Other Parts Discussed in Thread: LM3880
Hi!
As I've understood, the power supply sequencers control the power-up/power-down sequence by means of some sort of main EN signal. Rails are sequenced in needed order when the EN signal is activated and in reverse order when the EN signal is deactivated. But what if the primary supply is just removed? How can the shutdown sequence be controlled in such circumstances?
Best regards, Vic.
