Other Parts Discussed in Thread: TPS659037
How to TPS659037 power on the automatic start, no button operation
Hi Wei,
You can pull the POWERHOLD pin up to LDOVRTC, and use RESET_IN to turn the PMIC on/off based on input power. Since LDOVRTC is always on, this will get pulled high when power is supplied. For RESET_IN, my recommendation is to use a powergood from a pre-regulator, or a supervisor on the input supply, to control RESET_IN in order to allow the power-off sequence to complete when power is removed.
You can look at our blog post How to meet power sequencing requirements, specifically the second half about power-down sequencing, for more details about meeting the power-down requirements with powergood or supervisor.
Karl
Hello Karl,
I just saw this while having the same question.
I was just wondering if the same auto-turn on can be implemented just by putting a supervisor on PWRON.
KEvin
