Part Number: LM3409
When I am operating the driver under normal operation the system is quiet. On my PWM dimming circuit, i get audible ringing, I am PWM dimming about 1kHz. I read a document regarding what it is and believe it is in the capacitor,
electronics-eetimes.com/news/improving-reliability-and-lowering-audible-noise-led-drivers/page/0/1
However, the document does not specify exactly what capacitor it is saying is doing the vibrating. I tried removing the output capacitor in my circuit, but that did not solve the ringing. Since placing a cap on the bottom of the PCB to counter the PCB vibration is not an option considering i have all components on the top side so it would not make sense to add cost just for this. I was going to drill around the caps and reduce the ability for the cap to effect the PCB and resonate. I cant seem to figure out what caps the article is referring to.
Is it the input caps to the chip itself? there are not many caps so i have to assume it is that. Or is there some other item that could be causing the ringing from the PWM dimming function?
thanks
