Other Parts Discussed in Thread: TPS61240, TPS61090, TPS61230
I have a short on the input pin probably because of a voltage spike on the SW pin. The device is damage when the battery feeding the IC is really low.
It's probably because of my layout (my coil is at 1.5cm of the IC) but it's work (most of time) with this coil :media.digikey.com/.../VLC5045.pdf but it's damage the device with this one : http://www.farnell.com/datasheets/1735537.pdf
Can you explain me why it's working with one and not with the other coil ? it's because of the different Isat ? can you explain me the layout consequences ?
Here is the layout :
Thank you in advance for the help and the explanation
