Pls help review schematic diagram designing?INERTIAL_NAVIGATION_review dsp.pdf
I believe TI does not offer schematic reviews for TMS320C6748 designs.
Instead refer to OMAP-L13x / C674x / AM1x schematic review guidelines
https://www.ti.com/lit/pdf/sprack9
Since your schematics are so small I took a quick look, but not a comprehensive review. From the limited look of the partial schematics, it looks okay.
NOR boot correctly uses CS2 in your schematics... EMA_CSn_2
x16 NOR flash correctly connects SST39VF6401B A0 pin to C6748 EMA_BA[1].
This matches the recommendation from SPRUH79C C6748 TRM section 18.2.5.1 Interfacing to Asynchronous Memory:
An external pull-up resistor on NOR_CS is typically recommended.
Weak (~51K) pull ups on all MMC/SD lines are recommended.
Mark
