TPS65175: TPS65175 with Level Shifter power off discharge
Part Number: TPS65175
Other Parts Discussed in Thread: TPS65197, TPS65149, TPS65163
Hi Team,
As there are several version of TPS65175, would you please suggest if there is a version of TPS65175's Level Shifter have output discharge function during power off, like TPS65197/B? thanks.
Kevin
  • Hello Kevin,
    All versions of the TPS65175 does not include the discharge function. What are the requirements for this application ? Do you require all 12-Ch Level Shifter? Dependent on the criteria there is the
    TPS65149 (8-Ch-L/s with discharge function, AVDD, VGH, VGL, VCOM, Reset) or the
    TPS65163 (9-Ch L/s with discharge function, AVDD, VGH, VGL, Buck, Reset) or use a standalone L/s.
    Best Regards.
    Ilona
