Other Parts Discussed in Thread: LM317,
Hello team,
My customer would like to use tps7b7701 to power a two-wire fan, the problem is speed control. We could either change the output voltage or limit the output current, need check with you: Can we change the feedback resistor or the current limit resistor during operation?
Do you have any other recommendation for this kind of application? As far as I know, most of the next-generation infotainment processors power dissipation is very high, fans are needed to help cool the system.
Thanks.
Dongbao
