My customer asked us that some SEC_PROXY_MESSAGE_j_y resisters can't be accessed from code on CA72 core.
So I checked the following manual and tested it on psdk_rtos_auto_j7_07_00_00_11.
The read/write access for j=0h to 9h, y=0h to Eh is OK but other area happened SError.
Q1: CA72 core can access only for j=0h to 9h ? (hardware limitation)
Q2: if no hardware limitation, Sciclient call parameters are needed to change ?
Seiki Tatesawa
< Technical Reference Manual >
j=0h - 9Fh , y = 0h - Eh for NAVSS0_SEC_PROXY0_SRC_TARGET_DATA
< Test Code >
#define CSL_NAVSS0_SEC_PROXY0_SRC_TARGET_DATA_BASE (0x32c00000UL) #define IO_OFFSET (0xFFFFFFFF00000000ULL) <- my customer's MMU setting for(j = 0x00UL; j <= 0x9FUL; j++) { for(y = 0UL; y <= 0xEUL; y++) { formula = (j * 0x1000UL) + (y * 4UL); regbase = (volatile uint32_t*) (CSL_NAVSS0_SEC_PROXY0_SRC_TARGET_DATA_BASE + 0x0004UL + formula + IO_OFFSET); printf("SEC_PROXY_MESSAGE_%02x_%02x: 0x%08x 0x%08x \n", j, y, regbase, *regbase); printf("%s() @%d: write 0x%08x to 0x%p\n", __func__, __LINE__, value, regbase); *regbase = value; printf("%s() @%d: done\n", __func__, __LINE__); } }
< Test Result: register read/write OK area >
SEC_PROXY_MESSAGE_00_00: 0x32c00004 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00004 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_01: 0x32c00008 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00008 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_02: 0x32c0000c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0000c run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_03: 0x32c00010 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00010 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_04: 0x32c00014 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00014 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_05: 0x32c00018 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00018 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_06: 0x32c0001c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0001c run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_07: 0x32c00020 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00020 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_08: 0x32c00024 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00024 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_09: 0x32c00028 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00028 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_0a: 0x32c0002c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0002c run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_0b: 0x32c00030 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00030 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_0c: 0x32c00034 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00034 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_0d: 0x32c00038 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c00038 run_sample_programs() @201: done SEC_PROXY_MESSAGE_00_0e: 0x32c0003c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0003c run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_00: 0x32c01004 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01004 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_01: 0x32c01008 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01008 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_02: 0x32c0100c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0100c run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_03: 0x32c01010 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01010 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_04: 0x32c01014 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01014 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_05: 0x32c01018 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01018 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_06: 0x32c0101c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0101c run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_07: 0x32c01020 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01020 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_08: 0x32c01024 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01024 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_09: 0x32c01028 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01028 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_0a: 0x32c0102c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0102c run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_0b: 0x32c01030 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01030 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_0c: 0x32c01034 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01034 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_0d: 0x32c01038 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c01038 run_sample_programs() @201: done SEC_PROXY_MESSAGE_01_0e: 0x32c0103c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0103c run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_00: 0x32c02004 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02004 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_01: 0x32c02008 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02008 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_02: 0x32c0200c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0200c run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_03: 0x32c02010 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02010 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_04: 0x32c02014 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02014 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_05: 0x32c02018 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02018 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_06: 0x32c0201c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0201c run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_07: 0x32c02020 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02020 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_08: 0x32c02024 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02024 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_09: 0x32c02028 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02028 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_0a: 0x32c0202c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0202c run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_0b: 0x32c02030 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02030 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_0c: 0x32c02034 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02034 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_0d: 0x32c02038 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c02038 run_sample_programs() @201: done SEC_PROXY_MESSAGE_02_0e: 0x32c0203c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0203c run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_00: 0x32c03004 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03004 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_01: 0x32c03008 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03008 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_02: 0x32c0300c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0300c run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_03: 0x32c03010 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03010 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_04: 0x32c03014 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03014 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_05: 0x32c03018 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03018 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_06: 0x32c0301c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0301c run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_07: 0x32c03020 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03020 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_08: 0x32c03024 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03024 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_09: 0x32c03028 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03028 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_0a: 0x32c0302c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0302c run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_0b: 0x32c03030 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03030 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_0c: 0x32c03034 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03034 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_0d: 0x32c03038 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c03038 run_sample_programs() @201: done SEC_PROXY_MESSAGE_03_0e: 0x32c0303c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0303c run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_00: 0x32c04004 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04004 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_01: 0x32c04008 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04008 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_02: 0x32c0400c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0400c run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_03: 0x32c04010 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04010 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_04: 0x32c04014 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04014 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_05: 0x32c04018 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04018 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_06: 0x32c0401c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0401c run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_07: 0x32c04020 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04020 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_08: 0x32c04024 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04024 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_09: 0x32c04028 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04028 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_0a: 0x32c0402c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0402c run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_0b: 0x32c04030 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04030 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_0c: 0x32c04034 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04034 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_0d: 0x32c04038 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c04038 run_sample_programs() @201: done SEC_PROXY_MESSAGE_04_0e: 0x32c0403c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0403c run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_00: 0x32c05004 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05004 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_01: 0x32c05008 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05008 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_02: 0x32c0500c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0500c run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_03: 0x32c05010 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05010 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_04: 0x32c05014 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05014 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_05: 0x32c05018 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05018 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_06: 0x32c0501c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0501c run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_07: 0x32c05020 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05020 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_08: 0x32c05024 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05024 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_09: 0x32c05028 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05028 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_0a: 0x32c0502c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0502c run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_0b: 0x32c05030 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05030 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_0c: 0x32c05034 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05034 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_0d: 0x32c05038 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c05038 run_sample_programs() @201: done SEC_PROXY_MESSAGE_05_0e: 0x32c0503c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0503c run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_00: 0x32c06004 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06004 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_01: 0x32c06008 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06008 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_02: 0x32c0600c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0600c run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_03: 0x32c06010 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06010 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_04: 0x32c06014 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06014 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_05: 0x32c06018 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06018 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_06: 0x32c0601c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0601c run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_07: 0x32c06020 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06020 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_08: 0x32c06024 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06024 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_09: 0x32c06028 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06028 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_0a: 0x32c0602c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0602c run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_0b: 0x32c06030 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06030 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_0c: 0x32c06034 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06034 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_0d: 0x32c06038 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c06038 run_sample_programs() @201: done SEC_PROXY_MESSAGE_06_0e: 0x32c0603c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0603c run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_00: 0x32c07004 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07004 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_01: 0x32c07008 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07008 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_02: 0x32c0700c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0700c run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_03: 0x32c07010 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07010 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_04: 0x32c07014 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07014 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_05: 0x32c07018 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07018 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_06: 0x32c0701c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0701c run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_07: 0x32c07020 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07020 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_08: 0x32c07024 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07024 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_09: 0x32c07028 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07028 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_0a: 0x32c0702c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0702c run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_0b: 0x32c07030 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07030 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_0c: 0x32c07034 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07034 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_0d: 0x32c07038 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c07038 run_sample_programs() @201: done SEC_PROXY_MESSAGE_07_0e: 0x32c0703c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0703c run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_00: 0x32c08004 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08004 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_01: 0x32c08008 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08008 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_02: 0x32c0800c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0800c run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_03: 0x32c08010 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08010 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_04: 0x32c08014 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08014 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_05: 0x32c08018 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08018 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_06: 0x32c0801c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0801c run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_07: 0x32c08020 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08020 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_08: 0x32c08024 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08024 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_09: 0x32c08028 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08028 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_0a: 0x32c0802c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0802c run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_0b: 0x32c08030 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08030 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_0c: 0x32c08034 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08034 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_0d: 0x32c08038 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c08038 run_sample_programs() @201: done SEC_PROXY_MESSAGE_08_0e: 0x32c0803c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0803c run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_00: 0x32c09004 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09004 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_01: 0x32c09008 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09008 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_02: 0x32c0900c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0900c run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_03: 0x32c09010 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09010 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_04: 0x32c09014 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09014 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_05: 0x32c09018 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09018 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_06: 0x32c0901c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0901c run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_07: 0x32c09020 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09020 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_08: 0x32c09024 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09024 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_09: 0x32c09028 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09028 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_0a: 0x32c0902c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0902c run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_0b: 0x32c09030 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09030 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_0c: 0x32c09034 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09034 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_0d: 0x32c09038 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c09038 run_sample_programs() @201: done SEC_PROXY_MESSAGE_09_0e: 0x32c0903c 0x00000000 run_sample_programs() @199: write 0x11223344 to 0xffffffff32c0903c run_sample_programs() @201: done
