I am working on the grounding arrangements around pin 37 PGND and the connection to AGND.
The data sheet (P.23) gives a suggested layout with a solid AGND top layer plane connected to PGND at pin 37 only.
The evaluation board layout (P7 of the user guide) shows a similar layout for the top layer AGND plane but with the PGND connections isolated. The AGND connection is then at the vias near pins 33 and 34.
I am assuming that the eval. board is the best reference but is there a definitive answer?
Thanks.
