What is the MAX leakage expected on the PG pin - this is needed to properly size a pull-up resistor.
The internal IC only specs a typical value of 7nA.
The maximum recommended pull-up resistor on the power good pin is 100kΩ.
Ok -
We need a current to work with for a worst-case analysis. If 100kohms is the max resistor, would you please advise the expected leakage current that corresponds to the 100k pull-up? Or, equivalently, what voltage drop is expected with a 100kohm pull-up?
