TPS23756 damaged after using Adapter Option 3 when first start up.
Our customer use "adapter option 3" to connect external power and TPS23756. But the voltage of adapter(5.1V) > Vout(4.99V)
The 2nd side is diods not SR, and also a diode after adapter output.
Is there anything could makes this happen?
Thank you very much.
BTW, this is a different case and different customer with the thread below
