I want to startup A core and R core in our board. but through A core starting up, there is something wrong and can not start up successfully. The start up log as following:
[ OK ] Created slice system-systemd\x2dfsck.slice.
ERROR: Unhandled External Abort received on 0x80000000 from S-EL1
ERROR: exception reason=0 syndrome=0xbf000000
Unhandled Exception from EL1
x0 = 0x0000000000000000
x1 = 0x0000000000000000
x2 = 0x0000000000000002
x3 = 0x0000000000000001
x4 = 0x0000000000000000
x5 = 0xffff800015aefb9c
x6 = 0xffff800015aefb9c
x7 = 0x8080808080808080
x8 = 0xfefefefefefefeff
x9 = 0x7f7f7f7f7f7f7f7f
x10 = 0xfefefefefefefeff
x11 = 0x0101010101010101
x12 = 0x0000000000000000
x13 = 0xffffffffffffffff
x14 = 0xffffffffffffffff
x15 = 0xffffffffffffffff
x16 = 0x0000000000000000
x17 = 0x0000000000000000
x18 = 0x0000000000000000
x19 = 0xffff800015aefab8
x20 = 0xffff000842a00000
x21 = 0x0000000000001388
x22 = 0xffff000842a77e00
x23 = 0x0000ffffc92bd4a0
x24 = 0x00000080001149b3
x25 = 0x0000000056000000
x26 = 0x0000000000000000
x27 = 0x0000000000000000
x28 = 0xffff000842a77e00
x29 = 0xffff800015aefa20
x30 = 0xffff8000108ddc80
scr_el3 = 0x000000000000073d
sctlr_el3 = 0x0000000030cd183f
cptr_el3 = 0x0000000000000000
tcr_el3 = 0x0000000080803520
daif = 0x00000000000002c0
mair_el3 = 0x00000000004404ff
spsr_el3 = 0x0000000060000005
elr_el3 = 0xffff80001074bcd8
ttbr0_el3 = 0x0000000070010b00
esr_el3 = 0x00000000bf000000
far_el3 = 0x0000000000000000
spsr_el1 = 0x0000000060000000
elr_el1 = 0x0000ffff83003a5c
spsr_abt = 0x0000000000000000
spsr_und = 0x0000000000000000
spsr_irq = 0x0000000000000000
spsr_fiq = 0x0000000000000000
sctlr_el1 = 0x0000000034d4d91d
actlr_el1 = 0x0000000000000000
cpacr_el1 = 0x0000000000300000
csselr_el1 = 0x0000000000000000
sp_el1 = 0xffff800015aefa20
esr_el1 = 0x0000000056000000
ttbr0_el1 = 0x00000008c1653a00
ttbr1_el1 = 0x01c2000082e90000
mair_el1 = 0x0000bbff440c0400
amair_el1 = 0x0000000000000000
tcr_el1 = 0x00000034f5d07590
tpidr_el1 = 0xffff80086eb50000
tpidr_el0 = 0x0000ffff835d7870
tpidrro_el0 = 0x0000000000000000
par_el1 = 0x0000000000000000
mpidr_el1 = 0x0000000080000000
afsr0_el1 = 0x0000000000000000
afsr1_el1 = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1 = 0xffff800010081800
cntp_ctl_el0 = 0x0000000000000005
cntp_cval_el0 = 0x00000000bc8a2878
cntv_ctl_el0 = 0x0000000000000000
cntv_cval_el0 = 0x0000000000000000
cntkctl_el1 = 0x00000000000000d6
sp_el0 = 0x000000007000a3d0
isr_el1 = 0x0000000000000040
dacr32_el2 = 0x0000000000000000
ifsr32_el2 = 0x0000000000000000
cpuectlr_el1 = 0x0000001b00000040
cpumerrsr_el1 = 0x0000000000000000
l2merrsr_el1 = 0x0000000000000000
I put our executive file in the SD card, As bellow:
-rw-r--r-- 1 root root 7637928 9月 3 17:12 app_remoteswitchcfg_server1.xer5f
-rw-r--r-- 1 root root 699528 9月 2 18:50 app_remoteswitchcfg_server_strip.xer5f
-rw-r--r-- 1 root root 7675420 9月 3 13:59 app_remoteswitchcfg_server.xer5f
drwxr-xr-x 2 root root 4096 9月 2 18:50 cadence
drwxr-xr-x 2 root root 4096 9月 2 18:50 ethfw
-rw-r--r-- 1 root root 918268 9月 2 18:50 iwlwifi-3160-17.ucode
-rw-r--r-- 1 root root 1745176 9月 2 18:50 iwlwifi-8000C-13.ucode
-rw-r--r-- 1 root root 2351636 9月 2 18:50 iwlwifi-8000C-16.ucode
-rw-r--r-- 1 root root 2394060 9月 2 18:50 iwlwifi-8000C-21.ucode
-rw-r--r-- 1 root root 2120860 9月 2 18:50 iwlwifi-8000C-22.ucode
-rw-r--r-- 1 root root 2227284 9月 2 18:50 iwlwifi-8000C-27.ucode
-rw-r--r-- 1 root root 2310116 9月 2 18:50 iwlwifi-8000C-31.ucode
-rw-r--r-- 1 root root 2448976 9月 2 18:50 iwlwifi-8000C-34.ucode
-rw-r--r-- 1 root root 2428004 9月 2 18:50 iwlwifi-8000C-36.ucode
-rw-r--r-- 1 root root 2389968 9月 2 18:50 iwlwifi-8265-21.ucode
-rw-r--r-- 1 root root 1811984 9月 2 18:50 iwlwifi-8265-22.ucode
-rw-r--r-- 1 root root 2234528 9月 2 18:50 iwlwifi-8265-27.ucode
-rw-r--r-- 1 root root 2307104 9月 2 18:50 iwlwifi-8265-31.ucode
-rw-r--r-- 1 root root 2440780 9月 2 18:50 iwlwifi-8265-34.ucode
-rw-r--r-- 1 root root 2436632 9月 2 18:50 iwlwifi-8265-36.ucode
lrwxrwxrwx 1 root root 64 9月 2 18:50 j7-c66_0-fw -> /lib/firmware/pdk-ipc/ipc_echo_test_c66xdsp_1_release_strip.xe66
lrwxrwxrwx 1 root root 64 9月 2 18:50 j7-c66_1-fw -> /lib/firmware/pdk-ipc/ipc_echo_test_c66xdsp_2_release_strip.xe66
lrwxrwxrwx 1 root root 60 9月 2 18:50 j7-c71_0-fw -> /lib/firmware/pdk-ipc/ipc_echo_test_c7x_1_release_strip.xe71
lrwxrwxrwx 1 root root 33 9月 3 17:13 j7-main-r5f0_0-fw -> app_remoteswitchcfg_server1.xer5f
lrwxrwxrwx 1 root root 63 9月 2 18:50 j7-mcu-r5f0_0-fw -> /lib/firmware/pdk-ipc/ipc_echo_testb_mcu1_0_release_strip.xer5f
lrwxrwxrwx 1 root root 62 9月 2 18:50 j7-mcu-r5f0_1-fw -> /lib/firmware/pdk-ipc/ipc_echo_test_mcu1_1_release_strip.xer5f
lrwxrwxrwx 1 root root 49 9月 2 18:50 j7-pru0_0-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt0_0.out
lrwxrwxrwx 1 root root 49 9月 2 18:50 j7-pru0_1-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt0_1.out
lrwxrwxrwx 1 root root 49 9月 2 18:50 j7-pru1_0-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt1_0.out
lrwxrwxrwx 1 root root 49 9月 2 18:50 j7-pru1_1-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt1_1.out
lrwxrwxrwx 1 root root 49 9月 2 18:50 j7-rtu0_0-fw -> /lib/firmware/pru/RTU_RPMsg_Echo_Interrupt0_0.out
lrwxrwxrwx 1 root root 49 9月 2 18:50 j7-rtu0_1-fw -> /lib/firmware/pru/RTU_RPMsg_Echo_Interrupt0_1.out
lrwxrwxrwx 1 root root 49 9月 2 18:50 j7-rtu1_0-fw -> /lib/firmware/pru/RTU_RPMsg_Echo_Interrupt1_0.out
lrwxrwxrwx 1 root root 49 9月 2 18:50 j7-rtu1_1-fw -> /lib/firmware/pru/RTU_RPMsg_Echo_Interrupt1_1.out
lrwxrwxrwx 1 root root 35 9月 2 18:50 j7-txpru0_0-fw -> /lib/firmware/pru/TX_PRU_Halt_0.out
lrwxrwxrwx 1 root root 35 9月 2 18:50 j7-txpru0_1-fw -> /lib/firmware/pru/TX_PRU_Halt_1.out
lrwxrwxrwx 1 root root 35 9月 2 18:50 j7-txpru1_0-fw -> /lib/firmware/pru/TX_PRU_Halt_0.out
lrwxrwxrwx 1 root root 35 9月 2 18:50 j7-txpru1_1-fw -> /lib/firmware/pru/TX_PRU_Halt_1.out
And I found that A core can start up successfully if I removed j7-main-r5f0_0-fw . And when there is j7-main-r5f0_0-fw in SD card, A core can not start up successfully, R core runs OK.
Please help me to analysis why my A core can not start up successfully when there is j7-main-r5f0_0-fw in SD card.
Thanks a lot.
