Other Parts Discussed in Thread: TPS82084
Dears,
I am now trying to select a power module. I find both LMZ20502 VS TPS82084 are suitable to my case.
They have similar function. Could you please tell the different between each others?
Many thanks.
Hi Zhengqing Wang,
I've attached a side-by-side comparison between the LMZ20502 and TPS82084. These information can be seen from the "Description & parametrics" tab of the each product folder. The TPS82084 has a slightly higher maximum input voltage and considerably higher maximum output voltage. The TPS82084 also has a much lower quiescent current to reduce power consumption. I would recommend designing with the TPS82084.
Jimmy
