Designing of positive and negative voltage using TPS54060
Other Parts Discussed in Thread: TPS54060, TINA-TI, TPS54160
I need to generate +5V and -5V with 12V Input. I'm using TPS54060 regulator to generate required output.
I've referred the following document to design the circuit.
http://www.ti.com/lit/ug/slvu374/slvu374.pdf
I did not find any step by step guidelines to design positive and negative supply using TPS54060.
I've entered the schematic in TINA-TI and tried to simulate.
It was showing error as fault in design.
Attached the TINA-TI schematic.
Please help me with your feedback.
Amit
3835.TPS54060.tsc
