Part Number: TPS7A3301EVM-061
I designed a 4 channel +/-3.3vdc power supply board using tps7a3301 and tps7a8300. Each channel has 750mA loads. There are 4 tps7a3301 ic for each channel and 2 tps7a8300 ic sharing between 2 channels. The board has 4 layers , in which there is one ground plane.
Input supply is +/-5v , I checked ripples and noise is ok in individual channels, but when I connect the loads in all 4 channels , the board is getting too much hot, my concern is how to get overcome this problem. The ground plane is inner layer. Please help me.
