose their value? Please advise.
Hi Yitzhak Bolurian,
Thanks for your feedback.
1. Link for goole websit
I am China for business travel now and I can't link to goole websit now.
May you provide another link for it ?
2. Cold Redundancy
Please to refer below website for " Cold Redundancy " function.
The section 2.3.4 will show what is cold redundancy.
Best Regards
Jacky Chang
I have sent you the current sharing application via email.
Regarding the cold redundancy, depending on the timing and latency requirements, this may be implemented using the fast interrupt .
An edge on the fault pin can invoke the fast interrpt and turn on the power supply that is in CR.
Please advise of the latency requirement to turn the power supply on.
