Hello Team,
For AM64x, I am trying to setup and test with SK-AM64x board.
Right now I am following this procedure, https://dev.ti.com/tirex/content/tirex-product-tree/am64x-devtools/docs/am64x_skevm_quick_start_guide.html
And I found out that the SD card image *.wic.xz, from RT-linux SDK url is not working, doesn’t bootup, nothing show up on the uart terminal, but the sd image file in regular linux sdk url works, the login prompt show up on the uart terminal.
Would you please help me to get correct sd image file for RT-linux SDK.
Also, from debug terminal, I saw ptp is running, do you have some documentation or procedure for testing/evaluating PTP time synchronization?
I need PPS (one second pulse) output from the board, and in that way I would use hardware to measure the jitter over time.
