Hello TI,
I am using SDK 06.02.00.07 with a bare-metal application. The requirement is such that I can't switch to the latest SDK release. In the resource manager configuration present at ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/system-firmware-image-gen-2019.12/soc/j721e/evm/rm-cfg.c, there are no resource assignments present for J721E_DEV_NAVSS0_INTR_ROUTER_0 device. When I try to add an entry for the above device, the sysfw.itb is generated successfully but the board stops booting. I added the following entry in rm-cfg.c and is copied from the ti-processor-sdk-linux-am65xx-evm-07_00_00 release:
/* Main Nav IR */
.start_resource = 10,
.num_resource = 100,
.type = RESASG_UTYPE (J721E_DEV_NAVSS0_INTR_ROUTER_0,
RESASG_SUBTYPE_IR_OUTPUT),
.host_id = HOST_ID_A72_2,
The following line is added to the resasg_types.h
* Interrupt router subtype definitions
#define RESASG_SUBTYPE_IR_OUTPUT (0x0000U)
The total number of entries in the resource table is increased by one as below in sysfw_img_cfg.h file:
#define BOARDCFG_RM_RESASG_ENTRIES 271
I am using make sysfw-image command to create the sysfw.itb. For convenience, I have also attached the complete rm-cfg.c file
/* * K3 System Firmware Resource Management Configuration Data * * Copyright (C) 2019-2020 Texas Instruments Incorporated - http://www.ti.com/ * Andreas Dannenberg <dannenberg@ti.com> * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "common.h" #include <hosts.h> #include <devices.h> #include <resasg_types.h> const struct boardcfg_rm_local j721e_boardcfg_rm_data = { .rm_boardcfg = { /* boardcfg_abi_rev */ .rev = { .boardcfg_abi_maj = 0x0, .boardcfg_abi_min = 0x1, }, /* boardcfg_rm_host_cfg */ .host_cfg = { .subhdr = { .magic = BOARDCFG_RM_HOST_CFG_MAGIC_NUM, .size = sizeof (struct boardcfg_rm_host_cfg), }, .host_cfg_entries = {{0}}, }, /* boardcfg_rm_resasg */ .resasg = { .subhdr = { .magic = BOARDCFG_RM_RESASG_MAGIC_NUM, .size = sizeof (struct boardcfg_rm_resasg), }, .resasg_entries_size = BOARDCFG_RM_RESASG_ENTRIES * sizeof (struct boardcfg_rm_resasg_entry), .reserved = 0, /* .resasg_entries is set via boardcfg_rm_local */ }, }, /* This is actually part of .resasg */ .resasg_entries = { /* GIC/CLEC slot assignment for NAVSS INTR */ { .start_resource = 392, .num_resource = 32, .type = RESASG_UTYPE (J721E_DEV_COMPUTE_CLUSTER0_GIC500SS, RESASG_SUBTYPE_COMPUTE_CLUSTER0_GIC500SS_SPI_IRQ_GROUP0_FROM_GPIOMUX_INTRTR0), .host_id = HOST_ID_A72_2, }, { .start_resource = 424, .num_resource = 24, .type = RESASG_UTYPE (J721E_DEV_COMPUTE_CLUSTER0_GIC500SS, RESASG_SUBTYPE_COMPUTE_CLUSTER0_GIC500SS_SPI_IRQ_GROUP0_FROM_GPIOMUX_INTRTR0), .host_id = HOST_ID_A72_3, }, { .start_resource = 960, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_COMPUTE_CLUSTER0_GIC500SS, RESASG_SUBTYPE_COMPUTE_CLUSTER0_GIC500SS_SPI_IRQ_GROUP0_FROM_WKUP_GPIOMUX_INTRTR0), .host_id = HOST_ID_A72_2, }, { .start_resource = 74, .num_resource = 54, .type = RESASG_UTYPE (J721E_DEV_COMPUTE_CLUSTER0_GIC500SS, RESASG_SUBTYPE_COMPUTE_CLUSTER0_GIC500SS_SPI_IRQ_GROUP0_FROM_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_A72_2, }, { .start_resource = 448, .num_resource = 64, .type = RESASG_UTYPE (J721E_DEV_COMPUTE_CLUSTER0_GIC500SS, RESASG_SUBTYPE_COMPUTE_CLUSTER0_GIC500SS_SPI_IRQ_GROUP1_FROM_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_A72_2, }, { .start_resource = 672, .num_resource = 44, .type = RESASG_UTYPE (J721E_DEV_COMPUTE_CLUSTER0_GIC500SS, RESASG_SUBTYPE_COMPUTE_CLUSTER0_GIC500SS_SPI_IRQ_GROUP2_FROM_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_A72_3, }, { .start_resource = 716, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_COMPUTE_CLUSTER0_CLEC, RESASG_SUBTYPE_COMPUTE_CLUSTER0_GIC500SS_SPI_IRQ_GROUP2_FROM_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_C7X_1, }, /* MCU_0_R5_0 CPU INTR */ { .start_resource = 68U, .num_resource = 28U, .type = RESASG_UTYPE(J721E_DEV_MCU_R5FSS0_CORE0, RESASG_SUBTYPE_MCU_R5FSS0_CORE0_INTR_IRQ_GROUP0_FROM_MCU_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 124U, .num_resource = 16U, .type = RESASG_UTYPE(J721E_DEV_MCU_R5FSS0_CORE0, RESASG_SUBTYPE_MCU_R5FSS0_CORE0_INTR_IRQ_GROUP0_FROM_WKUP_GPIOMUX_INTRTR0), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 160U, .num_resource = 64U, .type = RESASG_UTYPE(J721E_DEV_MCU_R5FSS0_CORE0, RESASG_SUBTYPE_MCU_R5FSS0_CORE0_INTR_IRQ_GROUP0_FROM_MAIN2MCU_LVL_INTRTR0), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 224U, .num_resource = 48U, .type = RESASG_UTYPE(J721E_DEV_MCU_R5FSS0_CORE0, RESASG_SUBTYPE_MCU_R5FSS0_CORE0_INTR_IRQ_GROUP0_FROM_MAIN2MCU_PLS_INTRTR0), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 376U, .num_resource = 4U, .type = RESASG_UTYPE(J721E_DEV_MCU_R5FSS0_CORE0, RESASG_SUBTYPE_MCU_R5FSS0_CORE0_INTR_IRQ_GROUP0_FROM_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_MCU_0_R5_0, }, /* MCU_0_R5_2 CPU INTR */ { .start_resource = 68U, .num_resource = 28U, .type = RESASG_UTYPE(J721E_DEV_MCU_R5FSS0_CORE1, RESASG_SUBTYPE_MCU_R5FSS0_CORE1_INTR_IRQ_GROUP0_FROM_MCU_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 124U, .num_resource = 16U, .type = RESASG_UTYPE(J721E_DEV_MCU_R5FSS0_CORE1, RESASG_SUBTYPE_MCU_R5FSS0_CORE1_INTR_IRQ_GROUP0_FROM_WKUP_GPIOMUX_INTRTR0), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 160U, .num_resource = 64U, .type = RESASG_UTYPE(J721E_DEV_MCU_R5FSS0_CORE1, RESASG_SUBTYPE_MCU_R5FSS0_CORE1_INTR_IRQ_GROUP0_FROM_MAIN2MCU_LVL_INTRTR0), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 224U, .num_resource = 48U, .type = RESASG_UTYPE(J721E_DEV_MCU_R5FSS0_CORE1, RESASG_SUBTYPE_MCU_R5FSS0_CORE1_INTR_IRQ_GROUP0_FROM_MAIN2MCU_PLS_INTRTR0), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 380U, .num_resource = 4U, .type = RESASG_UTYPE(J721E_DEV_MCU_R5FSS0_CORE1, RESASG_SUBTYPE_MCU_R5FSS0_CORE1_INTR_IRQ_GROUP0_FROM_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_MCU_0_R5_2, }, /* MAIN_0_R5_0 CPU INTR */ { .start_resource = 176U, .num_resource = 16U, .type = RESASG_UTYPE(J721E_DEV_R5FSS0_CORE0, RESASG_SUBTYPE_R5FSS0_CORE0_INTR_IRQ_GROUP0_FROM_GPIOMUX_INTRTR0), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 228U, .num_resource = 28U, .type = RESASG_UTYPE(J721E_DEV_R5FSS0_CORE0, RESASG_SUBTYPE_R5FSS0_CORE0_INTR_IRQ_GROUP0_FROM_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 256U, .num_resource = 256U, .type = RESASG_UTYPE(J721E_DEV_R5FSS0_CORE0, RESASG_SUBTYPE_R5FSS0_CORE0_INTR_IRQ_GROUP0_FROM_R5FSS0_INTROUTER0), .host_id = HOST_ID_MAIN_0_R5_0, }, /* MAIN_0_R5_2 CPU INTR */ { .start_resource = 176U, .num_resource = 16U, .type = RESASG_UTYPE(J721E_DEV_R5FSS0_CORE1, RESASG_SUBTYPE_R5FSS0_CORE1_INTR_IRQ_GROUP0_FROM_GPIOMUX_INTRTR0), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 228U, .num_resource = 28U, .type = RESASG_UTYPE(J721E_DEV_R5FSS0_CORE1, RESASG_SUBTYPE_R5FSS0_CORE1_INTR_IRQ_GROUP0_FROM_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 256U, .num_resource = 256U, .type = RESASG_UTYPE(J721E_DEV_R5FSS0_CORE1, RESASG_SUBTYPE_R5FSS0_CORE1_INTR_IRQ_GROUP0_FROM_R5FSS0_INTROUTER0), .host_id = HOST_ID_MAIN_0_R5_2, }, /* MAIN_1_R5_0 CPU INTR */ { .start_resource = 176U, .num_resource = 16U, .type = RESASG_UTYPE(J721E_DEV_R5FSS1_CORE0, RESASG_SUBTYPE_R5FSS1_CORE0_INTR_IRQ_GROUP0_FROM_GPIOMUX_INTRTR0), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 228U, .num_resource = 28U, .type = RESASG_UTYPE(J721E_DEV_R5FSS1_CORE0, RESASG_SUBTYPE_R5FSS1_CORE0_INTR_IRQ_GROUP0_FROM_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 256U, .num_resource = 256U, .type = RESASG_UTYPE(J721E_DEV_R5FSS1_CORE0, RESASG_SUBTYPE_R5FSS1_CORE0_INTR_IRQ_GROUP0_FROM_R5FSS1_INTROUTER0), .host_id = HOST_ID_MAIN_1_R5_0, }, /* MAIN_1_R5_2 CPU INTR */ { .start_resource = 176U, .num_resource = 16U, .type = RESASG_UTYPE(J721E_DEV_R5FSS1_CORE1, RESASG_SUBTYPE_R5FSS1_CORE1_INTR_IRQ_GROUP0_FROM_GPIOMUX_INTRTR0), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 228U, .num_resource = 28U, .type = RESASG_UTYPE(J721E_DEV_R5FSS1_CORE1, RESASG_SUBTYPE_R5FSS1_CORE1_INTR_IRQ_GROUP0_FROM_NAVSS0_INTR_ROUTER_0), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 256U, .num_resource = 256U, .type = RESASG_UTYPE(J721E_DEV_R5FSS1_CORE1, RESASG_SUBTYPE_R5FSS1_CORE1_INTR_IRQ_GROUP0_FROM_R5FSS1_INTROUTER0), .host_id = HOST_ID_MAIN_1_R5_2, }, /* C6X_0_1 CPU INTR */ { .start_resource = 8U, .num_resource = 1U, .type = RESASG_UTYPE(J721E_DEV_C66SS0_CORE0, RESASG_SUBTYPE_C66SS0_CORE0_C66_EVENT_IN_SYNC_IRQ_GROUP0_FROM_C66SS0_INTROUTER0), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 15U, .num_resource = 81U, .type = RESASG_UTYPE(J721E_DEV_C66SS0_CORE0, RESASG_SUBTYPE_C66SS0_CORE0_C66_EVENT_IN_SYNC_IRQ_GROUP1_FROM_C66SS0_INTROUTER0), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 99U, .num_resource = 1U, .type = RESASG_UTYPE(J721E_DEV_C66SS0_CORE0, RESASG_SUBTYPE_C66SS0_CORE0_C66_EVENT_IN_SYNC_IRQ_GROUP2_FROM_C66SS0_INTROUTER0), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 102U, .num_resource = 8U, .type = RESASG_UTYPE(J721E_DEV_C66SS0_CORE0, RESASG_SUBTYPE_C66SS0_CORE0_C66_EVENT_IN_SYNC_IRQ_GROUP3_FROM_C66SS0_INTROUTER0), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 114U, .num_resource = 2U, .type = RESASG_UTYPE(J721E_DEV_C66SS0_CORE0, RESASG_SUBTYPE_C66SS0_CORE0_C66_EVENT_IN_SYNC_IRQ_GROUP4_FROM_C66SS0_INTROUTER0), .host_id = HOST_ID_C6X_0_1, }, /* C6X_1_1 CPU INTR */ { .start_resource = 8U, .num_resource = 1U, .type = RESASG_UTYPE(J721E_DEV_C66SS1_CORE0, RESASG_SUBTYPE_C66SS1_CORE0_C66_EVENT_IN_SYNC_IRQ_GROUP0_FROM_C66SS1_INTROUTER0), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 15U, .num_resource = 81U, .type = RESASG_UTYPE(J721E_DEV_C66SS1_CORE0, RESASG_SUBTYPE_C66SS1_CORE0_C66_EVENT_IN_SYNC_IRQ_GROUP1_FROM_C66SS1_INTROUTER0), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 99U, .num_resource = 1U, .type = RESASG_UTYPE(J721E_DEV_C66SS1_CORE0, RESASG_SUBTYPE_C66SS1_CORE0_C66_EVENT_IN_SYNC_IRQ_GROUP2_FROM_C66SS1_INTROUTER0), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 102U, .num_resource = 8U, .type = RESASG_UTYPE(J721E_DEV_C66SS1_CORE0, RESASG_SUBTYPE_C66SS1_CORE0_C66_EVENT_IN_SYNC_IRQ_GROUP3_FROM_C66SS1_INTROUTER0), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 114U, .num_resource = 2U, .type = RESASG_UTYPE(J721E_DEV_C66SS1_CORE0, RESASG_SUBTYPE_C66SS1_CORE0_C66_EVENT_IN_SYNC_IRQ_GROUP4_FROM_C66SS1_INTROUTER0), .host_id = HOST_ID_C6X_1_1, }, /* AUTO GENERATED ENTRIES BELOW */ /* Main Nav UHC TX Channel */ { .start_resource = 0, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_UHCHAN), .host_id = HOST_ID_A72_2, }, { .start_resource = 2, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_UHCHAN), .host_id = HOST_ID_MAIN_0_R5_2, }, /* Main Nav UHC RX Channel */ { .start_resource = 0, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_UHCHAN), .host_id = HOST_ID_A72_2, }, { .start_resource = 2, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_UHCHAN), .host_id = HOST_ID_MAIN_0_R5_2, }, /* Main Nav HC TX Channel */ { .start_resource = 4, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_HCHAN), .host_id = HOST_ID_A72_2, }, { .start_resource = 8, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_HCHAN), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 10, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_HCHAN), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 14, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_HCHAN), .host_id = HOST_ID_ALL, }, /* Main Nav HC RX Channel */ { .start_resource = 4, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_HCHAN), .host_id = HOST_ID_A72_2, }, { .start_resource = 8, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_HCHAN), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 10, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_HCHAN), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 14, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_HCHAN), .host_id = HOST_ID_ALL, }, /* Main Nav Total TX Channel */ { .start_resource = 16, .num_resource = 36, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_A72_2, }, { .start_resource = 52, .num_resource = 20, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_A72_3, }, { .start_resource = 72, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 74, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 76, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 82, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 88, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_C7X_1, }, { .start_resource = 94, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 110, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 118, .num_resource = 7, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 125, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 133, .num_resource = 7, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_ALL, }, /* Main Nav Total RX Channel */ { .start_resource = 16, .num_resource = 36, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_A72_2, }, { .start_resource = 52, .num_resource = 20, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_A72_3, }, { .start_resource = 72, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 74, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 76, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 82, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 88, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_C7X_1, }, { .start_resource = 94, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 110, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 118, .num_resource = 7, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 125, .num_resource = 15, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MAIN_0_R5_2, }, /* Main Nav extended TX channels */ { .start_resource = 140, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_ECHAN), .host_id = HOST_ID_C7X_1, }, { .start_resource = 156, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_ECHAN), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 162, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_ECHAN), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 168, .num_resource = 132, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_ECHAN), .host_id = HOST_ID_MAIN_0_R5_2, }, /* Main Nav UHC TX ring */ { .start_resource = 0, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_UH), .host_id = HOST_ID_A72_2, }, { .start_resource = 2, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_UH), .host_id = HOST_ID_MAIN_0_R5_2, }, /* Main Nav UHC RX ring */ { .start_resource = 300, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX_UH), .host_id = HOST_ID_A72_2, }, { .start_resource = 302, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX_UH), .host_id = HOST_ID_MAIN_0_R5_2, }, /* Main Nav HC TX ring */ { .start_resource = 4, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_H), .host_id = HOST_ID_A72_2, }, { .start_resource = 8, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_H), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 10, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_H), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 14, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_H), .host_id = HOST_ID_ALL, }, /* Main Nav HC RX ring */ { .start_resource = 304, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX_H), .host_id = HOST_ID_A72_2, }, { .start_resource = 308, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX_H), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 310, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX_H), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 314, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX_H), .host_id = HOST_ID_ALL, }, /* Main Nav TX ring */ { .start_resource = 16, .num_resource = 36, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_A72_2, }, { .start_resource = 52, .num_resource = 20, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_A72_3, }, { .start_resource = 72, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 74, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 76, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 82, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 88, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_C7X_1, }, { .start_resource = 94, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 110, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 118, .num_resource = 7, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 125, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 133, .num_resource = 7, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_ALL, }, /* Main Nav RX ring */ { .start_resource = 316, .num_resource = 36, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_A72_2, }, { .start_resource = 352, .num_resource = 20, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_A72_3, }, { .start_resource = 372, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 374, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 376, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 382, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 388, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_C7X_1, }, { .start_resource = 394, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 410, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 418, .num_resource = 7, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 425, .num_resource = 15, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MAIN_0_R5_2, }, /* Main Nav TX Extended rings */ { .start_resource = 140, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_EXT), .host_id = HOST_ID_C7X_1, }, { .start_resource = 156, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_EXT), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 162, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_EXT), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 168, .num_resource = 132, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_EXT), .host_id = HOST_ID_MAIN_0_R5_2, }, /* Main Nav ring monitors */ { .start_resource = 0, .num_resource = 3, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_MONITORS), .host_id = HOST_ID_A72_2, }, { .start_resource = 3, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_MONITORS), .host_id = HOST_ID_A72_3, }, { .start_resource = 5, .num_resource = 27, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_MONITORS), .host_id = HOST_ID_ALL, }, /* Main Nav nonsecure proxies */ { .start_resource = 0, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_PROXY_0, RESASG_SUBTYPE_PROXY_PROXIES), .host_id = HOST_ID_A72_2, }, { .start_resource = 4, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_PROXY_0, RESASG_SUBTYPE_PROXY_PROXIES), .host_id = HOST_ID_A72_3, }, { .start_resource = 8, .num_resource = 56, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_PROXY_0, RESASG_SUBTYPE_PROXY_PROXIES), .host_id = HOST_ID_ALL, }, /* Main Nav Free RX Flow */ { .start_resource = 140, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_A72_2, }, { .start_resource = 156, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_A72_3, }, { .start_resource = 172, .num_resource = 64, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_ALL, }, { .start_resource = 236, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_MAIN_0_R5_2, }, /* Main Nav Free Ring */ { .start_resource = 440, .num_resource = 150, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_A72_2, }, { .start_resource = 590, .num_resource = 40, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_A72_3, }, { .start_resource = 630, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 636, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 642, .num_resource = 10, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 652, .num_resource = 10, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 662, .num_resource = 32, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_C7X_1, }, { .start_resource = 694, .num_resource = 38, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 732, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 744, .num_resource = 40, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 784, .num_resource = 182, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 966, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_ALL, }, /* Main Nav IR */ { .start_resource = 10, .num_resource = 100, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_INTR_ROUTER_0, RESASG_SUBTYPE_IR_OUTPUT), .host_id = HOST_ID_A72_2, }, /* Main Nav IA VINT */ { .start_resource = 38, .num_resource = 86, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_A72_2, }, { .start_resource = 124, .num_resource = 32, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_A72_3, }, { .start_resource = 156, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 168, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 180, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_C7X_1, }, { .start_resource = 192, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 204, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 216, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 224, .num_resource = 24, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 248, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_ALL, }, /* Main Nav IA SEVT */ { .start_resource = 38, .num_resource = 1024, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_A72_2, }, { .start_resource = 1062, .num_resource = 512, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_A72_3, }, { .start_resource = 1574, .num_resource = 32, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 1606, .num_resource = 32, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 1638, .num_resource = 256, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 1894, .num_resource = 256, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 2150, .num_resource = 256, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_C7X_1, }, { .start_resource = 2406, .num_resource = 256, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 2662, .num_resource = 256, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 2918, .num_resource = 256, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 3174, .num_resource = 512, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 3686, .num_resource = 922, .type = RESASG_UTYPE (J721E_DEV_NAVSS0_UDMASS_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_ALL, }, /* MCU Nav HC TX Channel */ { .start_resource = 0, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_HCHAN), .host_id = HOST_ID_MCU_0_R5_0, }, /* MCU Nav HC RX Channel */ { .start_resource = 0, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_HCHAN), .host_id = HOST_ID_MCU_0_R5_0, }, /* MCU Nav Total TX Channel */ { .start_resource = 2, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_A72_2, }, { .start_resource = 14, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_A72_3, }, { .start_resource = 20, .num_resource = 5, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 25, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MCU_0_R5_1, }, { .start_resource = 25, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 27, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 29, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 31, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_C7X_1, }, { .start_resource = 33, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 35, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 37, .num_resource = 3, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 40, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 42, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_TX_CHAN), .host_id = HOST_ID_ALL, }, /* MCU Nav Total RX Channel */ { .start_resource = 2, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_A72_2, }, { .start_resource = 14, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_A72_3, }, { .start_resource = 20, .num_resource = 5, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 25, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MCU_0_R5_1, }, { .start_resource = 25, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 27, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 29, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 31, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_C7X_1, }, { .start_resource = 33, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 35, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 37, .num_resource = 3, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 40, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 42, .num_resource = 3, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_CHAN), .host_id = HOST_ID_ALL, }, /* MCU Nav HC Tx ring */ { .start_resource = 0, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX_H), .host_id = HOST_ID_MCU_0_R5_0, }, /* MCU Nav HC Rx ring */ { .start_resource = 48, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX_H), .host_id = HOST_ID_MCU_0_R5_0, }, /* MCU Nav Tx ring */ { .start_resource = 2, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_A72_2, }, { .start_resource = 14, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_A72_3, }, { .start_resource = 20, .num_resource = 5, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 25, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MCU_0_R5_1, }, { .start_resource = 25, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 27, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 29, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 31, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_C7X_1, }, { .start_resource = 33, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 35, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 37, .num_resource = 3, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 40, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 42, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_TX), .host_id = HOST_ID_ALL, }, /* MCU Nav Rx ring */ { .start_resource = 50, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_A72_2, }, { .start_resource = 62, .num_resource = 6, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_A72_3, }, { .start_resource = 68, .num_resource = 5, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 73, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MCU_0_R5_1, }, { .start_resource = 73, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 75, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 77, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 79, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_C7X_1, }, { .start_resource = 81, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 83, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 85, .num_resource = 3, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 88, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 90, .num_resource = 3, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_UDMAP_RX), .host_id = HOST_ID_ALL, }, /* MCU Nav ring monitors */ { .start_resource = 0, .num_resource = 3, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_MONITORS), .host_id = HOST_ID_A72_2, }, { .start_resource = 3, .num_resource = 2, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_MONITORS), .host_id = HOST_ID_A72_3, }, { .start_resource = 5, .num_resource = 27, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_MONITORS), .host_id = HOST_ID_ALL, }, /* MCU Nav nonsecure proxies */ { .start_resource = 1, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_PROXY_0, RESASG_SUBTYPE_PROXY_PROXIES), .host_id = HOST_ID_A72_2, }, { .start_resource = 5, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_PROXY_0, RESASG_SUBTYPE_PROXY_PROXIES), .host_id = HOST_ID_A72_3, }, { .start_resource = 9, .num_resource = 55, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_PROXY_0, RESASG_SUBTYPE_PROXY_PROXIES), .host_id = HOST_ID_ALL, }, /* MCU Nav Free RX Flow */ { .start_resource = 48, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_A72_2, }, { .start_resource = 56, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_A72_3, }, { .start_resource = 60, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 68, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_MCU_0_R5_1, }, { .start_resource = 68, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 72, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 76, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 80, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 88, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 92, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_UDMAP_0, RESASG_SUBTYPE_UDMAP_RX_FLOW_COMMON), .host_id = HOST_ID_ALL, }, /* MCU Nav Free Ring */ { .start_resource = 96, .num_resource = 20, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_A72_2, }, { .start_resource = 116, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_A72_3, }, { .start_resource = 124, .num_resource = 32, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 156, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MCU_0_R5_1, }, { .start_resource = 156, .num_resource = 12, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 168, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 176, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 184, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_C7X_1, }, { .start_resource = 192, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 200, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 208, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 224, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 232, .num_resource = 20, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_RINGACC_0, RESASG_SUBTYPE_RA_GP), .host_id = HOST_ID_ALL, }, /* MCU Nav IA VINT */ { .start_resource = 8, .num_resource = 32, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_A72_2, }, { .start_resource = 40, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_A72_3, }, { .start_resource = 56, .num_resource = 64, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 120, .num_resource = 4, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 124, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 140, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 156, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_C7X_1, }, { .start_resource = 164, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 172, .num_resource = 8, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 180, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 196, .num_resource = 16, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 212, .num_resource = 44, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_IA_VINT), .host_id = HOST_ID_ALL, }, /* MCU Nav IA SEVT */ { .start_resource = 16392, .num_resource = 128, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_A72_2, }, { .start_resource = 16520, .num_resource = 128, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_A72_3, }, { .start_resource = 16648, .num_resource = 256, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MCU_0_R5_0, }, { .start_resource = 16904, .num_resource = 64, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MCU_0_R5_2, }, { .start_resource = 16968, .num_resource = 128, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MAIN_1_R5_0, }, { .start_resource = 17096, .num_resource = 128, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MAIN_1_R5_2, }, { .start_resource = 17224, .num_resource = 64, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_C7X_1, }, { .start_resource = 17288, .num_resource = 64, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_C6X_0_1, }, { .start_resource = 17352, .num_resource = 64, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_C6X_1_1, }, { .start_resource = 17416, .num_resource = 128, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MAIN_0_R5_0, }, { .start_resource = 17544, .num_resource = 128, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_MAIN_0_R5_2, }, { .start_resource = 17672, .num_resource = 248, .type = RESASG_UTYPE (J721E_DEV_MCU_NAVSS0_INTAGGR_0, RESASG_SUBTYPE_GLOBAL_EVENT_SEVT), .host_id = HOST_ID_ALL, }, }, };
umkhan@ubuntu:~/ti-processor-sdk-linux-automotive-j7-evm-06_02_00$ make sysfw-image ===================================== Building the Linux Kernel DTBs ===================================== make -C /home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0 ARCH=arm64 CROSS_COMPILE=/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-linux-gnu- tisdk_j7-evm_defconfig make[1]: Entering directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' # # configuration written to .config # make[1]: Leaving directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Entering directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' scripts/kconfig/conf --syncconfig Kconfig make[1]: Leaving directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Entering directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Leaving directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Entering directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Leaving directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Entering directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Leaving directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Entering directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Leaving directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Entering directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Leaving directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Entering directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' make[1]: Leaving directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/linux-4.19.94+gitAUTOINC+5a23bc00e0-g5a23bc00e0' ============================= Building SYSFW Image ============================= make[1]: Entering directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/system-firmware-image-gen-2019.12' ./gen_its.sh j721e evm sysfw.bin board-cfg.bin pm-cfg.bin rm-cfg.bin sec-cfg.bin > out/soc/j721e/evm/sysfw-j721e-evm.its fatal: not a git repository (or any of the parent directories): .git mkimage -f out/soc/j721e/evm/sysfw-j721e-evm.its -r sysfw-j721e-evm.itb FIT description: SYSFW and Config Fragments Created: Tue Aug 3 03:20:52 2021 Image 0 (sysfw.bin) Description: sysfw Created: Tue Aug 3 03:20:52 2021 Type: Firmware Compression: uncompressed Data Size: 263052 Bytes = 256.89 KiB = 0.25 MiB Architecture: ARM OS: Unknown OS Load Address: unavailable Image 1 (board-cfg.bin) Description: board-cfg Created: Tue Aug 3 03:20:52 2021 Type: Firmware Compression: uncompressed Data Size: 29 Bytes = 0.03 KiB = 0.00 MiB Architecture: ARM OS: Unknown OS Load Address: unavailable Image 2 (pm-cfg.bin) Description: pm-cfg Created: Tue Aug 3 03:20:52 2021 Type: Firmware Compression: uncompressed Data Size: 2 Bytes = 0.00 KiB = 0.00 MiB Architecture: ARM OS: Unknown OS Load Address: unavailable Image 3 (rm-cfg.bin) Description: rm-cfg Created: Tue Aug 3 03:20:52 2021 Type: Firmware Compression: uncompressed Data Size: 2526 Bytes = 2.47 KiB = 0.00 MiB Architecture: ARM OS: Unknown OS Load Address: unavailable Image 4 (sec-cfg.bin) Description: sec-cfg Created: Tue Aug 3 03:20:52 2021 Type: Firmware Compression: uncompressed Data Size: 303 Bytes = 0.30 KiB = 0.00 MiB Architecture: ARM OS: Unknown OS Load Address: unavailable make[1]: Leaving directory '/home/umkhan/ti-processor-sdk-linux-automotive-j7-evm-06_02_00/board-support/system-firmware-image-gen-2019.12'
Can you please help me figure out what might be stopping my board from booting?
Umair Khan
