For CAD library, I need urgently information for TPS84A20 dimensions and location of the exposed thermal pad.
This information is not given in the datasheet
Generally the package dimensions can be found in the components webpage itself (http://www.ti.com/product/TPS84A20).
It will be at Package | Pins Column under Sample & Buy
What you are looking for is http://www.ti.com/lit/ml/mpqf306/mpqf306.pdf
Sorry, if I missed or overlooked something, but there is only a description of package size and dimensoins of case and signal pins, but no information about exposed thermal pad size and dimension.
Hi Franz,
Here are all of the drawings you need. They should be attaching to the end of the datasheet soon.
