Part Number: LM5060
Other Parts Discussed in Thread: LM5069, , TPS2490
Hello all,
i am looking for some simple Hot-swap controller. I've found two which should be fine LM5060 and LM5069. The first one do not need a sense resistor what is great but i do not understand properly how it works during limiting of input current. Also i did not find any mention about short pin in datasheet (probably thru the dividing resistors on UVLO and OVP). Which one should i use for hot inserting and hot removing modules? Any advice?
Many thanks
