Other Parts Discussed in Thread: TPS82130
Hi Team,
My customer is using TPS82085, but due to load restriction, they have to use output cap higher than 150uF. But in our datasheet, we have recommendation for output cap is 22uF to 150uF. So the question from customer is that:
1. Since they already use bigger than 150uF during first around pp test, is these any risk for this when go to MP? For example, will TPS82085 be damaged during MP stage after running a while at field side;
2. At the second around pp test(Another slot TPS82085), they do found TPS8208 can't output normal with this big cap, this should trigger the hiccup mode during start up as mentioned in our datasheet.
If customer have to use bigger 150uF, do we have solution to avoid problem or potential risk? Thanks.
Sulyn
